It is currently Sun Aug 03, 2025 7:45 pm
 Post subject: 1st Sound Port
PostPosted: Thu Nov 21, 2013 9:34 am
First name: EddieLee
Last Name: Brown
I am working on installing me 1st sound port. I am wondering what type of designs people normally do. Let's see your sound port pictures. Any tips would be appreciated.
_____________
EddieLee
 Post subject: Re: 1st Sound Port
PostPosted: Thu Nov 21, 2013 9:41 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Paw shaped sound port.
Doug
These users thanked the author Doug Balzer for the post: EddieLee (Thu Nov 21, 2013 11:29 am)
PostPosted: Thu Nov 21, 2013 9:47 am
A cross:
These users thanked the author SteveSmith for the post: EddieLee (Thu Nov 21, 2013 11:29 am)
PostPosted: Thu Nov 21, 2013 11:21 am
Just a simple oval for me, but folks always seem to think its where electronics will be installed. The fancy shapes take away that impression, although I opt for simplicity, for ease of sanding and finishing.
These users thanked the author JasonM for the post: EddieLee (Thu Nov 21, 2013 11:30 am)
PostPosted: Thu Nov 21, 2013 11:29 am
Last Name: Brown
These are all beautiful and very nicely executed. Are your sound ports cut with the use of a jig or cut free hand?
_____________
EddieLee
PostPosted: Thu Nov 21, 2013 12:35 pm
Last Name: Ensor
City: Springfield
State: Missouri
Yes.
For ovals, I use a template. This makes it easier to bind if you so choose to as well.
For other shapes like f-holes, crosses, etc. I would cut it free hand.
http://elevatelutherie.com
http://ensorguitars.com
These users thanked the author Chris Ensor for the post: EddieLee (Thu Nov 21, 2013 1:21 pm)
PostPosted: Thu Nov 21, 2013 2:29 pm
I do mine free hand with a laminate trimmer. I do glue a paper pattern on first.
These users thanked the author SteveSmith for the post: EddieLee (Thu Nov 21, 2013 4:27 pm)
PostPosted: Thu Nov 21, 2013 4:12 pm
Last Name: Sollod
Oval...
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post: EddieLee (Thu Nov 21, 2013 4:28 pm)
PostPosted: Thu Nov 21, 2013 6:45 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Freehand with a dremel, then finish with needle files...
These users thanked the author Robbie_McD for the post (total 2): Doc (Fri Nov 22, 2013 4:39 pm) • EddieLee (Thu Nov 21, 2013 7:06 pm)
PostPosted: Thu Nov 21, 2013 7:44 pm
Is there a routing jig that works on a completed box?
Old growth, shmold growth!
PostPosted: Thu Nov 21, 2013 8:19 pm
SteveSmith wrote:
A cross:
I'm digging the look on this one.
PostPosted: Fri Nov 22, 2013 9:28 am
Last Name: Brown
Todd, What do you use to make the cut? Router with a guide ring and a 1/8 bit?
And a thank you to all.
_____________
EddieLee
PostPosted: Fri Nov 22, 2013 11:10 am
theguitarwhisperer wrote:
SteveSmith wrote:
A cross:
Thanks. I designed that and used it on that rim set then found that PeterM (I think it was) had already done something similar with his guitars - so I can't claim that I originated it.
These users thanked the author SteveSmith for the post: EddieLee (Fri Nov 22, 2013 3:26 pm)
