It is currently Thu Aug 07, 2025 9:17 am
Post new topic Reply to topic  [ 54 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri Oct 11, 2013 10:00 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So while building or repairing a guitar, some sawdust and wood chips inevitably gets into the box and I found it really difficult to get it back out. How can I clean the inside of the box?
Typhoon Guitars
PostPosted: Fri Oct 11, 2013 10:16 pm
Normally I've used a vacuum cleaner, shaking the guitar about, taking care not to block the soundhole and collapse the box.
But last time I used the vacuum cleaner, (nozzle just above the soundhole) with compressed air (from a sprayer turbine) which proved more efficient and kept the sawdust/chippings from flying about the shop.
PostPosted: Fri Oct 11, 2013 10:22 pm
First name: Trevor
Last Name: Gore
City: Sydney
Vacuum cleaner on suck to remove the large bits, vacuum cleaner on blow (shifts way move air then your typical air line) to remove the smaller stuff.
http://www.goreguitars.com.au
PostPosted: Fri Oct 11, 2013 11:14 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Play Stairway to Heaven. That should do it.
Alex
These users thanked the author Alex Kleon for the post: fingerstyle1978 (Sat Oct 12, 2013 1:26 pm)
PostPosted: Sat Oct 12, 2013 12:41 am
Pretend you dropped a pick in there and shake it 'till you make it, lol.
PostPosted: Sat Oct 12, 2013 8:25 am
First name: Tony
Last Name: C
City: Brooklyn
Remove the top and vacuum. Or compressed air.
http://www.CostaGuitars.com
PMoMC
PostPosted: Sat Oct 12, 2013 8:55 am
I used popcorn once on a very funky old guitar. Shake it around, dump it out, then vacuum.
PaT
PostPosted: Sat Oct 12, 2013 10:31 am
First name: Tony
Last Name: C
City: Brooklyn
I have heard of using rice to clean inside, but I think Tai is only concerned about saw dust.
PMoMC
PostPosted: Sat Oct 12, 2013 10:37 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Yea, sawdust is really difficult to get out, it sticks to anything and nothing less than direct wiping will get rid of it. I have noticed on many occasion that sawdust would get into the box and once it's inside, no amount of shaking would remove it.
Typhoon Guitars
PostPosted: Sat Oct 12, 2013 10:46 am
State: PA
Shake with a fresh tack rag in the box.
PostPosted: Sat Oct 12, 2013 11:02 am
Last Name: Flindall
City: Peterborough
I carefully use the shop vac with a soft brush attachment that came with our central vac for the house. (but don't tell my wife - she's been looking for that attachment for years!). It works really well and gives that soft scrubbing action to pick up that hard to remove sawdust. Anything else that remains in the guitar I joke that it's no charge, the sawdust is free. :)
Rob Flindall
Flindall Guitars
http://www.flindallguitars.com
https://www.facebook.com/FlindallGuitars
PostPosted: Sat Oct 12, 2013 1:11 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
One caution with compressed air--Taylor tells me that the bodies can explode. Bet that's exciting! I use it but not too much and make sure to not block the soundhole with my hand. I have my students use a vacuum.
David Malicky
PostPosted: Sat Oct 12, 2013 1:30 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Todd Stock wrote:
Home Depot has a little pistol-grip compressed air gun that runs about $6* in most places, and it has a 1/8" ID line, so throttles between a gentle breeze and whatever your compressor will put out. I use this with a 1/8" ID vinyl flex line to direct air inside guitars, or to run the line through the tail pin hole and 1" ID vac line in sound hole.
* $483 in CA, NY, CT, due to mandatory trigger lock and CEPA air filtration regulations; $606 in MD due to mandatory $600 sortagun-shaped object registration fee, background check, fingerprinting, DNA sample, and cavity search. CO limits use to less than 10 psi and compressors of less than 3 gallon air storage capacity.
The more I read about the silly gun laws in the lower 48- the more I want to stay in Alaska. The 2nd amendment is alive and thriving here. You can buy a military grade blow torch, an AR-15, an AK-47, a Glock 40, and a .44 Magnum at your local yard sale- or in 30 minutes at Sportsman's Warehouse.
PostPosted: Sat Oct 12, 2013 2:27 pm
City: chicagoland
State: illinois
...sounds about right. drill baby drill.
:roll:
PostPosted: Sat Oct 12, 2013 4:08 pm
Last Name: Beaver
City: Lake Forest
Suck and Blow seems to be the answer!!!
Joe Beaver
Maker of Sawdust
PostPosted: Sat Oct 12, 2013 4:28 pm
First name: Alex
Last Name: Kleon
City: Whitby
I think that can be said for just about every problem in life! ;)
Alex
PostPosted: Sat Oct 12, 2013 5:55 pm
Ha! Best post of the week!!
PostPosted: Sat Oct 12, 2013 8:38 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I build all my guitars with a removable top so I can vacuum more efficiently.
PostPosted: Sat Oct 12, 2013 8:50 pm
City: chicagoland
State: illinois
its all velcro these days
PostPosted: Sat Oct 12, 2013 8:56 pm
If we had a political forum that would be a good
place to discuss gun laws. However we don't ;)
These users thanked the author LanceK for the post: David Malicky (Sun Oct 13, 2013 1:29 am)
PostPosted: Sun Oct 13, 2013 2:02 am
First name: Joey
Last Name: Holliday
City: Palmetto
Filippo Morelli wrote:
He's not discussing gun laws. He's saying how awesome Alaska is :-)
Now ... If we had an Alaska forum ....
Filippo
Indeed the 49th state is almost completely awesome. That whole sun never going down all summer/forest fire thing is my only real complaint. It's my bad though- I get all "cold dead hand" at the mention of "someone" taking my home depot spray-gun that can only hold an ounce of lacquer and be sprayed constantly for .05 milliseconds at a time...
PostPosted: Mon Oct 14, 2013 10:55 am
Last Name: Lee
Country: Wales U.K.
It's my bad though- ...
Can you please translate for an old...ish, non hip man?
PostPosted: Mon Oct 14, 2013 12:31 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Yeah, "it's my fault".
PostPosted: Mon Oct 14, 2013 9:09 pm
Last Name: A
Todd Stock wrote:
I was talking about pistol grip compressed blow guns...where did you guys get firearms from? Injuries from compressed air are a serious thing - is it even debatable that we need common sense compressor and spray accessory regulation?
compressed air pistol grip guns don't blow people - people blow people.
These users thanked the author John A for the post: Goodin (Tue Oct 15, 2013 8:20 am)
PostPosted: Tue Oct 15, 2013 7:10 am
First name: Tony
Last Name: C
City: Brooklyn
Oh... This....ahahahaha!!!! I. Can't. Stop. Laughing!!!
Can't breathe....so good..so funny!! HAHAHAHA!!!!
PMoMC
Users browsing this forum: Gasawdust, Kbore, ptourin and 24 guests
