It is currently Fri May 15, 2026 4:31 pm
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Apr 04, 2013 11:51 am
Last Name: Giltzow
City: Boise
State: Idaho
Zip/Postal Code: 83709
Hi Fred
I agree with what you are saying and I am happy with my new temperature controller. It is so much better than the method I was using. and I made it myself - I like to do that when I can. Just wanted to let some of the people that have been PMing me know, that you need to do a little more than just turn it on, set it and forget it. Thanks again for all your help - Mike
guitarsbygiltzow.com
PostPosted: Thu Apr 04, 2013 1:46 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
LarryH wrote:
Looks really good Mike. Where did you get those rocker switches? Ebay?
I just got the linked PID from Ebay and am not that thrilled with the Centigrade readout. I've contacted the seller to see if I can exchange it even though the conversion is really easy I'd rather not bother. Oh did I mention I have absolutely no clue how to wire this thing up? I'll start building a box and see where that leads me. Who gets the first PM? [:Y:]
I did buy the rocker switches off ebay. They were pretty cheap. The PID unit i bought will read out in C or F. I have never tested the accuracy of temperature readout. I would think it could have something to do with the type of probe your using. I'm using just the little wire ones like they have on the LMI unit.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Fri Apr 26, 2013 5:23 pm
First name: Arroyas
Last Name: guillaume
City: saint desirat
Zip/Postal Code: 07340
Country: france
Hello,
Last week i found a kit on ebay with the Pid controller + the thermocouple an da solid state relay of 25a.
Unfortunatly, i can't go to this obejct anymore because of restrictions from ebay for my country.
I found the same kit but with a 40a SSr. Will it work for our purpose ?
thank you very much and sory for my bad english.
PostPosted: Fri Apr 26, 2013 5:32 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
The higher amp SSR is not a problem, and could even be a benefit if you decide to run 2 blankets as some builders chose to do.
Fred
Fred Tellier
PostPosted: Fri Apr 26, 2013 5:33 pm
First name: Arroyas
City: saint desirat
Country: france
Thank you very much!
Does i need 2 pid digital controller for running 2 blankets at the same time or there is enough "slot" to connect the 2 blankets with one "kit" ? (sorry i'm very bad at elecronics!)
PostPosted: Fri Apr 26, 2013 5:41 pm
First name: Fred
Last Name: Tellier
City: Windsor
One controller will work, the thermocouple will see the temperature of the whole wood, steel slat and blanket stack.
Fred
Fred Tellier
PostPosted: Fri Apr 26, 2013 6:02 pm
First name: Arroyas
City: saint desirat
Country: france
Thank you so much for your advices! I've just ordered the kit.
PostPosted: Tue Jul 02, 2013 4:48 am
First name: Arroyas
City: saint desirat
Country: france
Hello,
I've received all the necessary to make a heat blanket controlled device.
However, i need help stuck with the wiring of all the components because i'm afraid doing something wrong!
in my mind:
1-2 to the electrical power
4-5 to the input (4-3 but i'm not sure maybe 4-5 ?) of the SSR (and my blanket connected in the 1-2 of the SSR)
9-10 to the thermocouple (but i don't known which is the - or the + in the red and blue).
PostPosted: Tue Jul 02, 2013 7:27 am
First name: Fred
Last Name: Tellier
City: Windsor
That looks right, as for + - on the Thermocouple if it is reversed the readings will be strange. Hook up power and T-couple to the unit and check that it reads room temperature. If the temperature is wrong reverse. If that much is good hook the SSR input to the output terminals of the controller and the output of the SSR will be in series with the hot side (black wire) of the power to the blanket.
If you have any questions feel free to contact me with a PM I have helped a few other get up and running.
Fred
Fred Tellier
PostPosted: Tue Jul 02, 2013 7:51 am
First name: Larry
Last Name: Hawes
And get a different Thermo-Couple now. That large threaded end is intended for a completely different purpose than a heat blanket. It's too thick and it will not register the temp properly, or nearly quick enough causing the blanket to over heat.
Get something like this with the very small wires that fit snuggly between layers in a blanket sandwich. Even the ones with the long thinner probes are too thick to convey the heat readings fast enough to the PID.
http://www.ebay.com/itm/New-1m-K-Type-T ... 257fcdc718
Thank You and Best To All
PostPosted: Tue Jul 02, 2013 8:15 am
First name: Fred
Last Name: Tellier
City: Windsor
Actually cutting the wires from the T-couple and twisting them together results in the same thing as the one linked to. I did this for my 1st 10 or so bends before getting one like this
http://www.ebay.ca/itm/K-Type-Thermocouple-Probe-f-Digital-Thermometer-Stainless-Steel-Sensor-K-752-F-/310676340965?pt=LH_DefaultDomain_0&hash=item4855c0c0e5
Fred
Fred Tellier
PostPosted: Tue Jul 02, 2013 9:17 am
First name: Larry
Last Name: Hawes
True Fred, as long as it's a 'K' type I believe. The one that came with my kit, can't remember maybe an 'N' type? just stopped working when the wires were twisted together. Just a heads up from my real world experience using a kit with the wrong thermo couple type.
And couldn't have gotten it working without your help - another thanks. [clap]
PostPosted: Tue Jul 02, 2013 11:22 am
First name: Fred
Last Name: Tellier
City: Windsor
Your was a RTD type which creates a resistance change with temperature changes, either J or K type will work with twisted wires. We used to do this and crimp the joint into a lug to mount t-couples to the sheet metal paint oven walls.
Fred
Fred Tellier
Users browsing this forum: DennisK and 408 guests
