It is currently Fri Aug 22, 2025 5:31 pm
PostPosted: Mon Feb 04, 2013 11:42 am
First name: Blake
Last Name: Dixon
City: Kelowna
Zip/Postal Code: V1V1W7
Can I spray a wash coat of shellac tether than brush on?
Blake Dixon
Kelowna B.C.
PostPosted: Mon Feb 04, 2013 2:31 pm
me too, for my taste less danger for bleeding out of some woods into purflings etc. I am using this one...like it with a 0,8mm thing...
http://www.sata.com/index.php?id=minijet
PostPosted: Mon Feb 04, 2013 2:55 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Always.
And what Herr said!
Mc
Mike Collins
PostPosted: Mon Feb 04, 2013 7:22 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Yes, you can spray. For some circumstances, such as sealing a binding channel, I brush. But I spray tops, etc., for an overall sealer/protection coat. Thin it to 1-lb. cut, as previously advised.
PostPosted: Mon Feb 04, 2013 7:26 pm
Last Name: Schreiner
City: Miami
State: FL
Zip/Postal Code: 33183
I got tired of leveling the overlaps so I now spray and that works sooooooooooooooo much better.
Michael
PostPosted: Tue Feb 05, 2013 10:10 am
So why a 1lb cut? I spray a 2lb cut with no problems. Do you just want to put down less material or ??? Just curious.
PostPosted: Tue Feb 05, 2013 1:58 pm
Last Name: Collins
City: Argyle
State: New York
I use a thicker mix also.
More shellac= less alcohol = less raised grain.
Mc
Mike Collins
PostPosted: Tue Feb 05, 2013 11:19 pm
First name: Lincoln
Last Name: Goertzen
City: Fort St John
State: BC
Why the thinner mix?
For me, the answer is simple: I get a smoother coat with a thinner mix. It's almost self-leveling, as long as you don't do anything crazy. I haven't had as good success with shooting a 2-lb cut. Runs, sags, orange peel, and nightmares were all over the place. I am no spraying expert, but I couldn't get rid of the orange peel until I started thinking thin.
Blake, my favorite method for shooting shellac is to mix Zinsser Universal Sanding Sealer (a 2-lb cut) with equal parts acetone and methyl hydrate. If I had ready access to ethanol instead of the methanol, I would use that.
This mix dries super fast, and I have no problems with rosewood right next to maple, and other such (possibly) unruly combinations.
PostPosted: Wed Feb 06, 2013 9:33 am
Thanks, I was wondering. My 2# cut is made from blonde shellac flakes dissolved in ethanol (everclear). Don't know if that makes a difference but I have not experienced any of the problems you've noted. idunno
PostPosted: Wed Feb 06, 2013 9:54 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I spray 2 coats of the Zinsser seal coat right as it comes from the can and have no problems with it.
Fred
Fred Tellier
PostPosted: Wed Feb 06, 2013 4:13 pm
First name: Lincoln
Last Name: Goertzen
City: Fort St John
State: BC
Fred,
What size tip, and what PSI at the gun are you using? That may be all I need to change.
PostPosted: Wed Feb 06, 2013 6:18 pm
Don't know about Fred but I'm using a Walcom EGO hvlp with 1.2mm tip running at 29psi.
PostPosted: Wed Feb 06, 2013 6:41 pm
Lincoln Goertzen wrote:
Fred,
2" Ox hair at 1 pass per second. No clean up required.
PostPosted: Thu Feb 07, 2013 12:14 am
First name: Fred
Last Name: Tellier
City: Windsor
I use the Devilbiss HVLP starting line touch up gun with the stock needle size, 1 mm. The air is set at 25psi an the gun.
Fred
Fred Tellier
PostPosted: Thu Feb 07, 2013 4:36 am
First name: Tom
Last Name: West
State: Nova Scotia
Spray..................If I brush something always seems to go wrong........!! When spraying Mr. Murphy goes for lunch break.
Tom
PostPosted: Thu Feb 07, 2013 8:01 am
You don't clean the brush?
PostPosted: Thu Feb 07, 2013 9:04 am
Why clean the brush? Just stick the bristle part in a plastic bag with a few drops of alcohol, tied with an elastic band. Keeps it sweet for a couple of days. Quick and fuss free. Pretty much the same with cloth and Danish oil/Tru-Oil - put the cloth in a screw top jar with a few drops of Turps. You can then use the same piece of cloth, less waste with the Tru-Oil continually being absorbed by the cloth.
PostPosted: Thu Feb 07, 2013 10:10 pm
I can see that. I wrap my good paint brushes with plastic when I take a break while house painting although I always clean them at the end of the day.
Todd Stock wrote:
Penetration.
That makes sense.
PostPosted: Fri Feb 08, 2013 1:34 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I hate spraying shellac.. I did it for a restoration project that had shellac finish and it doesn't spray nearly as nice as lacquer, since the alcohol dries out before it makes it onto the wood. Also it is a nightmare to clean, since shellac doesn't dissolve quickly like lacquer. Brushing is probably a better idea...
Typhoon Guitars
PostPosted: Fri Feb 08, 2013 5:43 am
There's no real need to clean a brush regularly used for Shellac unless it has become contaminated or you need to switch colour. Storing the brush in a plastic bag simply means that you don't have to wait around for the bristles to soften in the Shellac itself.
The overlaps are only a problem if they are 'heavy'. Very shallow overlaps are easy to rub out. Given that we are referring to a wash coat you shouldn't be getting obvious overlaps anyway. Probably down to technique or the shellac not being dilute enough. You can pre cool the Shellac in the fridge and/or add some retarder if you have trouble brushing. Light coloured inlays need to be sealed prior to using any brushed Shellac. I simply go round with a cloth loaded Shellac as in the Milburn tutorial.
PostPosted: Fri Feb 08, 2013 3:48 pm
First time I sprayed shellac I had the same problem. Turns out I did not have the gun adjusted properly. Maybe try turning down the air pressure or increasing the material feed.
I use the 3M PPS cup system for my spraygun now and cleanup is simple and very fast.
