It is currently Sat Apr 25, 2026 7:48 am
PostPosted: Fri Dec 14, 2012 11:53 am
First name: Big
Last Name: Jim
I am bidding on this Martin Guitar Made usa 2002 000X1 Classical Per the info .. If I get this I will have $150.00 in it before neck reset . What should this be worth fixed ? Am I already at a cost to high ? If I am it will be mine .
PostPosted: Fri Dec 14, 2012 11:57 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Someone who knows what they are talking about will be along soon, but. . . is this one of those martin bolts-ons that sometimes come loose requiring a simple tightneing (rather than re-set)? maybe it is not even Martin I'm thining of, jsut ignore me. . .
Bryan Bear PMoMC
PostPosted: Fri Dec 14, 2012 12:00 pm
First name: Big
Last Name: Jim
from the looks of it I believe it will be a simple fix
PostPosted: Fri Dec 14, 2012 12:11 pm
Last Name: Waldsmith
City: Bark River
State: Mi
Zip/Postal Code: 49807
easiest neck reset you will ever do.... tighten bolt... done................. usually
PostPosted: Fri Dec 14, 2012 12:14 pm
First name: Big
Last Name: Jim
Whats this sucker worth on market ? ... ball park ?
PostPosted: Fri Dec 14, 2012 1:11 pm
That looks like one of the Martin formica guitars.
PostPosted: Fri Dec 14, 2012 1:19 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
After you're done playing Malaguena, you can eat your lunch on the back of it! ;)
Alex
PostPosted: Fri Dec 14, 2012 4:20 pm
City: chicagoland
State: illinois
i think brand new they were around $500USD...and $450 of that was for the paint on the headstock that says "Martin".....
PostPosted: Fri Dec 14, 2012 4:34 pm
First name: Big
Last Name: Jim
Model: 000X1
Construction: Mortise/Tenon Neck Joint
Body Size: 000-14 Fret
Top: Solid Sitka Spruce
Rosette: Multiple Black/White Boltaron with Red Fiber
Top Bracing Pattern: A-Frame ''X-1''
Top Braces: Solid Spruce 5/16''
Back Material: Mahogany Pattern HPL Textured Finish
Back Purfling: none
Side Material: Mahogany Pattern HPL Textured Finish
Endpiece: none
Endpiece Inlay: none
Binding: none
Top Inlay Style: none
Side Inlay: none
Back Inlay: none
Neck Material: Rust Stratabond
Neck Shape: Modified Low Oval
Nut Material: White Corian
Headstock: Solid/StandardTaper
Headplate: Mahogany Pattern HPL
Heelcap: none
Fingerboard Material: Black Richlite
Scale Length: 25.4''
Number of Frets Clear: 14
Number of Frets Total: 20
Fingerboard Width at Nut: 1-11/16''
Fingerboard Width at 12th Fret: 2-1/8''
Fingerboard Position Inlays: none
Fingerboard Binding: none
Finish Back & Sides: none
Finish Top: Hand Rubbed Finish
Finish Neck: none
Bridge Material: Black Richlite
Bridge Style: Belly
Bridge String Spacing: 2-1/8''
Saddle: 16'' Radius/Compensated/White Tusq
Tuning Machines: Chrome Enclosed w/ Small Buttons
Recommended Strings: Martin Studio Performance Light Phosphor Bronze (MSP4100)
Bridge & End Pins: White w/ Black Dots
Pickguard: Tortoise Color
PostPosted: Fri Dec 14, 2012 4:48 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Mahogany pattern HPL = Formica.
So has anyone done any sound comparisons of Formica vs. Plywood?
I'd guess maybe $150 on CL ?
Kevin Looker
I'm not a luthier.
PostPosted: Fri Dec 14, 2012 7:15 pm
City: Bark River
State: Mi
^^^^^I havent done REAL TESTING on formica vs plywood but i have definitely heard it... I had one of those dx-1's when they first came out sounded GREAT for about a year and a half, then the belly came in so bad you couldnt keep the bridge on without bolting it down..... that model only had a x brace and a thin laminate under the top. (probably why it sounded good) (bassy)
now days they are a more standard x brace pattern (most of em) and sound pretty close to a yamaha plywood guitar..... if not worse
PostPosted: Fri Dec 14, 2012 10:44 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I've heard cheap Chinese guitars that sounded way better than a Martin formica guitar. Played one and it sounded terrible. Even a baby Taylor sounded better.
Typhoon Guitars
PostPosted: Fri Dec 14, 2012 10:58 pm
First name: George
City: Seattle
Many Martin dealers will sell new guitars for 40% off list or "MAP" (Minimum Advertised Price). That means this could have been purchased new for around $300. Non-collectible used Martins in good to excellent condition typically garner around 50% of their street price. So, considering the condition, I think your bid of $150 is a bit on the high side. That's just my opinion.
George :-)
PostPosted: Sat Dec 15, 2012 8:10 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I agree, played all the Formica models at Martin last year. To my ear the smaller bodies sounded better than the large but all sounded very tin and hollow. I have done a few set ups on some of the cheap $129.99 guitars from musicians friend etc and if you can get the action to a decent place and work the nut a bit they actually don't sound all that bad. Especially if you take into account the ones I have seen appear to have been assembled with a hot glue gun.
Brian
PostPosted: Sat Dec 15, 2012 8:59 am
First name: Big
Last Name: Jim
Filling me fulla hope here guys .. :shock: laughing6-hehe . If I win this I will have $158.00 in it including shipping before repair ... May be to much , if so lesson learned . I am gonna see what happens and then if Im not happy with the sound to resell it " ( was thinking $250.00 or so ) " Then one of my family will get a present .
Either way , I chalk it up to a learning experience . I do appreciate the input guys , it gives me some basics to examine when / if it gets here . Thanks ! [:Y:]
PostPosted: Sat Dec 15, 2012 11:48 am
First name: Big
Last Name: Jim
Went to $150.00 , said id stop there and I was out bid . Well , hope the new owner Likes it ! idunno
PostPosted: Sat Dec 15, 2012 12:09 pm
First name: George
City: Seattle
As others have noted, these are not particularly highly regarded guitars. Fine for camping, Third World travel, Bering Sea crabbing, tornado chasing, space walks, etc., but not well-suited for your Sunday best. The numbers I listed above are pretty reliable and widely known among the Martin community, so I think you did well to lose the auction.
Again, just my opinion,
George :-)
PostPosted: Sat Dec 15, 2012 12:10 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
In Taiwan those guitars are overpriced. It sells for about 1,200 dollars here. And they still sound like crap. A Yamaha guitar 1/4 the price sounded better than that.
Typhoon Guitars
PostPosted: Sat Dec 15, 2012 12:16 pm
First name: Big
Last Name: Jim
True , but a young child getting a " Martin" guitar for a present would have been elated and possible motivated to learn to do something with it. Ahh well , water under the bridge now ... Again thanks for the Input guys , I might not always agree , but I DO appreciate Honesty ! [:Y:]
PostPosted: Sun Dec 16, 2012 1:23 pm
First name: Big
Last Name: Jim
The bid on that Guitar is Now at $265.00 ...... LOL
PostPosted: Sun Dec 16, 2012 1:27 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
People really go crazy over a "name".
Typhoon Guitars
PostPosted: Sun Dec 16, 2012 2:15 pm
Last Name: Howard
City: Magnolia
State: Delaware
laughing6-hehe
Pretty close to a barge guitar, yes indeed.
Brian
PostPosted: Sun Dec 16, 2012 2:38 pm
First name: Ringo
I once had a Martin dread with the plastic back and sides that sounded and played great. Go figure.
PostPosted: Sun Dec 16, 2012 5:11 pm
First name: Alex
Last Name: Kleon
City: Whitby
You'd think that if Martin were making guitars with counter top material back and sides, they'd at least make it look like Brazilian! laughing6-hehe
Alex
PostPosted: Sun Dec 16, 2012 5:18 pm
It's not the formica back and sides that hurt the sound and short term durability of the instruments, it's the other elements that go into making a "cheap" guitar. The Richlite bridge is the first thing I would look at as a tone killer. The thicknessing and bracing of the top would be the next place I would look. The Stratabond neck and Richlite finger board, although not aesthetically great, probably work O.K..
I have built a number of HPL back and sided instruments, and although I would not call them "world beaters" they have sounded fine.
We don't put expensive materials and the time and care into an instrument made for a lower price point. Why would we compare it to a fine hand made guitar?
Users browsing this forum: No registered users and 42 guests
