It is currently Sat Aug 16, 2025 7:05 pm
 Post subject: Fretboard Preparation
PostPosted: Wed Sep 12, 2012 2:30 pm
Last Name: Charnock
Country: UK
I have worked from a kit previously that had a fretboard ready slotted and cut to size.
I am about to make my first fretboard from a rosewood blank following Cumpiano's method in the book.
Is there anything I should look out for, any tips etc
My first bridge I have to cross is dealing with a neck blank that refuses to flatten out, it has a slight bow in it across the length of about 1.5mm, I am assuming planing it is not going to make the problem go away
J
PostPosted: Thu Sep 13, 2012 8:08 pm
First name: Stephen
Last Name: Williams
City: Leesburg
Go slow. Measure twice. Cut once.
I just did my first using Cumpiano's method, and it came out fine, in the end. I did have to fill and recut a slot, thus the advice above.
As far as the neck blank that won't go flat, it seems to me that you should be able to plane it out. The trick is the shim the blank so that it doesn't flatten out when you plane it. You have to make sure you preserve the bow, as you work it. Again, go slow and check your progress often with a straight edge.
PostPosted: Fri Sep 14, 2012 1:44 am
Last Name: Charnock
Country: UK
Thanks, I don't get the last bit about shimming. The book says use double sided tape to fix it ti the bench for planing. I have not tried it but I think this will take the bow out.
Are you saying the the bow is always present and therefore work with it?
PostPosted: Fri Sep 14, 2012 1:54 am
That won't take the bow out. With tape you will be probably forcing the board flat.
First you need to get one side of the board flat. You can do that by either shimming underneath with veneer or by deliberately planing it concave (shorter Plane) or convex (longer plane taking off more towards the ends). Once you have that one side flat then the other side is easy.
PostPosted: Thu Sep 27, 2012 10:16 am
Last Name: Charnock
Country: UK
Hi can you describe the shimming as I can't visualize it
PostPosted: Thu Sep 27, 2012 10:55 am
What they are saying is to place shims under the board where it is not flush with your bench top, ie where the light shines through. So that when you plane the board you don't just push it flat. I would first plane off the ends on the concave side so that you have one flat side then flip it over and plane out the hump. I would also suggest that the hump side is the side you want to glue the fret board to.
PostPosted: Thu Sep 27, 2012 11:02 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Pablo Picasso
PostPosted: Thu Sep 27, 2012 3:01 pm
Last Name: Charnock
Country: UK
PeterF wrote:
Great thanks I'll try it
Joh
Users browsing this forum: ptourin and 11 guests
