It is currently Sun Jun 22, 2025 11:21 pm
PostPosted: Tue Jul 31, 2012 6:03 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
So I am at the binding stage of the 3rd guitar, and for the first time, want to try mitering the end wedge purfling with the binding purfling. I have used Titebond or white glue for bindings in the past, but want plenty of open time to do this one. So I had planned to use fish glue. But I have also seen that some builders dry-fit everything and then wick CA glue in. The latter appeals to me because it gives unlimited time to get everything right. I am wondering about getting the binding tape off (I suppose any residue just scrapes off when you scrape the bindings). I'm also concerned about staining the spruce top....will a coat of shellac in the channels be sure to prevent that?
I welcome any thoughts or tips about doing the mitering, and your preference for glue-up of this kind of binding scheme.
Thanks, Beth
PostPosted: Tue Jul 31, 2012 6:11 pm
First name: Tony
Last Name: C
City: Brooklyn
Beth,
If you want the best of both worlds, tack just the mitered corners with CA, then glue the rest of the binding and purfling with your glue of choice. Also, I route my binding channels completely, then add the wedge with purfling, then cut to size. I find it easier than other methods, but that's just me.
It is annoying to have to scrape off the tape/ CA goop, but you are leveling the binding anyway, so it's not that bad. Hope that helps.
Tony
http://www.CostaGuitars.com
PMoMC
PostPosted: Tue Jul 31, 2012 7:16 pm
First name: Darryl
Last Name: Young
State: AR
I think a video would be appropriate.....any takers? <smile>
PostPosted: Tue Jul 31, 2012 10:30 pm
First name: Trevor
Last Name: Gore
City: Sydney
If you have any white wood in the mitred binding/purfling, don't use CA. It gives the effect of a dark glueline on the mitre, no matter how tight the joint. Titebond seems to disappear the best.
http://www.goreguitars.com.au
PostPosted: Tue Jul 31, 2012 10:53 pm
John Bogdanovich recommends leaving the actual miter without glue at all. He said it hides the line better than having glue in the joint. There is plenty of glue all around the line anyway.
PostPosted: Tue Jul 31, 2012 11:45 pm
I also get the miters perfect, hold witn clear packing tape, and tack down with thin CA. Do the rest with LMI white or Tightbond for wood or LMI FCA for ivoroid etc. Brown StewMac tape there. Shellac on the top.
I've only used fiber bwb miters. Trevor's advice on light colored wood purfling with CA is appreciated.
PostPosted: Wed Aug 01, 2012 5:48 am
Trevor's advice is indeed good, no CA glue on light colored woods, or you risk getting a black line at the miter. On a related note, when I use celluloid bindings, I "weld" the miters shut by gluing them up dry, and wick acetone into the joint. Duco or certain other solvent based glues will also also do this, but I find I get the cleanest results with straight acetone. This is especially important if you plan to dye the instrument before sealing it (as in, color the bare wood), as the dyes will seep into any open joint. So even if the miter looked fine in the white, unless the parts are indeed melted together, you may get a telltale line there after the colors are scraped scraped off the bindings. The acetone trick will not work unless the fit is very good to begin with, BTW.
PostPosted: Wed Aug 01, 2012 7:36 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
I've used Titebond, CA, and Fish glue. I like the fish glue best for binding. Titebond doesn't leave me a comfortable open time, CA makes a mess for me, and fish is just so easy to use, good open time and cleans up nicely.
Work carefully, and reference all of your work from the tail.
http://redrivercanoe.ca/
PostPosted: Wed Aug 01, 2012 10:52 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Great advise! Thanks to all who responded. Today's the day, at least for the top binding!
PostPosted: Wed Aug 01, 2012 4:18 pm
Last Name: Charnock
Country: UK
can someone explain mitered purfling to me ?
PostPosted: Wed Aug 01, 2012 4:53 pm
http://www.frets.com/FretsPages/General/Glossary/MiteredPurfling/mitered.html
PostPosted: Wed Aug 01, 2012 4:58 pm
Last Name: Charnock
Country: UK
I get it now
J
Users browsing this forum: DennisK and 62 guests
