It is currently Mon Jul 28, 2025 9:33 am
PostPosted: Thu Jul 19, 2012 7:16 pm
City: Alton
State: IL
I'm pretty much sure the solution to this is saw down the crack and glue. But for the second crack thats not all the way through, are there any other suggetions? This was caused by the back being over the edge of my work bench, and dropping my #5 plane on it. oops_sign (at least plane landed on my newly placed anti-fatigue instead the bare concret floor. I just shappened the blade. Bridge side right?)
PostPosted: Thu Jul 19, 2012 7:19 pm
I would mark either side of the line with a white pencil, clamp the edges to close the crack tightly and then wick thin CA into it.
PostPosted: Thu Jul 19, 2012 9:22 pm
City: Alton
State: IL
Filippo Morelli wrote:
Is it in the pattern?
Filippo
Right smack in the middle. I just finished shooting that edge and am getting ready to glue. I can't true up the other edge and join it with out making a smaller guitar.
PostPosted: Thu Jul 19, 2012 9:25 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
what Charlie said!!!
MK5acoustics.com
PostPosted: Thu Jul 19, 2012 9:28 pm
If that is walnut you won't want to use CA. The CA will show , here is a perfect candidate for Hot Hide Glue. You can make it as good as new. Hot Hide will wick into cracks and fibers making a good repair. With this being a force crack you should also be able to clamp this closed simple enough.
PostPosted: Thu Jul 19, 2012 10:03 pm
First name: Tony
Last Name: C
City: Brooklyn
I don't know about plain walnut but u have used CA on figured Clark to fix a crack I caused and it's invisible before and after finish.
http://www.CostaGuitars.com
PMoMC
PostPosted: Thu Jul 19, 2012 10:13 pm
City: Alton
State: IL
It is walnut. Guess I'll order some Hot hide glue next payday. Thanks for the tips everyone.
PostPosted: Fri Jul 20, 2012 8:19 am
State: Tennessee
I use HHG for just about everything but Titebond will work just fine for this.
PostPosted: Fri Jul 20, 2012 3:57 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
If St. Louis (South County, just across the JB bridge) isn't too far you could stop by my shop some time this weekend and we can mix up some hot hide glue.
BB
Bryan Bear PMoMC
PostPosted: Mon Jul 23, 2012 9:59 am
City: Alton
State: IL
BB
I may have to take you up on that. When you say "shop", do you mean your work shop, or do you operate a store?
I wicked in some tight bound this weekend. It looks to have resolved that issue. Now I'm fighting my $25 smoothing plane. [headinwall] But that is a story for another time.
PostPosted: Mon Jul 23, 2012 10:15 am
How do you wick in Titebond? If you did what I'm thinking I'd be concerned about that.
PostPosted: Mon Jul 23, 2012 12:20 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Evilfrog wrote:
BB
No, just my basement workshop. I'm not a pro (not even close) but I have HHG and dind't want you to have to wait until you were able to order some, when you could just pop in and glue it. Sounds like you already took care of it though. . .
Bryan Bear PMoMC
PostPosted: Mon Jul 23, 2012 1:49 pm
You can dilute Titebond but looking at those pics and having done this several times before you just rub the Titebond in as is while flexing a little bit then wedge it tight.
That's no biggie at all.
PostPosted: Mon Jul 23, 2012 10:34 pm
fair enough.
Users browsing this forum: Ken Lewis and 10 guests
