It is currently Sun May 17, 2026 11:44 am
PostPosted: Mon Jun 27, 2011 7:45 am
Country: Romania
I ordered a couple tops recently (not here yet) and while reading about the stuff, it seems to pop out often that it splits easily. How easily is that in fact? I build classicals...a dense top can end up at 0.08 in thickness, and I also use a very pronounced dome, of about 15' or so. I hope it is not going to split when gluing the braces! eek
Build log
PostPosted: Mon Jun 27, 2011 8:11 am
It tends to split when flexing cross grain .. long grain is fine ... handle gently, it will brace up fine, and then you are good to go.
PostPosted: Mon Jun 27, 2011 8:24 am
First name: Edzard
Last Name: Kolks
City: Eindhoven
Country: The Netherlands
Hello Alexandru,
I ordered 5 pieces. When they arrived I took one out for flexing it (only a little bit) and it broke in two pieces.
After a while I used one for a steelstring. Got the rosette in, then glued the purflings around it with CA. I sealed everything (twice) with shellac. Stains everywhere.Through the top away.
Yesterday I took the third piece, put in a (very nice burl) rosette. Glued it with Fish glue. No stains.
Then to the saw, during sawing I slipped and fel with my elbow on the top...it broke in two.
Maybe someone up there is trying to tell me not to use redwood...
Best regards,
Edzard
PostPosted: Mon Jun 27, 2011 9:28 am
Country: Romania
Thanks everyone. Edzard, if that is any consolation, I suppose even the hardest spruce would have split after an elbow impact.
Well seems I need to keep my fingers crossed! I'll see how they pass the offcut test. For every top I saw off about an inch of endgrain and split in many pieces. Helps finding weak grains and getting the "feel of the wood"
Build log
PostPosted: Mon Jun 27, 2011 12:04 pm
I too have been afraid of splitting Redwood, because it IS fragile, but the instruments that I've used it on, once together, have been fine after many years, and the tone is worth it.
PostPosted: Mon Jun 27, 2011 12:15 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
I've ruined a couple of sinker redwood sets by taking them too thin. As the others have said, it's not so strong across the grain. You will not be able to get your top anywhere near 0.08" IMO. I would stop at 0.115" and brace appropriately. YMMV. Good luck!
Dave F.
Cambrian Guitars
PostPosted: Mon Jun 27, 2011 1:03 pm
Country: Romania
Thanks guys. I am going to try the thickest top/lightest bracing scheme I can come with, although something like 0.115 might be way too heavy. Will see how the actual top behaves. Factoring in the guitar size, I would say a 0.08-0.085 classical spruce top is about the same as a .105-.11 Dread top.
Build log
PostPosted: Sat Jul 02, 2011 1:08 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I don't have much Redwood, and have only built with it twice, but I believe it's alot stronger/stable/less likely to split if it's prefectly quartered. I (think I) read somewhere that it's more prone to split if it isn't dried correctly.........maybe dried too fast????
PostPosted: Sat Jul 02, 2011 1:39 pm
Country: Romania
I ordered from Rick, and they seem to be pretty well quartered, as there is long silk visible in the photos here and there. I should have them in a week or so and I will return with a report.
Build log
PostPosted: Sat Jul 02, 2011 4:57 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
sorry for the (dumb?) question, but what is sinker redwood? redwook that has been sank?
thanks,
miguel.
PostPosted: Sat Jul 02, 2011 5:13 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
thanks for the detailed (and quick!) reply Filippo. so it just happened by chance that some logs sank? here (portugal, EU) some loggers keep their wood for some years in rivers (mainly white oak, i believe), saying that it turns the wood "better" (which i translated at the time as "stronger" or "more durable"), but i thought it could be just a case of wishful thinking. do you know if this is done with other woods (that is, woods used in guitar making)?
thanks,
miguel.
PostPosted: Sat Jul 02, 2011 8:21 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
There is quite an industry of reclaiming logs that were floated to mills. Many are not only on the bottom of rivers, but sunk in mud where the rivers have changed their direction over the years. Old growth pine that has been reclaimed is much saught after. I would think that there must be sitka spruce reclaimed the same way in British Columbia as well. Maybe someone else knows for sure.
Alex
PostPosted: Tue Jul 19, 2011 9:17 am
Country: Romania
I just got my two soundboards. It doesn't really seem much worse than WRC in terms of hardness and splitting. On the other hand they are quite very heavy, one at 450Kg/m3 (7.37 grams/cubic inch) the other 490 (8grams). The 450 is also stiffer. Both are well quartered, with lots of silk. The heavy one has the rings so tight you can't count them.
I am thinking I could make an all-redwood guitar and use the heavy piece for the back, if I could get some long stock for sides somewhere. Hmmm.
Build log
PostPosted: Tue Jul 19, 2011 9:35 am
First name: Miguel
Last Name: Bernardo
Country: portugal
Hi Alexandru, could you tell me where you got the tops from? and how do they tap? it looks nice...
cheers,
(a curious) miguel.
PostPosted: Tue Jul 19, 2011 10:24 am
What Tony said!
I had a top 1/2 split on flexing it cross grain just as Tony says.
PostPosted: Tue Jul 19, 2011 11:49 am
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
Or you could get some rosewood sides and try out a kasha style like this Boaz/Majkowski [:Y:]
http://www.dreamguitars.com/detail/1739-boaz_majkowski_kashaschneider_concert_guitar_lisa_5/
PostPosted: Tue Jul 19, 2011 12:50 pm
Country: Romania
Miguel,
From here: http://www.luthierscooltools.com/Sinker_Gallery.htm
The tap tone is very nice, low damping and resonant like WRC, but a bit more restrained, and I suppose this is because of the weight. Because of the same weight, I would not recommend this stuff for a classical, unless you ask them to pick one which is noticeably light (and wide grained maybe). I picked a couple based on looks (uniform enough) and were not too big and pricey...
Oval,
Thanks! Rosewood might be. In fact I used a lighter brown orangeish type of Madagascar rw before that might work just fine. Perhaps bending sinker or redwood in general is not a great idea, not to mention later issues because of the fragility...
Build log
PostPosted: Tue Jul 19, 2011 1:02 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
thanks for the info! i wish you good luck with your future sinker endeavours!
edit: BTW, that kasha looks awesome, but i imagine - even considering mr. Heumiller remarks - that it should be difficult to play in the eupper frets... i mean, those are really up!
Users browsing this forum: Kbore and 60 guests
