It is currently Fri Aug 08, 2025 12:44 am
PostPosted: Thu Mar 04, 2010 3:17 pm
First name: Arnie
State: Oregon
Zip/Postal Code: 97814
Likey?
No Likey?
Construction issues?
Structural strength issues?
Can it be done retroactively, i.e., on a used guitar?
Tell me why or why not. I picked up a guitar with a monitor hole and thought I wouldn't like it.....but it sure seemed to allow me to hear the sound much better. My ears aren't what they used to be either....... :?
I'm thinking of someday taking this on. Just for kicks and grins.
I've noticed you folks can be somewhat opinionated. laughing6-hehe You have the floor. beehive
Arnie
PostPosted: Thu Mar 04, 2010 3:24 pm
I've never played a guitar with one, but you might have better luck searching for "sound port."
PostPosted: Thu Mar 04, 2010 3:31 pm
First name: Arnie
State: Oregon
Whoops! Is that what they're called? It seems that "sound port" would be indistinguishable from "sound hole", but what do I know? idunno laughing6-hehe
PostPosted: Thu Mar 04, 2010 11:16 pm
First name: Arnie
State: Oregon
Well.......it's either a boring topic or a to-hot-to-handle topic. I thought there would be a few more opinions than this. [uncle]
PostPosted: Fri Mar 05, 2010 2:19 am
First name: Jim
Last Name: Hansen
EOArnie wrote:
Likey?
No Likey?
Arnie
Arnie,
Sound Port is the term I've most commonly seen used for these.
I've never retrofitted a guitar with one, but I know people have done it succussfully. Search around here and other forums and I'm sure you'll find something. Please don't take this as an endorsement to do it (i'd not recommend modifying a guitar in this way).
That said, I have them on both of the guitars I've built. It's not difficult to do. Just use your imagination.
1. Pick a spot
2. Pick a shape
3. Reinforce the inside of the spot with a laminate of some kind
4. Make a pretty hole
5. Profit! :)
Here are some pictures of the one on my concert.
This is just a simple oval hole near the peak of the upper bought, about the size of an egg. The laminate on the inside is a thin piece of maple and a cutoff from the EIR sides. Gives it a little character and will sufficiently reinforce the side to prevent cracks/splits.. I just tapered the lip a bit to accentuate the highlight a bit.
I'm not even going to touch the question about their affect on the sound of the instrument. beehive
I will say definitively that sound definitely comes out of the sound port when I play it. 8-) I will also say that I like having it there. It looks cool, and I like how it sounds. :D
YMMV
Jim Hansen
PostPosted: Fri Mar 05, 2010 5:48 am
First name: Arnie
State: Oregon
Thanks Jim......excellent insight, and beautiful work.
However, I'm somewhat surprised that you laminated the area for strength purposes. I'm not saying you're wrong. It just seems that at that particular area of the bend, there is a fair amount of inherent strength. idunno
PostPosted: Fri Mar 05, 2010 5:58 am
Seems to me with a soundport about half the width of the side is removed, and, if there was no reinforcement, unsupported end grain is exposed and liable to crack when the sides flex, both when strung up and with humidity changes.
This might well significantly wow7-eyes weaken the side.
PostPosted: Fri Mar 05, 2010 11:46 am
EOArnie wrote:
"However, I'm somewhat surprised that you laminated the area for strength purposes. "
You've never had to fix a side crack, have you?
I think 'monitor hole' is probably a good name for the thing, since that's what it does, but by now 'side port' is the accepted term.
I like to make the 'main' soundhole smaller when I put in a port, but that's my opinion.
PostPosted: Fri Mar 05, 2010 1:08 pm
City: winnipeg
State: manitoba
Country: canada
Alan:
The backing has the grain at 90* to the grain in the side and is more to protect against splitting at the exposed end-grain rather than for strength. That is the explanation usually used on ukuleles.
Bob
PostPosted: Fri Mar 05, 2010 2:50 pm
First name: Jim
Last Name: Hansen
"Strength" isn't the word I used. I used "Reinforce"... I think cracking/splitting is the primary concern.
Jim Hansen
PostPosted: Fri Mar 05, 2010 5:49 pm
Another take ... port mimics the ribrest shape ...
PostPosted: Sat Mar 06, 2010 11:06 am
First name: Arnie
State: Oregon
Gotcha. Makes sense.
I have to say though.....
I thought there would be a little more reaction from the purist camp. beehive
Maybe it is more of an accepted practice than I thought. :?:
