It is currently Sun Jul 27, 2025 3:36 pm
PostPosted: Wed Mar 18, 2009 2:02 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Well, I've searched the archives and also the tutorial section and can't find anything on making a jig to slot the saddle in a bridge. I know it's here somewhere. Could anyone help?
Or show photos of what you use for this process. I'm think I'm going to use a PC 310 and a 3/32" carbide downcut bit. I have a jig in mind, but would like to see how ya'll do it.
Thanks for the help
Hutch
PostPosted: Wed Mar 18, 2009 2:41 pm
Hutch buddy, I posted this same question just last year. You can find the discussion here
After that, this is the jig I made.
The small block where the bridge goes is just there so I don't loose the wedge.
Hope this helps.
PostPosted: Wed Mar 18, 2009 3:06 pm
Here's mine with the bridge in it.
PostPosted: Wed Mar 18, 2009 3:08 pm
Mine's mostly for redoing saddle slots on the guitar, but works fine with a new bridge dblsticktaped to a surface, too. The router is a Bosch Colt w/clear subbase; part of the metal base has been cut away, since I took these photos, to see the work better
The second photo is the "target plate", set for 1/4" & 1/8" bits. I use endmills, recently got a 3/32"
one that I like; I bushed it up to 1/4" with telescoping brass hobby tubing, slit so that it will compress.
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
PostPosted: Wed Mar 18, 2009 5:46 pm
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
Here's my saddle mill in use.
For new builds, I cut slots with my milling machine.
- Louis Freilicher
PostPosted: Wed Mar 18, 2009 7:41 pm
Louis, how do you line that sucker up? I'm curious on the 'cut after install' method and your mill looks very cool.
PostPosted: Wed Mar 18, 2009 8:58 pm
Mine's in the tutorial section, Pinless Bridge...
But here's a pic in case you only have dial up.
PostPosted: Wed Mar 18, 2009 10:50 pm
My old jig used to be up on the jig and fixture page but I see that page doesn't seem to work any longer.
PostPosted: Wed Mar 18, 2009 10:58 pm
First name: Chuck
City: Houston
Rod, thanks for pointing me in the right direction in the Search for the thread.
And thanks to everyone for posting these photos. This gives me more to work with.
John How, I really do miss the "Tutorial Section". Wish there was some way to get them working again.
You guys are a real time saver. THANK YOU!
PostPosted: Thu Mar 19, 2009 6:01 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Is this the section you're talking about or am I missing something.
http://www.luthiersforum.com/forum/viewforum.php?f=10117
PostPosted: Thu Mar 19, 2009 6:47 am
Here's a jig John How made that I borrowed from Lance Kragenbrink at the ASIA symposium in MD. This was built with the PC 7310 for the laminate trimmer
PostPosted: Thu Mar 19, 2009 8:11 am
Just to note: You can save yourself the cost of dilling bushings by using a plunge router with a collar bushings.
PostPosted: Thu Mar 19, 2009 10:47 am
First name: Louis
City: Belchertown
State: MA
Rod,
I line the mill up by eye. After marking the saddle mid point and ends of the slot, I loosely clamp the mill to the guitar and tap it in. It sounds more difficult that it is really. You can just make out my marks in this after shot.
I really like this method for replacement bridges where duplicating the bridge outline, pin holes and saddle slot can be a case of too many variables at once.
Louis
- Louis Freilicher
PostPosted: Mon Mar 30, 2009 8:57 am
Finally got a chance to upload a few pics of mine. Note the combination of angles of the table the bridge sits on, to give the compensation angle and a 10 deg back tilt to the saddle. The small bar clamps on the front are just added insurance that the top part won't move while routing.
Todd Rose
Ithaca, NY
PostPosted: Mon Mar 30, 2009 9:19 am
First name: Chuck
City: Houston
Nice pictures Todd.
Could you give some measurements on the slanted board that gives the angle for the slot?
I had something like this in mind but just can't get my head wrapped around how to make it.
Hutch
PostPosted: Mon Mar 30, 2009 10:40 am
The table that the bridge sits on is supported by three wedge-shaped pieces of plywood, cut to a 10 deg angle. The front edge of the table, which the fence (that the front edge of the bridge rests against) is glued to, is cut at the compensation angle of the saddle. If I remember right, I used a taper cutting jig on the table saw to make that cut. In cross section, that cut is square, so that the fence is square, vertically, to the surface of the table. The fence has a 10 deg angle cut on its bottom edge, so that it sits flat on the base underneath.
The top part, which the router rides on, can be shifted forward or backward, or set at a slightly different angle if I want to vary the compensation angle. Varying the compensation angle will cause the saddle slot to be slightly deeper at one end than the other, but not by much, and that doesn't really matter anyway.
This jig allows a lot flexibility in the size of the bridge and the position and length (and depth, of course) of the saddle slot. The only thing that is really set in stone is the 10 deg back tilt. The shape of the bridge is also obviously infinitely variable, since the slot is cut while it's still a rectangular chunk of wood.
Have I answered all your questions?
Todd Rose
Ithaca, NY
Users browsing this forum: Glen H, kyle.medeiros and 13 guests
