It is currently Wed Aug 20, 2025 12:41 am
PostPosted: Tue Feb 04, 2014 2:09 pm
First name: Big
Last Name: Jim
Have a young Man who has brought me a Gibson J35 Acoustic Electric ... The Neck Is Twisted , and he says getting worse . I called Gibson , they wont sell me a Replacement neck . Any Suggestions ?
 Post subject: Re: Gibson J35
PostPosted: Tue Feb 04, 2014 2:18 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Make a better one! bliss
PostPosted: Tue Feb 04, 2014 2:30 pm
First name: Big
Last Name: Jim
Have to try and save Gibson Logo and if that doesnt work then what .
PostPosted: Tue Feb 04, 2014 2:36 pm
First name: Zeke
Last Name: McKee
Can you remove the entire front of the headstock and glue it on as the faceplate on a new neck?
PostPosted: Tue Feb 04, 2014 2:38 pm
First name: Big
Last Name: Jim
Yeah probably . Was hoping for other options to avoid building a neck
First name: Zeke
Last Name: McKee
I'm sure someone else has a better way to address the twisting. I'm just throwing out ideas.
These users thanked the author ZekeM for the post: WudWerkr (Tue Feb 04, 2014 2:42 pm)
PostPosted: Tue Feb 04, 2014 3:34 pm
Last Name: Tulloch
State: Vermont
You can play around with heat treatment. For the cost of pulling, making , installing and setting up a new neck.....he could just buy a new one for that. Apparently he's not the original owner.
PostPosted: Tue Feb 04, 2014 3:43 pm
First name: Big
Last Name: Jim
Bought it second hand ... Has less than $400.00 in guitar as is
PostPosted: Wed Feb 05, 2014 9:26 am
Do something like this:
http://www.bestbassgear.com/ebass/repai ... esign.html
Just because the neck is twisted doesn't mean the guitar has to be unplayable. Just fix the string paths. bliss
PostPosted: Wed Feb 05, 2014 9:38 am
If you want to preserve the originality of the instrument as much as possible, remove the fingerboard, plane the neck true, and re-install the fingerboard. I believe I saw something like that on Frank Ford's website. At that time you could also install neck reinforcement if you think it necessary.
Joe
PostPosted: Wed Feb 05, 2014 9:43 am
First name: Big
Last Name: Jim
Joe
I have suggested this , The fella says its getting worse . I have to verify that , but if it is this would be only a Temp fix . idunno
PostPosted: Thu Feb 06, 2014 3:05 pm
First name: Big
Last Name: Jim
Update , Looking down the neck from head stock , it does appear to have a slight twist . HOWEVER , when I did some checking with Parallel's its not twisted . The Bridge on the J35 is an angled bridge and the Saddle has been ground down on an angle as well " not factory " the whole thing creates an optical illusion . oops_sign
Because someone messed with the bridge the action above fret at 1st string is .040 and at 6th is . 058 and he wonders why it buzzes ... Also , whoever messed with it before loosened the truss rod nut to the point it was about to fall off ..... gaah New Saddle ordered ... Reset to proper string height and a little truss rod action and it should be in excellent shape. [:Y:]
Btw , where he had it worked on before was a "Reputable " Guitar store ... Sad
PostPosted: Thu Feb 06, 2014 3:15 pm
First name: duh
Last Name: Padma
. [headinwall]
PostPosted: Thu Feb 06, 2014 3:16 pm
First name: duh
Last Name: Padma
Loose nut eh! Could say sumptin...but ....
PostPosted: Thu Feb 06, 2014 3:18 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
You can say that again!
Alex
PostPosted: Thu Feb 06, 2014 3:27 pm
First name: Zeke
Last Name: McKee
Aahhhhh nuts!!!!Image
PostPosted: Thu Feb 06, 2014 5:16 pm
First name: Big
Last Name: Jim
Alex
When I realized the whole situation , I kinda felt like the " Loose Nut" duh
PostPosted: Mon Feb 10, 2014 9:20 am
First name: Big
Last Name: Jim
http://www.facebook.com/photo.php?v=422 ... =2&theater
Repair done , Another satisfied customer [:Y:]
PostPosted: Tue Feb 11, 2014 8:51 am
Last Name: Tulloch
State: Vermont
It's great he brought it to you. Well done Wud.!
