It is currently Thu Aug 21, 2025 12:28 am
 Post subject: Bubinga/Safe T Planer
PostPosted: Fri Sep 06, 2013 6:18 am
This stuff is tough to work!
After the last time thicknessing Bubinga, I set up my safe-t-planer and table to roughly thickness sides and back before finishing with my 10-20 (I had to use 36/60/80/100 grit last time, and go real slow)
The planer/table is properly set up as per all the guides I could find, about 1/1.5 thou thou lower at the feed side of the table (left) and level on consecutive passes, using hold downs.
It works works well with mahogany test pieces (with shower curtains of course!), and cutters are sharp.
But when I feed the Bubinga (sides at the moment, light cuts, about 0.2/0.3 mm) in it tends to "grab" the wood and pull it in "jerks", and I have to hold it back rather than feed it in like with the mahogany.
I checked with a run on the mahogany again after the bubinga - fine.
Does anyone have any suggestions or observations or is it just this typical of tough, figured wood?
PostPosted: Fri Sep 06, 2013 6:36 am
I have a "real" planer (straight bladed, not spiral) but I'm worried about chip-out in such figured wood.
And you're sure right there, it isn't mahogany!!
PostPosted: Fri Sep 06, 2013 6:56 am
Thank's the next thing I think - it's virtually new, just test runs, but better it sharpen myself.
PostPosted: Fri Sep 06, 2013 8:16 am
Are you talking about honing the inside or outside edge?
The instructions say not to hone the burr off? I did have reservations about this... maybe this was to prevent people rounding over the cutting edge on the outside.
Any advice welcome, I've not used this tool before in earnest.
My drill press vice is broke, so I've ordered another one as it seems the best way to do it.
I have a couple of the planers, both originals.
Wanted spare cutters, but of course. out of production. Was lucky enough to get a second new and complete. (Thanks again CS)
Virtually no milling marks with the hog at the moment (unlike the bubinga). Looks like a quick sand would finish it off.
PostPosted: Fri Sep 06, 2013 8:31 am
Colin, I have planed (using a standard straight blade planer) figured bubinga multiple times. Of course you must be gentile (small increments) and you may get very small tear-outs. But if you stop a little proud of 1/8", and let your drum sander take care of the rest, those tear-out marks will disappear with the sanding.
Regarding the Safe-T-planer, I've said it before and I'll say it again: there is nothing safety about this tool.
Alain Moisan
(Now building just for fun!)
PostPosted: Fri Sep 06, 2013 8:44 am
I may try that on my next set of (thickest) sides.
But unfortunately I only have a 6" planer so it's the backs that are my problem.
Some of them are almost thick enough for fretboards!
BTW, I agree wholeheartedly with your observation about the "Safe" part, it requires a good deal of care in use. :shock:
PostPosted: Fri Sep 06, 2013 9:44 am
Couldn't agree more. One of the most dangerous tools I've come across in my 25 years of woodworking. Up there with the Lancelot...
Ken Jones
Mountain Song Guitars
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Fri Sep 06, 2013 11:37 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
I've never used a safety planer, but I do have a normal planer in my shop.
With figured wood, I still prefer to thin it on the drum sander. I use 60 grit, high feed rate and VERY light cuts (~.01" or less) down to final thickness + about .05". Then I switch to 120 to 180 grit for the last few passes. I don't see any real advantage in working through the grits on the drum sander, 4 or 5 passes with the finer grit gets rid of the courser grit scratches, MUCH less work than skipping grits when hand sanding.
PostPosted: Fri Sep 06, 2013 4:21 pm
'Safe' applied to any power tool is, of course, stretching things a bit. Still, comparing a properly set up Safety planer to a Lancelot seems about as much a stretch in the other direction. I will say, though, that the second Safety planer I bought was not as well made as the first, and this lead to problems in use: you may have gotten one of that generation. Those improve a lot with a good tune-up.
I've always found having the table perfectly level to work best. Also, I take a very narrow pass the first time through, so that the cutters are not crossing the surface too much as they come off the edge: a 3-5mm pass is plenty. Subsequent passes are half the width of the tool, and no more: I don't want it cutting at all on the side that's pulling away from me. That's asking for trouble with any power tool.
I don't hone the edges at all; just use them off the wheel. You must get the edges aligned correctly, which sets the depth of cut of all three cutters to be the same. That's the most important thing (aside from sharp, of course). Having the cutters at even slightly different depths can cause it to grab things and throw them, and that was the problem I had with the 'new' one I bought. It turned out that neithe the cutters themselves nor the pockets they went in on the tool were really flat, so they would not hold a setting. A bit of lapping and scraping fixed it.
These users thanked the author Alan Carruth for the post: Colin North (Sun Sep 08, 2013 3:39 am)
PostPosted: Fri Sep 06, 2013 4:46 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Alain Moisan wrote:
I have planed (using a standard straight blade planer) figured bubinga multiple times. Of course you must be gentile ...
Oy vey , already ...
PostPosted: Fri Sep 06, 2013 8:09 pm
Alain Moisan
PostPosted: Fri Sep 06, 2013 8:19 pm
Last Name: calkin
City: greenville
State: va
Zip/Postal Code: 24440
If you haven't watched Robbie O'Brian's Luth du Jour about the safety planer, you should. Its on the LMI site, and probably others.
PostPosted: Sat Sep 07, 2013 1:02 am
Alain Moisan wrote:
Don't worry. Never mind the quality, feel the width.
PostPosted: Sat Sep 07, 2013 3:14 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Thank you, Colin ...even if only one person gets it, it's not a total waste of space ...
PostPosted: Sun Sep 08, 2013 3:50 am
Alan Carruth wrote:
'Safe' applied to .............................
.........................................of lapping and scraping fixed it.
Alan, took me a bit time (I can be dense) but that makes perfect sense, and explains my problem with the tougher wood (and the small blowout I had)
I'll do that - at the moment I have a fold-back fence to allow max size passes (2 each side give about 9 inches).
I got greedy and it doesn't pay!!
I'll check out the tools as well for set-up and sharpen the cutters.
PostPosted: Tue Sep 10, 2013 12:18 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
First time I had a Safe T Planer I planed bubinga with it... it wasn't bad, no grabbing or anything. Second time I bought it (the one I have now) grabbed pretty much everything it cuts, be it ebony or whatever. The only thing it didn't grab was mahogany. Then I sharpened the cutter as per the instruction... big difference. Now I can plane bridge blanks free handed.
Does anyone know where I can get replacement cutters? I mean what do I do once I run out of steel to sharpen? Also how do I set the cutter? I notice a mark on the planer itself and I always match the tip to that... but I wonder if there's a better way to do it. If someone made carbide cutter for this it would be great.
Typhoon Guitars
PostPosted: Tue Sep 10, 2013 12:22 pm
Yeah, set the tip of the cutter to the line. The company that made the planner took it out of production so it is likely that replacement cutters are unavailable.
PostPosted: Tue Sep 10, 2013 12:28 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So what happens then? Will anyone else pick up production of this or will cheap knock off cutters work?
Typhoon Guitars
PostPosted: Tue Sep 10, 2013 1:54 pm
No and no.
PostPosted: Wed Sep 11, 2013 10:18 am
My thanks to Alan and Todd.
My sides are down to 2.5 mm with the Safe T Planer, the 10-20 will do the rest.
Sharpened and honed the cutters, and only took half width cuts each time, went pretty smooth.
Still got a little blow-out (2-3 mm) at the edges despite taking only 3/4mm cuts first, but I have enough spare width anyway.
Next time I may try beveling the edges, see if that helps
PostPosted: Wed Sep 11, 2013 10:28 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So what do with the safe T Planer when I sharpen the cutters to the point that it no longer has enough steel? I hate for it to become junk just because it's missing a little part...
Typhoon Guitars
PostPosted: Wed Sep 11, 2013 12:02 pm
I guess you will have to resort to hand planing.
PostPosted: Wed Sep 11, 2013 1:13 pm
My Safety planer gets a lot of use, both by me and by my students. A set of cutters lasts me about 12-15 years, as near as I can tell. You might be able to find some replacements on E-bay before yours get used up. I bought a spare set from Grizzly when I heard the company had gone out of business, and still have five or six years left in the cutters on the tool, so I figure I'm good for another 20 years or so. By then I'll be almost 85, and may well not be making as many guitars or teaching as much.
There is another company making a similar tool.
PostPosted: Wed Sep 11, 2013 1:22 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
However their cutters don't fit Wagner's tool...
I'm even wondering why don't anyone produce replacement cutters for the tool? It doesn't look all that complicated to machine. In fact I'm even wondering about carbide cutters for this tool that would make the cutters last even longer...
Typhoon Guitars
PostPosted: Wed Sep 11, 2013 5:31 pm
Paperweight.
