It is currently Fri Jul 25, 2025 5:18 am
 Post subject: Preval sprayer
PostPosted: Wed Aug 31, 2011 11:54 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Saw one at the auto shop this morning . Was thinking of spraying small amount of water based poly on uke .If it worked could use it for touchups. What has been your experience??
 Post subject: Re: Preval sprayer
PostPosted: Wed Aug 31, 2011 12:20 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I tried it with KTM-SV and I got bad results, a splattered inconstant coat. I did not try using it very long, so I cannot say it can not be made to work.
PostPosted: Wed Aug 31, 2011 12:29 pm
Yeah, hard to get an even coat. But I did manage to successfully finish over a dozen guitars with them before I snapped and got an HVLP. Might not be too bad for a uke...
PostPosted: Wed Aug 31, 2011 6:24 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
They don't seem to like water based coatings. Work great with lacquers and shellac. I have used them for years for cabinet touch-ups in the field with good results. Will even do high solids varnish if you know how to thin the material out so it will spray without sagging.
Brian
PostPosted: Wed Aug 31, 2011 10:26 pm
First name: David
Last Name: LaPlante
I just used one quite successfully to spot finish and overspray an old Martin neck.
As per above I used nitrocellulose lacquer.
PostPosted: Wed Aug 31, 2011 10:53 pm
I know many have used them successfully, but my experience quite a few years ago was not good. They tend to spit and don't atomize very well. Granted I didn't try it many times before I broke down and bought a spray unit. This was using nitro.
PostPosted: Thu Sep 01, 2011 2:55 am
The web site suggests that for water based paints and acrylics, thin at a 3:2 ratio.
Old growth, shmold growth!
Users browsing this forum: ballbanjos and 15 guests
