It is currently Tue Jul 22, 2025 6:57 am
PostPosted: Tue Apr 01, 2025 3:34 pm
Last Name: Curran
City: Pietrasanta
State: Lucca
Zip/Postal Code: 55045
Country: Italy
Would anyone be willing to cast an opinion on my bracing?
I'm building a 4 string bass guitar. The body shape is an OOO 12. The scale length is 28.6", and the total string tension will be very similar to a 6 string.
The top of the X is 13.5mm high. Then straight line down to 8mm, 75mm from the rim, then down to paper thin at the rim. The upper X arms will be inlet into the sides.
I've built a couple of archtops, and a flattop with a floating bridge, but this is my first flat top with a glued bridge.
I get the impression most people seem to think free plate resonances doesn't say much of any use, but it's 258hz....
I originally decided to do a tapered X brace because I thought it would be easier to add a scallop later, once strung up, if it was obviously necessary. But now I'm having doubts and thinking I should scallop a bit now....
Please feel free to throw mud, I can take it! But obviously, given it's a bass I want to try to make it as flexible as possible. The top is european spruce, 2.7mm.
Thanks!
These users thanked the author Honza for the post: Kbore (Fri Apr 04, 2025 4:30 pm)
PostPosted: Tue Apr 01, 2025 5:57 pm
Beautifully crafted John, great work.
These users thanked the author Hesh for the post: Kbore (Fri Apr 04, 2025 4:30 pm)
PostPosted: Tue Apr 01, 2025 6:27 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Very clean work, John. It looks good to me. I often see photos of top braces that look a good deal heftier than needed, IMO. Yours don't look like that to me.
Do you plan to reinforce the x-brace joint?
I do have a question for other OLFers. Is there a consensus on whether or not to taper the upper x-brace arms? I don't because that's how I was taught, and it makes sense to me to keep the upper arms full strength because that's the area of the top that wants to fold in under string tension.
These users thanked the author J De Rocher for the post: Kbore (Fri Apr 04, 2025 4:30 pm)
PostPosted: Tue Apr 01, 2025 7:56 pm
I taper the upper X arms but only because that is the way I was taught.
These users thanked the author SteveSmith for the post: J De Rocher (Tue Apr 01, 2025 8:06 pm)
PostPosted: Tue Apr 01, 2025 9:36 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
Just curious! No sound hole reinforcement? No bridge plate? Or maybe this hasn’t been installed yet?
Your bracing looks quite nice, very clean work.
PostPosted: Wed Apr 02, 2025 12:48 am
Last Name: Kincheloe
I'd add some soundhole braces. It will probably dip there due to the long distance between upper X legs and upper transverse brace.
The lower X legs could probably use some more carving, but you could wait until it's strung up and do that through the soundhole so you can hear the difference and measure the effect on bridge rotation.
Same. I only carve them down in the last inch or two before the linings, and notch in at about 1/8" tall.
PostPosted: Wed Apr 02, 2025 6:46 am
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
Thanks Hesh :D
These users thanked the author Honza for the post: Hesh (Wed Apr 02, 2025 5:58 pm)
PostPosted: Wed Apr 02, 2025 6:48 am
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
Yes, for the x brace joint I was going to use glue (epoxy) soaked linen, or similar. Would you normally do both arms, or just the one?
PostPosted: Wed Apr 02, 2025 6:50 am
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
Thanks Cal. Sound hole reinforcement is on my to-do list, the bridge plate isn't. I'm going to do a pinless bridge, so my thinking is it's probably not needed. Do you think that sounds right?
PostPosted: Wed Apr 02, 2025 6:52 am
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
Doing it through the soundhole once strung up is definitely the plan. Though I'll admit to never actually having done it before. I'm guessing a finger plane or 80/120 grit sandpaper, do you think that sounds right? Is it...ummm...hard?
PostPosted: Wed Apr 02, 2025 8:31 am
Online
First name: Brad
Last Name: Combs
Looks good!
The pic doesn’t quite show the full lower bout, will you tuck the X into the linings or taper it to zero short of the lining?
What is the radius of the top and braces? Are the rims radiused the same to receive the top or left flat?
Cool project!
PostPosted: Wed Apr 02, 2025 9:37 am
Online
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
John—
This isn’t mud; more like a little cold water. :D
Can you tell us the setting(s) in which this instrument will be played, and whether it will have a pickup and amplification for regular performances? I ask because what you should do going forward may depend a lot on the answers to these questions. Acoustic bass guitars tend to be played in ensembles, and due to the limited size of the resonating chamber (compared to the notes being played on the lower strings), they tend to rely on pickups through amplifiers to be heard.
It does appear to be very clean work so far! Well done.
These users thanked the author doncaparker for the post: Kbore (Fri Apr 04, 2025 4:33 pm)
PostPosted: Wed Apr 02, 2025 12:41 pm
I would add a bridge plate extending in front and behind the bridge to help maintain the shape of the top. Otherwise the top could deform into an S shape, dipping in front on the bridge and rising behind it.
Nice clean work! I hope it’s a great success!
These users thanked the author Jim Watts for the post: Kbore (Fri Apr 04, 2025 4:33 pm)
PostPosted: Wed Apr 02, 2025 3:30 pm
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
bcombs510 wrote:
Looks good!
Cool project!
They're tapered to zero below the bridge, and tucked in above.
The top/braces are radiused to 32 feet, and the rims are radiused to meet them. Which is definitely the worst job I've encountered so far.... :shock:
These users thanked the author Honza for the post: bcombs510 (Wed Apr 02, 2025 3:34 pm)
PostPosted: Wed Apr 02, 2025 3:39 pm
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
doncaparker wrote:
John—
It's designed to be played acoustically, for practise at home and possibly (just possibly) with a soft-playing guitar person. But as you say, a pickup is probably a good option to have....
So I'm going to build it without a pickup, to begin with. But..... Previous acoustic bass builds have had a Fishman UST and a K&K soundboard pickup. So for this one I was thinking of trying something like this:
https://schaller.info/en/oyster-d-s/1605-D
Basically a pair of stick-on transducers that I can move around to compare how the sound changes depending on location. I can then CA glue it to the inside once I've found the optimum location. That's the plan anway. (Probably coupled with an external preamp).
These users thanked the author Honza for the post: Kbore (Fri Apr 04, 2025 4:34 pm)
PostPosted: Wed Apr 02, 2025 3:47 pm
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
Thanks Jim!
And noted re the bridge plate. I'll have another think. I feel as though I've got decision exhaustion. Who knew one tiny guitar could demand so many critical decisions :lol:
PostPosted: Wed Apr 02, 2025 5:48 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
I've built three ABGs, one had a pinned bridge the other two pinless. I referred to a plan by Mark Stanley for the bracing although the bodies were smaller than his plan (J200 and 0000 Martin). His plan had a substantial bridgeplate with a pinless bridge so that's what I used on all of them.
These users thanked the author CarlD for the post: Kbore (Fri Apr 04, 2025 4:35 pm)
PostPosted: Wed Apr 02, 2025 5:58 pm
I would feel pretty uncomfortable without a bridge pin…
PostPosted: Wed Apr 02, 2025 10:33 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I think it doesn't sound right. The string tension on the soundboard is unchanged.
Peter Havriluk
PostPosted: Wed Apr 02, 2025 10:57 pm
Bridge plate I meant…
PostPosted: Thu Apr 03, 2025 12:11 am
A bass may be more difficult than a guitar since the soundhole may be smaller. Curved finger plane is probably best. I've only ever done it with a chisel, which is fairly difficult. Sandpaper (or better, a small piece of sanding belt) would be annoyingly slow, but doable.
As for the bridge plate, I don't think it will do anything worth doing except for adding stiffness, so if present it should be larger than the bridge footprint. Here's an image I made a long time ago to explain it (in real life there will also be a bend in front of the bridge, but it's usually not problematic):
But your first tone bar looks like it will already perform that function to a large degree. And bridge peeling is mainly a concern for thinner-than-average soundboards. What species and how thick is yours? Chances are it would be fine just like it is.
If you add a bridge plate, you could use softwood to save weight since you don't need string ball protection. You could also orient the grain the same as the soundboard to get much more stiffness in the string pull direction for a given thickness, or diagonally for something inbetween.
Ain't that the truth :lol: But the decision making is a large part of the fun for me.
These users thanked the author DennisK for the post (total 2): Kbore (Fri Apr 04, 2025 4:37 pm) • Honza (Thu Apr 03, 2025 4:22 pm)
PostPosted: Thu Apr 03, 2025 10:59 am
Online
Last Name: Parker
City: Charleston
Honza wrote:
doncaparker wrote:
John—
My point in asking is that, since acoustic bass guitars tend to need pickups and amplification to be heard, I would favor structural stability over trying to get the most acoustic tone possible. We always are trying to balance between the two, and for this sort of instrument, there's only so much acoustic sound available, so I wouldn't do much more carving in order to try to make it sound better.
These users thanked the author doncaparker for the post: Kbore (Fri Apr 04, 2025 5:19 pm)
PostPosted: Thu Apr 03, 2025 4:20 pm
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
Hi Carl, Thanks for that. I've come across mention of the Stanley ABG plans a few times. I take it you don't still have them?
PostPosted: Thu Apr 03, 2025 4:35 pm
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
Well I've glued the top on, no bridge plate. Thanks everyone for the advice. As is always the case there are widely differing opinions, frequently opposing but always interesting! I can completely understand why the idea of no bridge plate makes people nervous. Me too! But there's only one way to find out....
These users thanked the author Honza for the post: Kbore (Fri Apr 04, 2025 5:20 pm)
PostPosted: Fri Apr 04, 2025 7:06 am
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
doncaparker wrote:
Honza wrote:
doncaparker wrote:
John—
Don, you make a good point! Though I have to say since I made my first ABG I literally haven't picked up an electric bass, nor have I plugged in. I may of course be abnormal :?
Users browsing this forum: doncaparker and 27 guests
