It is currently Fri Sep 12, 2025 7:10 pm
Post new topic Reply to topic  [ 1830 posts ]  Go to page Previous  1 ... 44, 45, 46, 47, 48, 49, 50 ... 74  Next
PostPosted: Fri Nov 17, 2023 3:52 am
Michaeldc wrote:
Time to close another box -
Beautiful work Michael, very clean as always.
Is that a 00 size? Beautiful lines!
PostPosted: Fri Nov 17, 2023 7:07 am
Last Name: Colbert
City: Anacortes
Thanks Colin, that means a lot coming from you -
This is actually a Parlor/0 size instrument. Parlor sized instruments got a lot of attention at the La Conner guitar festival last year - figured I’d better get on board!
Cheers, M
These users thanked the author Michaeldc for the post (total 2): bcombs510 (Fri Nov 17, 2023 7:17 am) • Colin North (Fri Nov 17, 2023 7:13 am)
PostPosted: Fri Nov 17, 2023 8:15 am
Interesting clamps there, nice looking guitar guts.
These users thanked the author jfmckenna for the post: Michaeldc (Fri Nov 17, 2023 8:49 am)
PostPosted: Fri Nov 17, 2023 8:52 am
Last Name: Colbert
City: Anacortes
The clamps are from Elevate Lutherie. https://elevatelutherie.com/product/side-clamps/
M
These users thanked the author Michaeldc for the post (total 2): Kbore (Sat Nov 18, 2023 1:52 pm) • jfmckenna (Fri Nov 17, 2023 12:35 pm)
PostPosted: Sat Nov 18, 2023 1:55 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Binding installation day…
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post (total 4): Colin North (Sun Nov 19, 2023 6:08 am) • bcombs510 (Sat Nov 18, 2023 3:08 pm) • jfmckenna (Sat Nov 18, 2023 2:52 pm) • Michaeldc (Sat Nov 18, 2023 2:02 pm)
PostPosted: Sun Nov 19, 2023 5:46 am
First name: Thomas
Last Name: T
I’ve only made one guitar, but I’m hooked and have two more underway. Now I’m making a few furniture and tooling upgrades.
Bought this new workbench and made some leg lifters to bring it up to a more comfortable level.
These users thanked the author guitarmaker78 for the post (total 4): Michaeldc (Sun Nov 19, 2023 11:49 am) • Kbore (Sun Nov 19, 2023 10:50 am) • Chris Pile (Sun Nov 19, 2023 10:13 am) • bcombs510 (Sun Nov 19, 2023 8:02 am)
PostPosted: Sun Nov 19, 2023 5:52 am
First name: Thomas
Last Name: T
I needed somewhere to store my guitars that are in progress so I built this cabinet out of a 3/4 birch plywood. The drawers are 1/2 birch plywood. I put a butcher block top and casters on the bottom as I do everything in my shop.
These users thanked the author guitarmaker78 for the post (total 6): rbuddy (Sun Nov 19, 2023 12:33 pm) • Kbore (Sun Nov 19, 2023 10:51 am) • Chris Pile (Sun Nov 19, 2023 10:13 am) • bcombs510 (Sun Nov 19, 2023 8:02 am) • Ken Nagy (Sun Nov 19, 2023 8:00 am) • Colin North (Sun Nov 19, 2023 6:09 am)
PostPosted: Sun Nov 19, 2023 6:02 am
First name: Thomas
Last Name: T
Got a new set of chisels, spent way too long sharpening them, and built a rack to hold them.
These users thanked the author guitarmaker78 for the post (total 3): Bryan Bear (Wed Feb 21, 2024 4:33 pm) • Michaeldc (Sat Dec 09, 2023 10:04 pm) • Kbore (Sun Nov 19, 2023 10:52 am)
PostPosted: Sun Nov 19, 2023 6:10 am
First name: Thomas
Last Name: T
And finally this week, I built a mold to laminate sides. I got the idea from a video by Driftwood Guitars. His idea for a vacuum bag using sheeting material was ok, but i found it much easier to use a blanket vacuum storage bag.
The plywood looks weird, because my cnc tears up and splinters the outer veneer layers so I run it through my thickness sander after the cnc is through with it.
These users thanked the author guitarmaker78 for the post (total 3): Michaeldc (Sat Dec 09, 2023 10:05 pm) • Kbore (Sun Nov 19, 2023 10:53 am) • Chris Pile (Sun Nov 19, 2023 10:13 am)
PostPosted: Sun Nov 19, 2023 8:12 am
First name: Brad
Last Name: Combs
Looking good! If you want to avoid the tearout on the plywood try a compression bit. You may already be familiar with them but, a compression bit does both upcut and downcut. The trick is you have to cut the first pass depth a little deeper than the upcut portion of the bit (marked as B1 here):
Before I had a CNC that was powerful enough to drive a compression bit I used to start with a downcut bit and then last pass would change bits to an upcut, reset the Z and run the last pass as a separate toolpath. That might still be faster than running the pieces through a sander.
Maybe some of that is useful.
Brad
These users thanked the author bcombs510 for the post: Kbore (Sun Nov 19, 2023 10:54 am)
PostPosted: Sun Nov 19, 2023 10:52 am
First name: Karl
Last Name: Borum
Where are you getting your Butcher tops?
Measure Twice,
Karl Borum
PostPosted: Sun Nov 19, 2023 11:32 am
Pretty happy with the way this top refinish came out. Not perfect, but close.
These users thanked the author jfmckenna for the post (total 5): dzsmith (Mon Nov 20, 2023 9:48 am) • Kbore (Sun Nov 19, 2023 12:56 pm) • Michaeldc (Sun Nov 19, 2023 11:49 am) • Hesh (Sun Nov 19, 2023 11:42 am) • bcombs510 (Sun Nov 19, 2023 11:35 am)
PostPosted: Sun Nov 19, 2023 11:43 am
Looks great Jf, nice work.
These users thanked the author Hesh for the post: jfmckenna (Sun Nov 19, 2023 12:53 pm)
PostPosted: Sun Nov 19, 2023 1:28 pm
First name: Thomas
Last Name: T
Brad
Thanks, Brad. I use compression bits on my big machine at work, which is how I made the cabinet. My smaller machine at home just uses a router and not a spindle. I could be wrong but I figured I needed to sand anyway to get a good glue surface and the veneer is so thin, I’m basically through it after only 2-3 passes through my thickness sander anyway.
These users thanked the author guitarmaker78 for the post: bcombs510 (Sun Nov 19, 2023 2:27 pm)
PostPosted: Sun Nov 19, 2023 1:32 pm
First name: Thomas
Last Name: T
Through a local cabinet supply shop. They are locally made. This uses a 24x48 and cost about $350.
I thought about getting a finger cut bit for my router and making my own, but decided I’d rather spend the time making guitars.
These users thanked the author guitarmaker78 for the post: Kbore (Sun Nov 19, 2023 8:14 pm)
PostPosted: Sun Nov 19, 2023 2:06 pm
Woodcraft and Home Depot (and others, no doubt) also have butcher block tops.
These users thanked the author SteveSmith for the post: Kbore (Sun Nov 19, 2023 8:14 pm)
PostPosted: Sun Nov 19, 2023 5:09 pm
First name: D
Last Name: S
Cleaning up prior to assembly.
Mahogany top and back with Maple center.
I have matching purple Dimarzio pickups and knobs.
All other hardware is black.Image
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post (total 7): Hesh (Sun Dec 10, 2023 9:38 am) • Kbore (Mon Nov 20, 2023 7:11 pm) • Michaeldc (Mon Nov 20, 2023 6:19 am) • Chris Pile (Sun Nov 19, 2023 9:20 pm) • bcombs510 (Sun Nov 19, 2023 5:41 pm) • jfmckenna (Sun Nov 19, 2023 5:20 pm) • Durero (Sun Nov 19, 2023 5:18 pm)
PostPosted: Mon Nov 20, 2023 6:10 am
City: Escondido
Zip/Postal Code: 92029
Someday, when I’m rich, I am going to commission one of your SG’s! They are the coolest slab guitars I’ve ever seen. I’ll stop playing jazz and I’ll only play AC/DC from then on.
These users thanked the author rlrhett for the post (total 2): Kbore (Sat Dec 09, 2023 6:33 pm) • dzsmith (Mon Nov 20, 2023 8:42 am)
PostPosted: Sat Dec 09, 2023 4:12 pm
A commission I took for a pre-Christmas delivery. 000 style, long scale, Pau Ferro, Torrified Red Spruce, Shertlers, Koa trim, Royal Lac Post Cat. It’s been a bit stressful, I agreed to do it in less than three months, normally I require 6 months. I was very happy to get the setup strings on today. It already sounds really good but I’ll let it sit till Monday then do the final setup and get it delivered next week.
These users thanked the author SteveSmith for the post (total 7): Robbie_McD (Wed Dec 13, 2023 7:50 am) • Doc (Mon Dec 11, 2023 4:39 pm) • Hesh (Sun Dec 10, 2023 9:37 am) • Colin North (Sun Dec 10, 2023 5:46 am) • Kbore (Sat Dec 09, 2023 7:54 pm) • bcombs510 (Sat Dec 09, 2023 5:45 pm) • Chris Pile (Sat Dec 09, 2023 4:33 pm)
PostPosted: Sat Dec 09, 2023 5:48 pm
First name: Brad
Last Name: Combs
A beauty, Steve! What’s the neck situation, is it tinted?
PostPosted: Sat Dec 09, 2023 5:49 pm
Test piece for a Florentine cutaway (laminated sides) in my bending jig.
Sent from my moto g(50) using Tapatalk
These users thanked the author Colin North for the post (total 4): SteveSmith (Sun Dec 10, 2023 1:33 pm) • Hesh (Sun Dec 10, 2023 9:38 am) • Michaeldc (Sat Dec 09, 2023 10:06 pm) • Kbore (Sat Dec 09, 2023 7:57 pm)
PostPosted: Sat Dec 09, 2023 6:35 pm
Thanks Brad. Yes, neck was very light colored mahogany so I airbrushed it with Colortone in shellac. I left it light in the middle just cause I like the way it looks.
These users thanked the author SteveSmith for the post (total 2): Colin North (Sun Dec 10, 2023 5:46 am) • bcombs510 (Sat Dec 09, 2023 8:04 pm)
PostPosted: Sat Dec 09, 2023 8:49 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
This old spokeshave is my favorite tool for the initial shaping of the neck shaft.
These users thanked the author J De Rocher for the post (total 6): SteveSmith (Sun Dec 10, 2023 1:34 pm) • Hesh (Sun Dec 10, 2023 9:38 am) • Colin North (Sun Dec 10, 2023 5:47 am) • Chris Pile (Sat Dec 09, 2023 11:52 pm) • Michaeldc (Sat Dec 09, 2023 10:06 pm) • bcombs510 (Sat Dec 09, 2023 8:54 pm)
PostPosted: Sun Dec 10, 2023 11:55 am
Just a follow up post, that trial for the Florentine cutaway piece turned out fine, and with the heat on 200deg F) the final glue up with high strength epoxy the cure time was less than an hour.
So laminating in the form can save time
P.S. spot the mistake.
These users thanked the author Colin North for the post (total 4): Hesh (Mon Dec 11, 2023 5:52 am) • Michaeldc (Sun Dec 10, 2023 10:57 pm) • SteveSmith (Sun Dec 10, 2023 1:34 pm) • bcombs510 (Sun Dec 10, 2023 12:38 pm)
PostPosted: Mon Dec 11, 2023 8:38 am
First name: Chuck
Last Name: Skarsaune
City: Butler
Along the "Now for something completely different" line...
Got talking to a couple of locals about dulcimers, had some wood that looked like a dulcimer, so I thought I'd make one.
Came together really quickly, works like it should.
Best part is, it got me fired up about building again.
So I started with some walnut sets I resawed not long ago....
And spent the weekend in the shop. Backs joined, sides bent, things getting braced, etc. It's been great.
These users thanked the author Skarsaune for the post (total 6): Doc (Mon Dec 11, 2023 4:40 pm) • Colin North (Mon Dec 11, 2023 10:04 am) • Kbore (Mon Dec 11, 2023 9:19 am) • Chris Pile (Mon Dec 11, 2023 8:50 am) • SteveSmith (Mon Dec 11, 2023 8:48 am) • bcombs510 (Mon Dec 11, 2023 8:45 am)
cron
