It is currently Fri Sep 12, 2025 7:11 pm
Post new topic Reply to topic  [ 1830 posts ]  Go to page Previous  1 ... 43, 44, 45, 46, 47, 48, 49 ... 74  Next
PostPosted: Wed Nov 08, 2023 4:55 pm
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
Cool looking ukes, bet they were fun to build. Thanks guys, I'll try to post a pic of the way I did the "pilage". I glued and thicknessed the top first, bent the fold in it. I had to use a good deal of heat and figured that the glue was probably compromised, so I cut it down the seam and reglued after the bending.
These users thanked the author surveyor for the post (total 2): Pat Foster (Mon Nov 13, 2023 8:41 pm) • Michaeldc (Thu Nov 09, 2023 10:17 am)
PostPosted: Wed Nov 08, 2023 6:14 pm
Wow beautiful Ukes Pat!
Mike that is a great idea to get the pliage done right. I was using Michael Collins book and he bends the pliage into each half first then joints them and glues them up. I could not possibly see myself doing that. But to intentionally glue the two tops together to bend them then re-cut and join again is brilliant.
These users thanked the author jfmckenna for the post (total 2): Pat Foster (Mon Nov 13, 2023 8:41 pm) • surveyor (Thu Nov 09, 2023 11:47 am)
PostPosted: Thu Nov 09, 2023 10:22 am
Last Name: Colbert
City: Anacortes
I’m working on a new parlor - thought I’d post a few progress shots.
I’m also considering building a Lefty - thoughts?
M
These users thanked the author Michaeldc for the post (total 4): Bryan Bear (Wed Feb 21, 2024 4:32 pm) • Doc (Fri Nov 17, 2023 8:58 am) • Kbore (Tue Nov 14, 2023 11:36 am) • bcombs510 (Thu Nov 09, 2023 10:57 am)
PostPosted: Thu Nov 09, 2023 10:57 am
First name: Brad
Last Name: Combs
Lovely, and I love a parlor guitar!
Question - are you making your own workboards on the CNC? If so, would you mind sharing the material you like to use? I’m wanting to find an MDF type material that’s thicker than .75” without having to laminate two pieces. :)
PostPosted: Thu Nov 09, 2023 11:11 am
Hi Brad,
They make MDF up to 2 inches in thickness. 1 1/8 inch thickness is usually not too hard to find from cabinet supply places as it is often used for commercial countertops. Your local cabinet shop could order it in from their wholesaler for a small markup.
These users thanked the author Clay S. for the post: bcombs510 (Thu Nov 09, 2023 11:32 am)
PostPosted: Thu Nov 09, 2023 11:20 am
Last Name: Colbert
City: Anacortes
No, I had Josh make mine. They are excellent quality! 2 work boards plus 2 radius dishes are under $300US. I sourced the sandpaper elsewhere cuz the 60# Josh offered was a bit aggro for my needs - I use 80#. https://www.canadianluthiersupply.com/c ... ork-boards
Cheers, M
These users thanked the author Michaeldc for the post (total 2): Pmaj7 (Fri Nov 10, 2023 6:00 pm) • bcombs510 (Thu Nov 09, 2023 11:31 am)
PostPosted: Thu Nov 09, 2023 11:28 am
Last Name: Colbert
City: Anacortes
Clay S. wrote:
Hi Brad,
I made my first dishes out of 1” MDF as I had a bunch of off-cuts from building loudspeakers. I found that once you cut the dish profile the material immediately distorted due to released tension in the material - plus a sheet of 1” MDF is f-in heavy, about #140 as I recall. My older frame isn’t much into that anymore.
M
These users thanked the author Michaeldc for the post: bcombs510 (Thu Nov 09, 2023 11:32 am)
PostPosted: Fri Nov 10, 2023 5:47 pm
Pat Foster wrote:
I've been trying out this glue and like it so far. High solids content. What I like best is that pieces being glued don't slide around so much. Haven't used it for any high-stress situations yet.
Less slippery than tight bond?
Sent from my SM-N960U1 using Tapatalk
PostPosted: Fri Nov 10, 2023 8:12 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
My buddy Joe Mendel uses that Lee Valley Cabinet makers glue and loves it.
Guess I should try it, since no more LMI glue.
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post: Pmaj7 (Fri Nov 10, 2023 8:15 pm)
PostPosted: Fri Nov 10, 2023 10:16 pm
Last Name: Sollod
I've been using titebond's “translucent” glue and I really like it. It seems a lot like LMI's old formula instrument makers glue…
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post (total 2): Kbore (Sat Nov 18, 2023 1:49 pm) • Pmaj7 (Fri Nov 10, 2023 10:20 pm)
PostPosted: Fri Nov 10, 2023 10:19 pm
What I like about the Cabinetmaker's glue is that the parts don't scoot around as much when being clamped.
These users thanked the author Pat Foster for the post (total 2): Kbore (Sat Nov 11, 2023 3:26 pm) • Pmaj7 (Fri Nov 10, 2023 10:20 pm)
PostPosted: Fri Nov 10, 2023 10:44 pm
First name: Brad
Last Name: Combs
I tried to buy some of the cabinetmakers glue and it says it’s an in store item only. Is that a new thing?
These users thanked the author bcombs510 for the post: Kbore (Sat Nov 18, 2023 1:50 pm)
PostPosted: Sun Nov 12, 2023 12:58 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
Finishing up a Purple Heart and spruce Torres model (body shape is FE-04 "La Leona" for a client in Singapore. A bit flashier then my norm but I'm kind of digging it.
These users thanked the author oval soundhole for the post (total 7): Bryan Bear (Wed Feb 21, 2024 4:32 pm) • Robbie_McD (Mon Dec 11, 2023 9:03 am) • Doc (Fri Nov 17, 2023 9:01 am) • Ken Nagy (Sun Nov 12, 2023 7:58 pm) • Kbore (Sun Nov 12, 2023 5:17 pm) • Michaeldc (Sun Nov 12, 2023 2:25 pm) • Chris Pile (Sun Nov 12, 2023 2:10 pm)
PostPosted: Sun Nov 12, 2023 2:11 pm
Elegant, colorful, classy. Love the tie block, too!
PostPosted: Sun Nov 12, 2023 2:41 pm
Beautiful headstock Brian I love the sharp angles on the ramps. All round very fine guitar.
PostPosted: Mon Nov 13, 2023 12:56 pm
Currently
These users thanked the author SnowManSnow for the post (total 4): Michaeldc (Tue Nov 14, 2023 12:45 pm) • Kbore (Tue Nov 14, 2023 11:34 am) • Hesh (Mon Nov 13, 2023 4:12 pm) • jfmckenna (Mon Nov 13, 2023 3:16 pm)
PostPosted: Mon Nov 13, 2023 4:13 pm
Really nice work Snow.
PostPosted: Mon Nov 13, 2023 5:03 pm
This one ready for finishImage
These users thanked the author SteveSmith for the post (total 7): Bryan Bear (Wed Feb 21, 2024 4:33 pm) • Robbie_McD (Mon Dec 11, 2023 9:04 am) • Michaeldc (Tue Nov 14, 2023 12:45 pm) • Kbore (Tue Nov 14, 2023 11:35 am) • Hesh (Tue Nov 14, 2023 4:37 am) • Chris Pile (Mon Nov 13, 2023 7:57 pm) • bcombs510 (Mon Nov 13, 2023 6:37 pm)
PostPosted: Mon Nov 13, 2023 8:42 pm
Much less.
These users thanked the author Pat Foster for the post (total 2): Kbore (Sat Nov 18, 2023 1:51 pm) • Pmaj7 (Mon Nov 13, 2023 8:47 pm)
PostPosted: Mon Nov 13, 2023 11:09 pm
Pat, I’m a few days late, but gorgeous!
These users thanked the author James Orr for the post: Pat Foster (Mon Nov 13, 2023 11:11 pm)
PostPosted: Tue Nov 14, 2023 4:38 am
Really nice guitar Steve!
These users thanked the author Hesh for the post: SteveSmith (Tue Nov 14, 2023 6:27 am)
PostPosted: Tue Nov 14, 2023 11:51 am
First name: Karl
Last Name: Borum
Wow, it seems it is a new thing. It no longer even comes up on the "USA" site. I added it to my cart from the Canadian .ca domain, it added ok, but when I went to check out it I got the "not available in your location" message. asking self -----> now what
EDIT: They don't ship it after November 1st. Should be available in the spring
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post: bcombs510 (Tue Nov 14, 2023 11:58 am)
PostPosted: Thu Nov 16, 2023 10:22 pm
Last Name: Colbert
City: Anacortes
Time to close another box -
These users thanked the author Michaeldc for the post (total 5): Kbore (Sat Nov 18, 2023 1:51 pm) • Durero (Fri Nov 17, 2023 4:49 pm) • Colin North (Fri Nov 17, 2023 3:45 am) • Hesh (Fri Nov 17, 2023 12:26 am) • bcombs510 (Thu Nov 16, 2023 10:30 pm)
PostPosted: Thu Nov 16, 2023 11:53 pm
Lee Valley glue separates when frozen so I expect they don’t like mailing it in the winter…
PostPosted: Thu Nov 16, 2023 11:55 pm
Also from press testing I’ve found the LV cabinet glue does not dry as hard as some other glues…
These users thanked the author meddlingfool for the post (total 2): Robbie_McD (Mon Dec 11, 2023 9:05 am) • Kbore (Sat Nov 18, 2023 1:51 pm)
