It is currently Sat Apr 18, 2026 3:11 am
PostPosted: Mon Mar 11, 2019 8:47 am
Here is the latest Luthier Tips du Jour video. - In this video I show how to fix action on a classical guitar that is too high but there is not enough saddle exposed to allow it. This video as well as all my other videos are available via my website, http://www.obrienguitars.com/videos , LMI's website or on youtube.
PostPosted: Mon Mar 11, 2019 10:08 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
one option I've used many times.
Drill the bridge to make a 12 hole-Take a 1/8"or 3/16- dowel-drill a hole in the end (very exactly) to except a 1/16 drill bit,make sure the dowel& drill bit reach the bridge -so that the new holes can be drilled
PROTECT the top from damage-- MARK ! the new drill spot with a sharp tool.
The new holes have to be 2-3mm from the original holes.
& lower on the tie block.
this will allow you to lower the saddle block & saddle.
Now the strings will NOT be pulled up & ride over the saddle.
WHY?
The sting will be tied to the saddle block-with NO lift from the old style tie.
Mike Collins
PostPosted: Mon Mar 11, 2019 10:40 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
HI Mike would you have a pic of this procedure , Looked at robbie/s youtube vid , seems like a lot of xtra work IMHO.Thank you ernie
PostPosted: Tue Mar 12, 2019 8:40 am
First name: Larry
Last Name: Hawes
Thanks Robbie, Curious about the fret install video by Kent? Can't find it anywhere but am very interested as his videos are great.
Thank You and Best To All
PostPosted: Tue Mar 12, 2019 8:46 am
Thanks Larry. Kent's video is available here - https://obrienguitars.com/courses
PostPosted: Tue Mar 12, 2019 9:25 am
First name: Larry
Last Name: Hawes
Thanks again...
