It is currently Tue Jul 22, 2025 7:34 am
 Post subject: The green beast planer
PostPosted: Mon Apr 23, 2018 9:27 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
WE have an older 16in hvy duty 2 hp 220 v Taiwanese Rexon 2 spd green planer bought in N. van. BC in 1987, my problem is the 2 speed xmission leaks oil from the upper right hand crankcase which takes about 1 month to drain itself out. It has not seen much use lately. It is comparable to other imports from grizz etc of that era .Not sure how to go about replacing the gasket or whatever to stop the leaking? anyone out there done this repair ? Scant info on youtube Thank you
PostPosted: Mon Apr 23, 2018 10:17 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I'm assuming you have but I'll mention it anyway. . . have you googled the name of the machine and problem yet (not just into youtube)? I often find some obscure forum devoted to fixing whatever I have that is broken and can usually get good advice. There may be a large shop tool maintenance forum out there somewhere.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: ernie (Mon Apr 23, 2018 4:34 pm)
PostPosted: Mon Apr 23, 2018 11:24 am
Most of the older Taiwanese machinery was a clone of a western brand. If you can figure out what it is a clone of you might be able to use the information for that machine to sort the problem.
PostPosted: Mon Apr 23, 2018 12:07 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Maybe this link could help? http://www.fixya.com/support/t17870867- ... aner_parts
I'm sure it's fixable....but maybe better left alone. If you don't use it that much I would just fill up the oil, use it, then put a pan under it to catch the drips
These users thanked the author Quine for the post: Bryan Bear (Mon Apr 23, 2018 12:19 pm)
PostPosted: Mon Apr 23, 2018 2:22 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Have you tightened the Allen bolts? My green BusyBee planer also leaked from the crank case, but not as badly. Snugging the bolts did the trick, for me.
Alex
PostPosted: Mon Apr 23, 2018 3:11 pm
First name: Aaron
Need to determine where its leaking from. If its a bearing seal, the you'll need to find a comparable replacement.
If its a joint leak, Permatex is your friend.https://www.permatex.com/product-catego ... et-makers/
PostPosted: Mon Apr 23, 2018 4:44 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
I think it/s leaking from the worn out seal .? not sure , and yes I confess I was doing the pan thing for 1 year , but want to fix the leak now . I did get some red permatex. The Rexon is pretty generic , and the busy bee tool store in burnaby in the 80/s probably carried the same planer with a different name .Taiwan will put any name on a tool you wish, i got replacement knives from grizz . The other suggestions about looking for a comparable planer are good, but am not familiar with other usa planers.This is the only heavy duty planer I/ve ever owned, and it was bought in .N.vancouver BC in 1987 . I still have the original manual, and diagram , But frankly it looks like a chinese puzzle to me! Thanks everyone. Will keep looking for a youtube vid on how to replace gasket on an older planer.
PostPosted: Mon Apr 23, 2018 9:44 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I bought a set of seals from Grizzly in the past.
I'm not a luthier.
These users thanked the author klooker for the post: ernie (Wed Apr 25, 2018 11:47 am)
Users browsing this forum: UncleMikey and 34 guests
