It is currently Tue Jul 29, 2025 11:41 am
 Post subject: Side dot jig....
PostPosted: Thu Mar 29, 2018 7:25 am
First name: Brad
Last Name: Combs
Does anyone have pictures of the Todd Stock side for jig? All his posts are removed and I see everyone’s responses but not the jig. :) I searched a bit online and saw a plexiglass model that looks interesting. Below is what I came up with. It’s a little finicky to get the bit aligned and then get the fence clamped down.
If anyone else uses a jig for this and is willing to share I’d like to see how to improve or rebuild this. The results were good, but this idea assumes the board is not a compound radius (I don’t use that today). The one I saw online top mounted so you could align however you want.
I use this guide block to align everything first:
The board is attached to a sled with double stick tape:
Each fret position is marked with an indexing pin:
Some pics of halo markers. One is a silver ring filled with ebony dust, the other is a silver ring filled with standard 1.5mm white plastic side dot material in the center:
 Post subject: Re: Side dot jig....
PostPosted: Thu Mar 29, 2018 7:55 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
These are the photos I have in the data files for the building guide. I believe this jig has since been upgraded to use drill bushings to address wear, but I hope this addresses your request.
- Beth Brower
These users thanked the author Woodie G for the post (total 2): jac68984 (Fri Mar 30, 2018 10:46 pm) • bcombs510 (Thu Mar 29, 2018 8:33 am)
PostPosted: Thu Mar 29, 2018 8:06 am
Over the last 14 years I have tried lots of different jigs to do side dots. One big problem is that a small bit in a drill press will deflect a little when it hits the wood. Some have used a small router bit to avert that problem.
After a lot of frustration with jigs I went back to freehand years ago. I wait until the fretboard is on the neck, the neck carved and leveled. It’s the last thing before fretting so the side width is at it’s final point.
Measure where you want them and draw a vertical line. For a constant distance from the top of the fretboard which is what I do, determine that distance and put a few layers of tape on a ruler. The tape keys off the edge of the fretboard. Make a light mark on the line with a sharp small awl. Double check and deepen the mark. Drill with a Brad point bit. Start in reverse to set the point then go forward and drill. Goes pretty fast after you get the hang of it.
A constant radius fretboard may be a little thinner on the edges at the wider end but if the dots are all the same distance from the top the eye does not seem to notice that they may be slightly off center at the 15th fret.
These users thanked the author Terence Kennedy for the post (total 2): Pmaj7 (Thu Mar 29, 2018 10:26 pm) • bcombs510 (Thu Mar 29, 2018 8:33 am)
PostPosted: Thu Mar 29, 2018 8:36 am
First name: Brad
Last Name: Combs
Thanks to you both. Yes, Woodie, thank you for sharing that. I like the idea a lot.
Good point about the bit. I did have to chuck the bit way up in the press to keep it from deflecting. At 2.5mm, even that little 5mm exposure probably still reflects a little when it hits ebony.
What I did was lower the bit just until it made contact, grab the sled and hold it up to the light to check that we are still centered, then drill (slowly) the rest of the way.
PostPosted: Thu Mar 29, 2018 8:39 am
Same here as Terry, center punch and drill. Most of the time I used large 3/32" tortoise dots on mandolins and guitars. Something about "over-jigging" never did appeal to me. Dots would take less than 15 minutes to do.
These users thanked the author Haans for the post: bcombs510 (Thu Mar 29, 2018 9:11 am)
PostPosted: Thu Mar 29, 2018 9:17 am
Same as Terry and Haans for me too. I just mark the center line between the frets then eyeball it. A nice awl mark and brad point bit gets it good. I always thought that it was my cheap bench top drill press but I always have bit wondering problems with it. For a jig I would suspect you would need something not unlike a classical guitar or mandolin tuner jig so that the bit is aligned perfect and fastened hard.
These users thanked the author jfmckenna for the post: bcombs510 (Thu Mar 29, 2018 9:22 am)
PostPosted: Thu Mar 29, 2018 9:21 am
First name: Brad
Last Name: Combs
Agreed, Hans. My wife continually says “it’s supposed to be handmade” to get me off of obsessing over ridiculous details that no-one cares about in the end. :)
I spent some time recently thinking about what gets the most eye ball time on a guitar. Once the initial infatuation is over and the player stops marveling at the soundboard, rosette, inlays, etc... what are they stuck looking at? The side dots, side sound port (if there is one), the binding and purfling, etc... What else?
For me, with the side dots... a screw up is such a tremendous amount of work to fix for such a little process. I’m not confident like you folks that I won’t blow it. ;)
I find myself walking a line between over jigging and handmade and I keep falling onto the jig side. Hopefully with time and confidence I’ll get my balance.
PostPosted: Thu Mar 29, 2018 10:09 am
First name: D
Last Name: S
I’d like to suggest erasing pencil marks before gluing in the dots.
This will prevent the marks from being trapped under glue that may wick from the edge of the hole.
I had an unpleasant experience with a Maple board.
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: bcombs510 (Thu Mar 29, 2018 10:38 am)
PostPosted: Thu Mar 29, 2018 10:14 am
One problem with a jig is you typically use it before the fretboard is glued. After gluing and leveling the side width could theoretically change (although admittedly very little).
I found my freehand method to be faster and more accurate than any of the jigs I made but I am sure there are ones that work great. There was a discussion here on this topic years ago and I remember Tony Karol I think using a router bit in his drill press jig and saying it worked well to keep things from wandering.
These users thanked the author Terence Kennedy for the post: bcombs510 (Thu Mar 29, 2018 10:38 am)
PostPosted: Thu Mar 29, 2018 10:28 am
Last Name: Sollod
I have also been doing it freehand. I will use the awl to open up the hole as needed and then follow that with the drill bit. Seems like I can't find a 2mm brad point bit anywhere...
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post: bcombs510 (Thu Mar 29, 2018 10:38 am)
PostPosted: Thu Mar 29, 2018 10:40 am
First name: Brad
Last Name: Combs
Same here. The set of brad points that I have goes down to 1mm but the brad point stops as the 3mm bit. If you find a 2 or 2.5, please share!
PostPosted: Thu Mar 29, 2018 10:47 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Not brad points but I use these - I like the short shank for this use.
https://www.mcmaster.com/#standard-drill-bits/=1c6jwlf
I'm not a luthier.
These users thanked the author klooker for the post: bcombs510 (Thu Mar 29, 2018 12:33 pm)
PostPosted: Thu Mar 29, 2018 10:58 am
LMI sells Brad points to match their side dot material. I use a 2mm dot and bit.
These users thanked the author Terence Kennedy for the post (total 2): Pmaj7 (Thu Mar 29, 2018 11:25 pm) • bcombs510 (Thu Mar 29, 2018 12:33 pm)
PostPosted: Thu Mar 29, 2018 11:22 am
First name: nigel
Last Name: forster
City: Newcastle upon tyne
Zip/Postal Code: ne12at
Country: england
A few years back I spent a lot of time on making a jig that was perfect for a specific scale. Then I got really bored with working in large batches. It's just not for me.
Like the others, I do it by hand. Though I also do it almost all by eye. The distance between the frets I "split" and mark a vertical pencil line. That line, I split by eye, mark with whatever is handy - a brad, a nail, then drill with a 1.5mm bit. If I'm using pearl, it's a 1.5mm dot which looks very neat. Or if it's for export, I use a pop rivet, snip it off, sand it smooth and tap it flush. I "borrowed" that trick from Marty Jacobson, the mandolin maker. saw it on his blog or on a video. I forget. Clever feller Marty.
Nigel
http://www.nkforsterguitars.com
These users thanked the author nkforster for the post (total 3): kwerry (Tue Apr 10, 2018 10:22 pm) • pkdz (Sat Mar 31, 2018 8:45 pm) • bcombs510 (Thu Mar 29, 2018 12:33 pm)
PostPosted: Thu Mar 29, 2018 11:29 am
I have a small milling machine that I use for side dots.
These users thanked the author arie for the post: bcombs510 (Thu Mar 29, 2018 12:33 pm)
PostPosted: Thu Mar 29, 2018 3:31 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I do them freehand too. After marking the positions with a fine point pencil, I use the brad point bit that I'm going to use to drill the holes like an awl to start the holes freehand. I spin the bit back and forth using my finger tips until the brad point itself is into the wood and the spurs of the bit just make contact. For small bits, this works better than an awl for me because the shape of the hole made by the awl doesn't match the shape of the brad tip well. That makes for a bit of slop which can result in the bit wandering slightly off target once the drill is fired up. Since slight errors in the position of a side marker are super noticeable to me, this solves the problem. I've also found that an awl tip can be shifted off the mark by a hard grain line into the soft grain next to it, but a sharp brad tip can usually be kept on target.
These users thanked the author J De Rocher for the post (total 2): Pmaj7 (Fri Mar 30, 2018 10:28 am) • bcombs510 (Thu Mar 29, 2018 4:21 pm)
PostPosted: Thu Mar 29, 2018 4:02 pm
Great idea. I use the StewMac inlay scribe which is quite fine but definitely can be deviated by a grain line. I am going to try that.
These users thanked the author Terence Kennedy for the post: bcombs510 (Thu Mar 29, 2018 4:21 pm)
PostPosted: Thu Mar 29, 2018 4:04 pm
I use something similar to yours Brad, except I use glued blocks and wedges to secure the workpiece, and blocks instead of the incline you are using, which I can vary for different tapers of FB with a wedge. (Sorry, no pics at the moment)
I use a multi radius FB as standard, with the bass side lower than the treble ( for more even string height at the bridge) so that side of the FB is tapered and quite narrow. The jig accounts for that taper, putting the side dots in the centre of the edge.
No index pin, as I use different scales, and fanned frets sometime, so I just line up the dots to marked positions.
These users thanked the author Colin North for the post: bcombs510 (Thu Mar 29, 2018 4:21 pm)
PostPosted: Thu Mar 29, 2018 4:58 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
From my model airplane days Robart hinge point drill jig.
https://robart.com/products/hinge-point-drill-jig
Fred
Fred Tellier
These users thanked the author Fred Tellier for the post: Pmaj7 (Fri Mar 30, 2018 10:38 am)
PostPosted: Thu Mar 29, 2018 6:03 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
We reference to the bottom of the fretboard on new work, and drill only after the board is scraped and ready to glue up. The only marking is a line centered between the slots...line up with the line on the jig and drill. Tape or shim stock adjusts height.
On repair work, we frequently add side dots to both classicals and (recently) an early Fylde 12 string that came in naked of side markers but with position markers on the face of the board... very odd duck and no truss rod, but nicely reinforced neck with perfect relief - these were eyeballed to split the difference from bottom to bevel and were drilled by hand. Some guitars live a charmed life and see little taken off the board for refrets...but we've had a few in where we've had to move side markers down from what must have been centered positions 60 or 70 years ago.
Jigging for the operation is more about consistency than saving time. It is surprising how often we see a wonky dot or two on a guitar that shows a high level of persnicketyness otherwise. Certainly shows a bit of humanity.
Layout always takes more time than seems reasonable...but worth the toll to avoid becoming reacquainted with Mr. Murphy.
- Beth Brower
These users thanked the author Woodie G for the post: bcombs510 (Fri Mar 30, 2018 1:20 pm)
PostPosted: Fri Mar 30, 2018 10:49 am
I do the same thing year after year; Spend a bunch of time thinking about what kind of cool jig I'm going to make for this,.........then do it by hand.
In efforts to eradicate the wonky, how do you all measure between the frets? I use a digicali, but I wonder if a centering rule would be easier........hmmmm
These users thanked the author Pmaj7 for the post: bcombs510 (Fri Mar 30, 2018 1:20 pm)
PostPosted: Fri Mar 30, 2018 1:52 pm
First name: Jay
City: Bothell
State: Washington
I use a 6" machinist's rule or my StewMac 6" centering rule, whichever is the handiest. Those work fine for me for centering between frets.
These users thanked the author J De Rocher for the post: Pmaj7 (Fri Mar 30, 2018 3:07 pm)
PostPosted: Fri Mar 30, 2018 2:28 pm
Mitutoyo 6" caliper, awl and a pin vise. Easier to drill accurate holes with a pin vise and it doesn't take that long.
These users thanked the author SteveSmith for the post: Pmaj7 (Sat Mar 31, 2018 12:24 am)
PostPosted: Mon Apr 02, 2018 2:39 pm
First name: Roger
State: Oklahoma
Here's my jig. Just a piece of angle aluminum with 2 holes and a center line. I mark my center line between the frets, line of the center line of my jig using the back sighting hole, then drill the front hole. You have to do this before carving the neck.
These users thanked the author RogerC108 for the post: bcombs510 (Mon Apr 02, 2018 3:04 pm)
PostPosted: Mon Apr 02, 2018 4:44 pm
I like your wife's thinking. I'm probably one of the only ones around here that thinks like that too. Most are too preoccupied with razor sharp perfection like Marvin, Collings, Olsen, etc.
I'm stuck in 1915 with Orville. A little "wobble" here or there is not the end of the world.
Here's a F5C with the tortoise dots touching the black line of the purfling...yes, folks they are supposed to touch the line. Notice the 15th fret dot is just shy of touching...big deal.
What do guitar players see while they are playing? I would guess most bluegrass standup players see the mic, audience. For us "sit down" players, binding, purfling, strings, rosette, idunno .
Personally, I like to watch my finners and marvel that I can still make them move...
Getting the confidence? Practice, practice, practice.
Users browsing this forum: mikeyb2 and 9 guests
