It is currently Sat Jul 19, 2025 5:10 pm
PostPosted: Fri Nov 03, 2017 6:24 am
I’m still working out some sources for regularly needed building supplies, and need to find a good place for the mortise and tenon barrels and bolts for bolt on connections. Lmi has these, but their shipping is kinda crazy, especially if you dont build a ton and only need a few connectors.
Stewmac doesn’t carry them, that I can find (why?)
Anyway.... where do you get yours?
Thanks for the insight
B
PostPosted: Fri Nov 03, 2017 6:55 am
Last Name: Colbert
City: Anacortes
I buy from these guys. https://shop.stafast.com
M
PostPosted: Fri Nov 03, 2017 7:35 am
First name: Brad
Last Name: Combs
Yeah, if you mean cross dowels when saying barrel connectors, I usually get those from Amazon or the local Ace Hardware. I've switched to hanger bolts on ukes and also using those on the next few guitars to see how they go. With a M/T joint the hanger bolt lets you really sink in the screw end deep, which gives me some peace of mind compared to have just a few 8ths of wood on the bottom side of the cross dowel. Probably overkill though I'm sure. :)
PostPosted: Fri Nov 03, 2017 7:45 am
Yes sir. That’s what I mean.
With the kits I’ve built they all used hanger bolts.
PostPosted: Fri Nov 03, 2017 8:41 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Home depot has these in the bulk bin area.
B
These users thanked the author Bri for the post: SnowManSnow (Fri Nov 03, 2017 9:23 am)
PostPosted: Fri Nov 03, 2017 9:24 am
So I’m looking for barrel nut = 1/4-10mm 20mm length and matching bolt that is 1/4x20 x30mm
PostPosted: Fri Nov 03, 2017 9:41 am
Last Name: Colbert
City: Anacortes
https://shop.stafast.com/cross-dowels
PostPosted: Fri Nov 03, 2017 10:09 am
I get my barrel nuts and Furniture bolts at Ace. Look for furniture connectors in the wonderful aisles with all the little boxes.
Spend some time there you will find all sorts of cool stuff for lutherie in those boxes.
These users thanked the author Terence Kennedy for the post: bcombs510 (Fri Nov 03, 2017 10:49 am)
PostPosted: Fri Nov 03, 2017 11:20 am
I've got a pile of these, can send you some. 1/4 x 10mm x 20mm zink plated.
PostPosted: Fri Nov 03, 2017 11:31 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Home Depot and Lowes. Like Terence said, you might find lots of other stuff.
Alex
PostPosted: Fri Nov 03, 2017 12:35 pm
FWIW, I evolve out of the bolt on M&T to the butt joint. The tenon is a holdover from the dovetail. If you're using bolts, there is no real reason for a tenon at all.
.02
PostPosted: Fri Nov 03, 2017 12:52 pm
In other words, beyond being the spot that holds the barrel nuts, the tenon has no actual purpose in the bolt on m&t.
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
You may already be aware of this, but if you order barrel nuts online, make sure they are the kind that have the bolt hole centered. Some barrel nuts have the bolt hole offset toward one end.
PostPosted: Fri Nov 03, 2017 5:16 pm
I’ve actually been looking for examples of this today.
PostPosted: Fri Nov 03, 2017 5:35 pm
I don't know about your search skills, but I did outline my process exactly in the build/repair section of the AGF not too long ago...
PostPosted: Fri Nov 03, 2017 5:44 pm
I found what I needed guys thanks for the insight. Also several folks messaged and offered to send me some.... thanks for the offers too! Very helpful thread for a new guy like me
PostPosted: Fri Nov 03, 2017 5:49 pm
Thanks for the last link
PostPosted: Fri Nov 03, 2017 5:50 pm
Yes sir. I did notice and ordered accordingly
PostPosted: Fri Nov 03, 2017 6:20 pm
First name: Nathan
Last Name: Peirson
If you don't know about McMaster Carr, they are a great place for mechanical parts.
https://www.mcmaster.com/
PostPosted: Fri Nov 03, 2017 6:35 pm
Here's mine...
