It is currently Wed Apr 29, 2026 8:42 am
PostPosted: Wed Jan 25, 2017 5:45 pm
First name: Tom
Last Name: Rein
City: Saline
Wondering if any OLF members have found a platina or blonde shellac that checks all the boxes? I used to use Kremer blonde but ran into some that wouldn't dissolve. I've been using super blonde from Shellac Finishes and while it dissolves admirably it doesn't sand quite as easily as I'd like.
Stay with the happy people.
--Reynolds Large
PostPosted: Wed Jan 25, 2017 6:37 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Are you grinding the flakes first? I use an old coffee grinder.
Alex
PostPosted: Wed Jan 25, 2017 7:08 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
Been using flakes from Shellac Shack out of Port Orford, Oregon. Haven't tried any others....good luck.
PostPosted: Wed Jan 25, 2017 8:20 pm
I also get mine from Shellac Finishes. No complaints here. I mix it with Everclear.
PostPosted: Wed Jan 25, 2017 10:59 pm
I've only ever gotten it from either Stew Mac or LMI and both seemed to be the same to me. I use a coffee grinder too. You can almost use it an hour later if you grind it to a fine powder.
PostPosted: Fri Jan 27, 2017 1:22 am
Last Name: Howell
City: Atlanta
State: Ga
I got a batch of blond years ago that would not dissolve after a month. I was told the batch was shipped to them during the summer and got hot in transit. Messed it all up.
PostPosted: Fri Jan 27, 2017 3:12 pm
First name: Craig
Last Name: Bumgarner
City: Drayden
I use LMII super blonde. Dissolves in Everclear in about 12 hours. I don't grind it, just dump the flakes in Everclear. Does not sand particularly well, clogs 1000g paper quickly when used dry, but I'm sanding between sessions and I'm sure the shellac is not well set up.
Craig Bumgarner
Bumgarner Guitar Blog
PostPosted: Fri Jan 27, 2017 4:17 pm
First name: Alex
Last Name: Kleon
City: Whitby
I get mine from Wood Essence. Processed in Germany. I think it is the same shellac that L.V sells, but less expensive.
Alex
Users browsing this forum: Gary Davis and 167 guests
