It is currently Mon Jul 28, 2025 12:38 pm
PostPosted: Fri Apr 01, 2016 8:44 pm
I am considering counterboring the washers on the face of the head for Schaller or Gotoh tuners.
The problem is that over time as the string pressure pulls the front of the washer digs into the lacquer on the face of the head and puckers the lacquer.
Obviously you can use a commercially made counterbore-Graingers? McMaster Carr? ????????
Any other methods?
These users thanked the author Brad Goodman for the post: Bri (Fri Apr 01, 2016 8:57 pm)
PostPosted: Fri Apr 01, 2016 9:13 pm
First name: D
Last Name: S
Brad,
I use a Dremel and base to cut the counterbores freehand. First picture.
Sometimes I drill the holes in the headstock veneer before gluing it to the head. Second picture.
I like the look, and it may add some stability to the tuner shaft.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Apr 01, 2016 9:38 pm
I use the fixture described in David Russell Young's book. Simple block with a short 10mm pin centered under a drill press spindle. Tuner hole placed on the locating pin, the CB is cut with a bottom cutting end mill.
Ken Cierp
PostPosted: Sat Apr 02, 2016 6:27 am
Oh yeah, that book. I took a look at it again, he actually puts another washer under ( in the recess) the washer so the top washer sits flush.
PostPosted: Sat Apr 02, 2016 8:07 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I use these... problem solved. http://www.stewmac.com/Luthier_Tools/Ty ... l_Bit.html
It will probably be alright.
PostPosted: Sat Apr 02, 2016 9:28 am
I use this, also from stewmac. When it wears out I will probably get what Greg has.
The above bit is cool though. As long as your headstock is 15-16mm thick, counter boring from the back until the pilot guide is flush with the face (in other words, hold face down on bench and drill til it stops) the depth is correct automatically.
PostPosted: Sat Apr 02, 2016 9:54 am
Those Stew Mac tools both address a different issue (and frankly a situation, tilting tuning machines which I have never seen or had a concern). I believe the problem is simply preventing the washer from peeling away the finish by adding a CB pocket. BTW I agree its a very nice simple to produce custom feature.
Ken Cierp
PostPosted: Sat Apr 02, 2016 11:58 am
A long phase of my life was plagued with tilting tuners pulling up the finish, the problem is very real.
PostPosted: Sat Apr 02, 2016 12:28 pm
Guess I have been lucky -- but to me the Stew Mac illustration defies logic if the base hole is the correct size and the back plate is secured with a screw how can that entire machine tip as shown? However, I can see how the string "post" could move and tilt toward the bridge under tension when the nut is running out of threads, so in that regard I certainly stand corrected.
Ken Cierp
PostPosted: Sat Apr 02, 2016 6:56 pm
I just drill an 2mm starter hole though then drill from the front to match the bushing thread OD and from the back to suit the tuner stub.
Not countersunk. but the bushing is fully supported.
PostPosted: Sat Apr 02, 2016 7:20 pm
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
Until I started using the Stew Mac tool I had a consistent problem with the washers causing a milky dimple in front of the tuners due to string tension pulling on the tuner. I've never had it happen since.
PostPosted: Sat Apr 02, 2016 10:11 pm
I have had the same problems so after 40 years its time to do something about it.
PostPosted: Sat Apr 02, 2016 10:14 pm
I think it has a lot to do with the type (and thickness) of the finish. The illustration is showing an exagerated view of what is happening. It's just enough downward string pressure to pucker the lacquer -in my case Nitro.
PostPosted: Sat Apr 02, 2016 10:35 pm
+1, minus the pilot hole. I use a Lee Valley HSS brad-point bit for the bushing side, and a HSS twist bit for the back side.
PostPosted: Sun Apr 03, 2016 5:17 pm
Using a pilot hole avoids having to drill through the headstock with either large bit so no breakout coming through, and I have a centre so I can use brad point bits from the back first and then from the front to meet.
PostPosted: Sun Apr 03, 2016 8:04 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I'm guessing a pilot hole followed by a Forstner bit to relieve the headstock veneer, and then drill for the tuner shaft, would go some way to getting the headstock counterbored for the washers, and retain concentricity. Could also clamp the headstock into position and not move it till both the counterbore for the washer and the tuner shaft were drilled. No?
Peter Havriluk
PostPosted: Mon Apr 04, 2016 10:56 am
I've used a piloted counterbore. like this:
http://www.mcmaster.com/#counterbores/=11u4m9q
Then I made a UHMW "washer" that fits the shaft of the bore and locks with a set screw. That way there is no measuring just drill until it stops. Perfect every time.
PostPosted: Tue Apr 05, 2016 9:53 pm
First name: Aaron
Not a counterbore response, and more like the StewMac solution, except I'm a cheapie and don't want to fork up the $$$ for a bit. So I click on the Amazon link above, do a search for
"Atoplee 4-12mm TI-Coated HSS Spiral Grooved Step Drill Set,Triangle Shank"
And order a couple more to add to the 1 that I've had over a year.
I grind down the 12mm section, and just use the 8 and 10mm sections for tuning machines. Fits my Hipshots like a glove. I'm sure the StewMac is a tighter fit, but even this makes a LOT of difference in how the machine tightens up.
And did I say I clicked the Amazon link above?
PostPosted: Wed Apr 06, 2016 7:22 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
So if all screw-down tuners generate this issue, perhaps this is more a case of poor tuner design, rather rather than an installation issue? I realize - as an example - that the Gotoh Delta and other 'contour' tuners are very fashionable right now, but are there other tuner options beyond the Schertler open backs that do not invite the issues associated with the design?
More to the OP's point, we use a modified (smaller cutting spurs) Fuller counter-bore with depth collar for this sort of task. If the central hole is bored accurately, the counter bore will be accurate as well.
- Beth Brower
Users browsing this forum: Bing [Bot] and 19 guests
