It is currently Sat Aug 02, 2025 3:01 pm
PostPosted: Tue Mar 29, 2016 5:39 pm
City: Escondido
Zip/Postal Code: 92029
I recently picked up the "low profile truss rod" from StewMac. But unlike the hot rod truss rod it only comes in 14-1/4" size.
I like the lower profile. My necks tend to be on the thin side. However the length is giving me grief. I prefer using a 12-1/4" length rod.
Is there a source for a low profile rod in the 12-1/4" size?
 Post subject: Re: 12-1/4
PostPosted: Tue Mar 29, 2016 6:10 pm
First name: Danny
Last Name: Vincent
Always been happy with what Allied has to offer. They seem to have made a change to the rod. Presumably for the better but I have been happy with the old one. I think it would qualify as low profile. https://ssl.sonic.net/cgi-bin/alliedlut ... key=PTRFSS
PostPosted: Tue Mar 29, 2016 6:20 pm
First name: Brad
Last Name: Combs
Would the TRSDS from LMI work? I used this in a 00 recently. It looks like it takes the same channel size as the SM low profile and is 12"
http://www.lmii.com/products/mostly-not ... welded-nut
Hope that helps!
Brad
These users thanked the author bcombs510 for the post: jack (Tue Mar 29, 2016 7:23 pm)
PostPosted: Tue Mar 29, 2016 9:07 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We use Martin 2-way rods, which fit a .250" x .370" slot, and come in three lengths (overall): 14" for 14 fret acoustics, 13-1/8" for 12 fret acoustics, and about 12-1/4" for Size 5 and octave mandolin necks in the 21.5" - 22" scale length. While not called 'low profile' truss rods, they fit the same roughly 1/4" x 3/8" slot that the Stewmac and LMI rods fit. I believe Mr. Hall at Blues Creek also sells an identical rod which comes in two different lengths, similar to the Martin rods.
- Beth Brower
PostPosted: Wed Mar 30, 2016 9:32 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I ordered a couple of Martin two way rods based on advice here which was basically the same info Woodie posted above. I haven't used one yet but they seem perfect for my application. I just wanted to add that the 12 fret rod was not on Martin's website but was available. I called them and got great service, she even went and measured one for me.
Bryan Bear PMoMC
PostPosted: Sun Apr 03, 2016 11:17 am
City: Escondido
Why is the LMI and Allied ones twice the cost of any other? :shock:
Thanks for the Martin heads up. The 12th fret or the 5 size one might just be the ticket. At $13 compared to over $30 for Allied, that seems to make the most sense.
PostPosted: Sun Apr 03, 2016 11:25 am
I really like the folks over at Allied -- but I agree the price point for that TS is not competitive -- what's the value add?
Martin Guitar Maker's Connection can fix you up with a short rod -- these are my two-way rods of choice, the design and quality is exceptional.
Ken Cierp
PostPosted: Sun Apr 03, 2016 11:49 am
State: Tennessee
[quote="kencierp"]I really like the folks over at Allied -- but I agree the price point for that TS is not competitive -- what's the value add?
Sounds like its an evolution of the Blanchard dual action rod, made in house all stainless custom lengths available and a forum sponsor
FlexStrong Truss Rods
Mike Gutsch, our friend and Allied shopmate is at it again with another product from his FlexStrong line to accompany his lauded line of kerfing. Features of the new rod include:
- All stainless-steel construction
- Simple dual-action design that allows for smooth, fine adjustment (but not so fine that you risk bottoming out the threads or being overly tedious to adjust)
- Adjustment rod spins freely within anti-vibration tubing so rod can never bind up inside neck in either direction
- End blocks are a full 1" long, providing both a large footprint (less likely to compress into softer woods) and a huge braze joint.
- Induction-brazed for superior strength, reliability and consistency
- Electro-cleaned and passivated for ultimate corrosion resistance and neat look
- Custom lengths available
- Designed and manufactured right here in our Healdsburg, California shop by Mike Gutsch Guitars exclusively for Allied Lutherie
Custom Lengths
We can cut rods in any custom length under 17-3/4 inches! To order rods in a custom length, select the part number for custom length rods above and place your order, then send an email with your custom length to sales@alliedlutherie.com. Please specify the length without the nut, which adds an additional one inch the overall length of the rod.
PostPosted: Sun Apr 03, 2016 12:01 pm
Clinch -- thanks for the update, Martin rods single and double action have worked fine for me for about twenty years + now -- no failures. So the more expensive rods no matter who makes or sells them have "at least for me" -- no value add.
Ken Cierp
PostPosted: Mon Apr 04, 2016 7:52 am
First name: Willard
Last Name: Guthrie
City: Cumberland
As the boss mentioned when I asked about alternative truss rods this weekend, this shop guarantees new guitars for an indefinite period, so it becomes a case of whether we can justify using rods that do not have hundreds of thousands (really, close to 1 million) of examples in the field and no documented history of failures.
- Beth Brower
PostPosted: Mon Apr 04, 2016 8:30 am
The Martin Truss Rods also use a larger allen wrench for adjustment and in my experience, require significantly less torque to adjust. I agree with the previous posts that the quality is exceptional. The Martin rods are shrink-wrapped for the entire length that fits into the neck slot with no need worry about their being seized from glue.
Mike Franks
www.mjfranksguitars.com
www.facebook.com/mjfranksguitars
Users browsing this forum: Ken Nagy and 11 guests
