It is currently Sat Aug 09, 2025 11:29 am
 Post subject: Neck block lines
PostPosted: Sun Mar 20, 2016 2:19 pm
Hi
Just shaping up the heel and the joint lines are really visable.. didn't have lines on the last neck I made
Wasn't going to stain the neck but might have to to try and hide them
Anyone have any ideas why there showing so much ?
 Post subject: Re: Neck block lines
PostPosted: Sun Mar 20, 2016 2:42 pm
First name: Tom
Last Name: West
State: Nova Scotia
Are you very careful to get good fits.......?? Thick glue lines will show.
Tom
These users thanked the author Tom West for the post: cablepuller1 (Sun Mar 20, 2016 3:43 pm)
PostPosted: Sun Mar 20, 2016 2:44 pm
I personally don't find that objectionable, common grain matching or rather mis-matching -- I've seen some rather pricey stacked heel classical's where there was not effort at all to conceal the stack lines -- no stain, no nothing.
Ken Cierp
These users thanked the author kencierp for the post (total 2): jack (Sun Mar 20, 2016 7:16 pm) • cablepuller1 (Sun Mar 20, 2016 3:42 pm)
PostPosted: Sun Mar 20, 2016 3:22 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Have you tried wiping the heel with naptha or alcohol to get and idea what it will look like under a finish?
These users thanked the author J De Rocher for the post: cablepuller1 (Sun Mar 20, 2016 3:44 pm)
PostPosted: Sun Mar 20, 2016 3:43 pm
No haven't tried that sounds like a good plan.. are lines acceptable do you think
PostPosted: Sun Mar 20, 2016 3:46 pm
That's good to hear ..might be ok to not stain .. I like the neck unstained if I can
PostPosted: Sun Mar 20, 2016 3:54 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
When you stacked them are you sure you kept the grain all going in the same direction? It looks to me like they may have been flipped around i.e. when you cut the pieces off the end of the blank the first piece is the top piece, next piece back is the middle of the stack and the last piece is the bottom all kept in line.
"I've been had again"
Tim Benware
Creedmoor, NC
These users thanked the author Ben-Had for the post: NightOwl (Sun Mar 20, 2016 6:14 pm)
PostPosted: Sun Mar 20, 2016 4:07 pm
Yes it's possible that's what happened Ben. . Never mind. . Would you stain to try and hide or have as a feature :/
PostPosted: Sun Mar 20, 2016 4:21 pm
Who's the guitar for? I keep seeming to ask this question. If you're in the early learning stages, move along and note for next time. If it's a deal breaker for the guitar then redo it.
Personally, I don't like stacked heels however sometimes they are necessary.
PostPosted: Sun Mar 20, 2016 4:27 pm
How are you preparing those joints? Jointer, plane or sanded joint?
Hi Rod .. going to sell it if I can.. am still learning but trying to sell each one as I go to fund the next one with a bit of profit to improve my tools etc :)
PostPosted: Sun Mar 20, 2016 4:30 pm
Sanded joint Barry.. I use an electric belt sander upside down in a vice to give me a flat sanding surface... not perfect but give a good flat surface as use different grade belts
First name: Jay
City: Bothell
State: Washington
It's not terribly unusual to be able to see the blocks in a stacked heel. If you do a Google image search for "classical guitar heel" you can see a number of examples from both big guitar companies and small shop builders where the blocks are apparent. Sometimes because of lines at the joints, other times because of different grain orientations. Some builders make the blocks a feature.
I wonder if they might be glue lines as Tom suggested. I would do the wipe down with naptha or alcohol first before worrying about staining. Those lines might blend in more under finish. How finely sanded is the heel in your photos?
PostPosted: Sun Mar 20, 2016 4:34 pm
Will have a look at that on Google now thanks.. the heel has been shaped with rasp the had a quick sand over with 120 to try and remove rasp marks
PostPosted: Sun Mar 20, 2016 4:43 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
If you have a good flat surface, like a cast iron table saw top, or jointer, you can lay down some 3M Stikit sandpaper, and get a pretty flat surface in no time. I leave a couple of strips on my table saw extension for touch ups, and slide the fence over it to get a 90*.
Alex
PostPosted: Sun Mar 20, 2016 4:47 pm
Alex
Good advice thanks Alex
PostPosted: Sun Mar 20, 2016 5:25 pm
I doubt you are getting a flat surface that way. You need to finish them on a known flat surface. My small granite surface plate was cheap and I use it ALL the time for this type of thing.
So far I have mostly used stacked heels and I always reverse the grain. I think it looks more intentional.
These users thanked the author Pmaj7 for the post: cablepuller1 (Mon Mar 21, 2016 1:30 am)
PostPosted: Sun Mar 20, 2016 5:29 pm
Sanding like that will never give a great joint like Pat said. A sharp plane is the preferred way.
These users thanked the author Barry Daniels for the post (total 2): cablepuller1 (Mon Mar 21, 2016 1:30 am) • ChuckH (Sun Mar 20, 2016 9:12 pm)
PostPosted: Sun Mar 20, 2016 7:30 pm
What kind of glue did you use?
A plane is always best for gluing surfaces imho. Belt sanders almost always are too hard to control perfectly, at least for me anyway.
I would think that, if anything, stain will only accentuate the lines.
These users thanked the author jfmckenna for the post: cablepuller1 (Mon Mar 21, 2016 1:30 am)
PostPosted: Sun Mar 20, 2016 7:38 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
I also think the grain direction got reversed, but at least it is consistent in alternating. In my opinion the stack would show glue line or not. It wouldn't bother me, as I see that in many classicals - it is just how they are built. That being said, I used a heel block on my last classical, and I like the look - only one glue joint, and the cost isn't much extra,
These users thanked the author Imbler for the post: cablepuller1 (Mon Mar 21, 2016 1:31 am)
