It is currently Mon Jul 21, 2025 8:05 pm
 Post subject: Radius dish warping
PostPosted: Mon Nov 23, 2015 2:31 pm
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Zip/Postal Code: 411044
Country: india
Hello friends
i have checked the saggita of an arc from following link. its really easy to use . i hope all of u see
http://www.handymath.com/cgi-bin/arc18.cgi?submit=Entry
my radius dish has been warped. for 15 foor radius it has warped to 12' and 25 has warped to 20.5
can we make the dish flat . it is not sealed by laquer or shellac.
or shall i use the 12 and 20 radius for back and top respectively?
or can i use 20 for back and make new 25' for soundboard?
waiting for ur advices
thanks in advance
 Post subject: Re: Radius dish warping
PostPosted: Mon Nov 23, 2015 2:42 pm
I would suggest securing the dishes to a flat sub-straight which is always a good idea for any dish.
Ken Cierp
PostPosted: Mon Nov 23, 2015 2:45 pm
Warping is pretty common.
My first dishes were 1/2" thick and warped pretty quickly. I laminated them to 3/4" birch ply, and that took care of it.
The next set was made from 3/4" MDF, and they've been fine.
My third set warped, but they seem to have flattened themselves back out.
A friend slices them every inch or so with his tablesaw (just enough to give them a little flex) before gluing them to ply.
PostPosted: Mon Nov 23, 2015 4:24 pm
What James and Ken said, a backer board of some kind is a must. Mine have 3/4" plywood discs laminated to the back side and they have been stable for years. Wish I could say the same....:)
PostPosted: Mon Nov 23, 2015 5:16 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
When I made mine, I glued two pieces of 3/4" MDF together, before I routered the radius, and then brushed on three coats of oil based poly. They have stayed flat so far.
Alex
PostPosted: Tue Nov 24, 2015 12:03 am
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Country: india
Thanks friends for ur advice.
can i make a new 25' dish for top and use the warped 20 foot for back and and laminate them together?
PostPosted: Tue Nov 24, 2015 8:36 am
I believe scooping out material from the center of a plate (even metal) disrupts the surface tension and makes the plate a little unstable. So in my opinion gluing two squirrelly dishes together is not a good idea. A flat sub-straight helps to combat the forces of nature.
Ken Cierp
PostPosted: Tue Nov 24, 2015 11:30 am
If you laminate them to some flat ply, they should go back to their original radius. If you have trouble flattening them back out, you can cut or rout some shallow kerfs in them like I described to help. They should be so deep that they go through the dish in the center, but just deep enough to help with the flex.
PostPosted: Wed Nov 25, 2015 3:17 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
After attaching to a sub base I also seal mine with Zinnser's seal coat shellac.
Sent from my HTC Desire 626s using Tapatalk
Another day, another dollar.
Users browsing this forum: dan2087 and 31 guests
