It is currently Tue May 26, 2026 5:03 am
Post new topic Reply to topic  [ 135 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: Tue May 12, 2015 10:47 am
Thanks Robbie, I'll do some test panels.
PostPosted: Wed May 13, 2015 11:18 pm
City: Escondido
Zip/Postal Code: 92029
That is exactly how this one was done. TransTint black over raw maple, sanded back. Hand rubbed TransTint brown/red/amber in water. Sprayed shellac base/seal coat, sanded back, then traditional French Polish with Royal Lac.
I don't think I could have rubbed the base coat on. I think that would have pushed the tint around too much.
These users thanked the author rlrhett for the post: SteveSmith (Thu May 14, 2015 7:44 am)
PostPosted: Thu May 14, 2015 7:45 am
Awesome! That is exactly what I want the back and sides to look like.
 Post subject: Re: Spraying Royal Lac
PostPosted: Sun May 24, 2015 9:32 am
I decided to do my Seal Lac and Royal Lac test on a guitar that I re-topped a couple of years ago. It is a 1951 Gibson LG-3, and it has been sitting in my shop because I could not make myself deal with a nitro finish. I get a headache when I type the word "nitro".:>)
I was experimenting, so I tried a little bit of everything as a learning process. I knew that if I did not like the result, I put it back on the shelf and wait for the next finish to come along that was not named nitro. The finish checking/crazing is not a concern to me, because the back and sides' original finish is already crazed. I sprayed some, brushed some, and wiped some on with a little tee-shirt ball.
I sealed with De-waxed Blonde Seal Lac. I used 6 light coats on the raw spruce. I brushed 2 coats, sprayed 2 light coats, and wiped 2 light coats. I waited a day after each 2 coat session and sanded lightly with 600 grit. It is amazingly easy to sand and you will sand through very easily.
I wanted an amber colored finish, to match the look of an old natural topped Gibson, so I used the De-waxed Garnet Royal Lac. I brushed a couple of coats, waited a day and sanded, then wiped on a couple of coats, waited a day and sanded lightly with 600 grit. I gave up with the brush and tee-shirt ball. Too many streaks and brush lines. That part is operator error, so I will work on my technique for that. I sprayed the rest of the coats. I am sorry to say, I did not keep good records, but I think i put around 6 sprayed coats, sanding after every 2 coat session had set over night. I then let it sit for 2 weeks. I block sanded with 600 grit until the shiny spots were gone, and then went through the grits with foam-backed Abralon, on my PC ROS, starting with 1000 grit, up through 4000 grit. I then used 5000 grit Trizact with the foam backing. I did not compound it yet, because the sheen is just right at this point to match the sides. I compounded a small area, and it looks great, but more gloss than I want on a vintage guitar top. I went back over the buffed area with 5000 grit.
I plan to induce a little crazing in it after it sits a few days. I tried a small area and it ages just right to match the old finish.
Mine is a unique situation, trying to match a vintage look, but you owe it to your self to give this finish a try. After using the Royal Lac, I am going to finish off some of my builds, that I had laid aside, due to my dislike for nitro. On these new guitars, I will buff it out for the gloss, and hope for no crazing.
The jury will be out for a while as to the durability of the finish, but the application and finishing is a pleasure compared to other finishes. The ease of sanding means it lacks some hardness, but I'm hoping the curing process will take care of this. When I do a new build, I will wait longer on the cure time, before I sand and buff. I was anxious to see what it looked like, and am surprised that it turned out as well as it did with only 2 weeks cure time. Longer cure time will help on the shrink back in the grain lines, but that is not a concern on this guitar, since it is 64 years old, and the original top had some of the same.
I will have some pictures later.
BTW. I spent less than 30 minutes from the time I started block sanding, and running through all the grits. Most of that time was spent on the block sanding. But, even the wet block sanding is super easy and fast. I only spent a few seconds with each Abralon grit on the ROS. I was afraid I would sand through. When I went through all the grits, I was sure I would have to go back, since it was so easy. But, when I did the final grit, everything looked fine.
PostPosted: Sun May 24, 2015 11:15 am
First name: Craig
Last Name: Gordon
Zip/Postal Code: 14216
James, what are you doing to achieve a crazed finish?
PostPosted: Sun May 24, 2015 12:39 pm
I use canned air from Office Max, and invert the can, so that it will freeze the finish. I only did a small area under the fretboard extension area. You can't see it in these pictures. You can see that I sanded through the finish at the edge binding. Not a problem, since I will touch that area up once the neck and bridge are installed.
Here are some pictures of the guitar. The color variations are not as pronounced in person. There is a lot of glare on these pictures taken outside.
PostPosted: Mon May 25, 2015 7:32 pm
I am noticing some pretty severe shrinkage in the film after about three weeks post-buffing. Next time, I intend to wait longer between wet sanding and buffing, and do another wet sanding after further shrinking takes place, or simply wait a few weeks longer than the 2+ weeks I waited this time.
Everyone who has seen this finish to date loves it...
PostPosted: Mon May 25, 2015 7:41 pm
Would it make sense to wait a month before sanding and buffing?
PostPosted: Mon May 25, 2015 7:42 pm
I am expecting the shrinkage, but since this one is a vintage guitar, I will be ok with it. I will wait longer on my new builds. The neck went on today, and the bridge and pick guard will go on tomorrow. Can't wait.
PostPosted: Tue May 26, 2015 11:32 am
Yes. Very much so. It seems to be shrinking into the edges a a small patch I did on the headstock, and it wasn't there a week ago. It is also shrinking into seams between the purflings in the rosette. I've seen that with nitro as well.
I may also be getting some delaminating occurring where I sprayed it over some Eoifanes varnish. I was fully prepared for that to happen as I knew it was a big risk. Not at all the fault of the RL.
Users browsing this forum: No registered users and 69 guests
