It is currently Sun Aug 03, 2025 12:50 am
PostPosted: Sun Feb 01, 2015 11:04 pm
Online
Start with the template for the bracing layout. One for each model.
Make a block with the x angle cut into it accurately.
Use it on the mitre guage.
Fetch 'Stick With Purposeful Lump' and clip onto mitre guage.
Align it so the blade passes through the same spot every time (yes, took a while to grock that).
Choose your spacer, made by smart people by measuring, and by trial and error by people like me. Masking tape shims are your friend.
Butt your braces against Purposeful Lump and take a cut. My mitre gauge has slop in the channel, so I make sure to always press obliquely to the left so it runs at a constant distance.
Add spacer and take second pass. Then take out the spacer and nudge the braces a bit so the blade hits the center of the notch so the height is constant.
Zippetty do dah, perfectly angled press fit x joint!
Clip spacers back onto the Purposeful Lump and stow for next time.
Takes a bit of time to make the templates and angle block for each model, but saves futzing about every time you make your x's...short term loss for long term gain.
These users thanked the author meddlingfool for the post (total 3): Clinchriver (Tue Oct 24, 2017 5:55 pm) • ernie (Tue Oct 24, 2017 12:40 pm) • Terence Kennedy (Sun Feb 01, 2015 11:36 pm)
PostPosted: Sun Feb 01, 2015 11:47 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Dang, now I need a table saw.
You know that you're now going to have to file for trademarks on " Super Simple Speedy Sunday X Brace Notching System" and "Purposeful Lump".
PostPosted: Sun Feb 01, 2015 11:50 pm
Online
I don't mind sharing.... :)
I find my tablesaw very useful. It's a Bosch job site style, retails these days for around 600$. We also bought a second DeWalt one about a year ago for 300$, and it's awesome too.
These users thanked the author meddlingfool for the post: Bri (Mon Feb 02, 2015 9:48 am)
PostPosted: Mon Feb 02, 2015 12:04 am
First name: Trevor
Last Name: Gore
City: Sydney
Only if you really want one.
The same idea will work on a router table. I use a similar sort of fixture for making lattices on a router table.
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post: J De Rocher (Mon Feb 02, 2015 1:27 am)
PostPosted: Mon Feb 02, 2015 12:14 am
Online
I know my tablesaw sees a lot of use. Enough to buy one for each end of the shop...
PostPosted: Mon Feb 02, 2015 3:00 am
First name: Edzard
Last Name: Kolks
City: Eindhoven
Country: The Netherlands
Nice!
This will do the trick too:
http://www.bridgecitytools.com/default/ ... maker.html
Regards,
Edzard
PostPosted: Mon Feb 02, 2015 5:34 am
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Good job, but why don't you have a length of birch ply permanently screwed on to the miter gauge to act as a cross-cut fence?
PostPosted: Mon Feb 02, 2015 6:04 am
Nicely done. You might consider an Incra fence. It can be adjusted to fit the table saw channel without slop and is also more easily set for the angles.
PostPosted: Mon Feb 02, 2015 7:22 am
Here's an adjustable "X"notch jig that does not require power tools -- just a razor saw.
http://www.kennethmichaelguitars.com/Xb ... guide.html
Ken Cierp
PostPosted: Mon Feb 02, 2015 7:36 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Thanks for sharing that, Ed. If I can make one suggestion, though - make a zero clearance insert for each of your table saws! You'll get cleaner cuts on the bottom side of the wood, and off cuts won't get caught or ping back at you! Great terminology, as well. Now all I have to do is find a mitre gauge for my 1" mitre slot. [headinwall]
Alex
PostPosted: Mon Feb 02, 2015 7:48 am
Great idea. You can take the slop out of your miter gauge by pinging the sides with a spring punch.
Ken Jones
Mountain Song Guitars
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Mon Feb 02, 2015 10:01 am
Online
Haven't found the need as of yet...
PostPosted: Mon Feb 02, 2015 10:03 am
Online
I have one for a different gadget that I'm workiing on, maybe I'll give it a try. The slop in the runner is real easy to account for by making sure the bar runs against the edge...
PostPosted: Mon Feb 02, 2015 10:05 am
Online
I have them for some tasks, like when using the fretsaw blade for cutting purflings...
PostPosted: Mon Feb 02, 2015 6:14 pm
State: Tennessee
Tablesaw good :mrgreen:
Thats pretty much how I do it, I've just been creeping up on the width but the spacer is a nice addition
PostPosted: Mon Feb 02, 2015 7:03 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
This is one of the jobs that is very satisfying with a fine toothed back saw and a chisel - a great skill to have. Kind of like learning to grind and sharpen your edge tools without a jig. Much quicker than locating the jig, setting it up, etc.
And Ken's little jig is a nice addition.
Ed
PostPosted: Mon Feb 02, 2015 7:51 pm
First name: kurt
Last Name: thomas
City: colden
State: ny
Zip/Postal Code: 14033
Maybe a dumb question, but the spacer needs to be the exact thickness of the braces, correct? And.. the depth of the cut is right at half the height of the brace(s). This looks much better than my hammer and flat screwdriver method.
_____________________________
Kurt Thomas
"There's a first time for everything even if you do it by mistake."
PostPosted: Mon Feb 02, 2015 8:33 pm
State: Tennessee
I'd like to hear Ed's take on this also, I like a tight press fit, thumb and finger tight so mine would be a few thousandths under. And yes on 1/2 the height.
PostPosted: Mon Feb 02, 2015 9:57 pm
Online
I personally go a little past halfway as there is still the bottom radius to be shaped. So about .010 extra, which leaves you a bit of wiggle room to put in your radius.
The combined width of your blade and spacer should be the width of your brace., minus a few thou for a tight press fit. I think...I made mine via trial and error...
PostPosted: Mon Feb 02, 2015 10:20 pm
You can also cut them just a little tight and sand a few thou off the sides of the brace with a hard sanding block to fine tune a squeek fit.
I've used a router jig I copied from Charlie Hoffman for the last 10 years but I like this saw thing, lots quicker to set up.
Thanks!
PostPosted: Tue Feb 03, 2015 1:25 pm
Last Name: Beaver
City: Lake Forest
Good stuff Ed. I like the way you think.
Joe Beaver
Maker of Sawdust
PostPosted: Tue Feb 03, 2015 1:37 pm
Online
The way I think is to make things as simple and easily repeatable as possible with the minimal amount of thought required so I don't have to stand there and go, 'Hmm, how's that go again?'...
PostPosted: Tue Oct 24, 2017 11:48 am
No kidding! I was standing there looking at this really cool sweet jig that I made going, "Hmm....I wonder what this is for..." I'm going to start writing more notes on them.
PostPosted: Tue Oct 24, 2017 11:58 am
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
Slick! But my table saw is currently a fancy base for my home made drum sander and buffer. It takes more time to change back to table saw mode than it does to use my razor saw. But I love the simplicity and repeatability of the setup!
Tony Thatcher
Bozeman, Montana
PostPosted: Tue Oct 24, 2017 12:14 pm
Online
Now I use a dado blade instead of a regular blade and spacer.
I use my Laguna bandsaw for basically all my straight cuts now, so the tablesaw has he dado in full time and is used for only two jobs, x brace joints and truss rod slots which use the same blade.
I cut the x's now just a hair thick and then sand them to about .005 oversized on the drum sander for a nice tight fit.
Users browsing this forum: meddlingfool and 34 guests
