It is currently Tue Aug 05, 2025 9:18 am
PostPosted: Fri Jan 09, 2015 4:10 pm
First name: Linus
City: Brooklyn
Zip/Postal Code: 11215
If I want to bend some BIG acoustic bass guitar sides (7+" wide - in the style of an Ernie Ball Earthwood Bass) can I get by with wide steel slats but a regular 5" wide blanket? The form will be the same size as the sides.
In other words, do I have to by a wider blanket to do the bend?
These users thanked the author Linus for the post: dberkowitz (Sat Jan 17, 2015 10:30 am)
PostPosted: Fri Jan 09, 2015 4:37 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
I've bent such sides and simply used a bending iron. Not hard to use and once you get the hang of it, one can easily bend a side in about 10-15 minutes. For a while I thought about getting set up with a bending machine but I have now shelved the idea as bending by hand is one of the more enjoyable steps to building for me. I do use a spring steel backing strip for more difficult species and spray everything with SuperSoft2 prior to bending. I spray again afterwards, clamp into the outside mold and leave overnight for near perfect results.
Doug
PostPosted: Fri Jan 09, 2015 5:08 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Aren't most blankets 6" wide? Even at 6", I can't see it working well with 1/2" of wood on either side going unheated. I would think it would not get hot enough to go plastic thus cracking when you tried to bend. This is all speculation on my part though. I'd do it on a hot pipe. Then if I felt like I needed to eve out some of the bends I would cook it in the bender hoping that the edges being close to the final bend would get me where I wanted to be. You could also bend the waist on the pipe and clamp it in the bender while still hot. Allow it to cool and then do the same for the lower bout followed by the upper. . .
Bryan Bear PMoMC
PostPosted: Sat Jan 10, 2015 11:15 am
Get a pipe.
Users browsing this forum: Bing [Bot], DennisK, guitarjtb, oval soundhole and 16 guests
