It is currently Sun Aug 03, 2025 6:17 pm
 Post subject: Spraying Cyanoacrylate
PostPosted: Tue Dec 02, 2014 6:42 pm
First name: Logan
Last Name: Sarchfield
State: AB
Has anyone ever sprayed cyanoacrylate?
The Bourgeois aged tone series has a cyanoacrylate based finish. I'm wondering if anyone else has used it to finish a guitar. It seems like a good product to finish with, very hard, coats should burn in, and short finish schedule.
PostPosted: Tue Dec 02, 2014 7:01 pm
I'll take my lung cancer in nitrocellulose...
PostPosted: Tue Dec 02, 2014 7:31 pm
First name: D
Last Name: S
There was a recent thread about it here.
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Dec 02, 2014 8:31 pm
First name: Victor
Last Name: Seal
City: Osseo
Zip/Postal Code: 49266
I would recommend that you research the MSDS for CA before making it airborne. Wicked stuff.
PostPosted: Tue Dec 02, 2014 9:48 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I just did a head stock veneer on a completed ukulele using gear-up fill and finish and it came out really nice. It buffed out to a great finish. On the same ukulele I pored filled the back and sides with the same product. That also went well.
For the finishing I used the method shown on a video on their site. I used small drops on a folded paper towel and padded it on, sprayed with their accelerator, sanded level with the green 3m polishing paper and repeated this four times. I then sanded up through a few of the grades of the polishing paper and buffed it out. The whole process took about 20 minutes.
I could see doing a ukulele this way, not trying to spray it. When padding it on you get a very thin layer. A larger instrument might be a bit intense fume wise.
PostPosted: Tue Dec 02, 2014 10:00 pm
The thought of attempting to spray CA is going to give me nightmares.
As they say - please don't try this at home.
For that matter, don't try it anywhere. Maybe if you donned a full astronaut suit and set up a disposable spray booth with a Teflon fan and ductwork, maybe. Short of that, no. I wouldn't even consider trying it. Even beyond the obvious health risks and having to wash your hair in acetone to get out the overspray - atomized cyanoacrylate swirling through the air - what a god awful mess that would create.
PostPosted: Tue Dec 02, 2014 10:16 pm
Last Name: Russell
State: Michigan USA
I wouldn't mess with the stuff for anything. I keep a bottle of CA glue but only use it when necessary and rarely on guitars.
I worked as a auto painter for over 20 years and I always wore a respirator when spraying lacquer and 3M dust masks when dry sanding because I really care about breathing... I flat out refused to spray 2K urethanes and that is the main reason I quit painting cars and found another profession.
When you have to wear a hazmat suite with piped in air to spray paint that tells you something about how dangerous it is.
CA is worse than 2K urethanes so I personally don't use it. It is great stuff but quite dangerous for your health let alone trying to atomize it to spray it on a guitar...
I say don't even try it if you like breathing.
Bob
PostPosted: Tue Dec 02, 2014 10:57 pm
That sounds like a recipe for a one way trip to the ER.
PostPosted: Tue Dec 02, 2014 11:26 pm
First name: Logan
State: AB
Sounds like I'll just stick with shellac for now. Shellac mixed with everclear or medical grade ethanol is probably the most benign finish available.
I pore filled with cyanoacrylate once and my lungs were messed up for days. I don't use it now without a respirator on. I was thinking spraying with a respirator and chemical goggles might be ok. I was also thinking the fast drying time would be great. After reading the comments above I'll just stay away from it.
I was also going to try minwax wipe on poly, I've read good results. I would have to leave it in the garage to dry which would only work in the summer. With shellac I can do all the finish work in my spare room.
PostPosted: Tue Dec 02, 2014 11:57 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Not even remotely a good idea.
PostPosted: Wed Dec 03, 2014 12:28 am
First name: Jamie
Last Name: Unden
City: Lakeside
Zip/Postal Code: 92040
You'll glue your lungs shut!
PostPosted: Wed Dec 03, 2014 3:22 am
You guys are using the wrong CA. I've done four guitars with non-fuming (or foam safe) CA. I use a respirator as a precaution but I probably only need it for the accelerator. I used to use Bob Smith Industries medium viscosity Super Gold but it's very expensive, about $25 for a 2 ounce bottle. I could do a guitar with 3 bottles but that's more than I want to spend. Now I use Starbond thin odorless. It's about $80 for a 16 ounce bottle. I pad on some BSI accelerator, since I have it. I let it flash off and then spread thin layers with black Duraskin powderless nitrile gloves. I sand lightly between coats with 320 gold paper. After 5 coats I level pretty aggressively. Then I do one final coat and sand 400, 600, 1500 and buff. It doesn't gas off for days like other finishes. It does blush some like the amine blush you get from epoxy but not as badly. I wouldn't use a paper towel to spread it because it would probably use up too much product. Could you spray it? Maybe, but you'd waste a lot doing so. The folks at Starbond told me that they sell most of it to people who do 3D printing. I only do one coat a day but I could do two pretty easily. It will shrink back some so it's better not to rush it. Sorry I don't have more pictures right now.
Ken Franklin
clumsy yet persistent
These users thanked the author Ken Franklin for the post (total 2): TimAllen (Fri Dec 05, 2014 8:04 pm) • Goodin (Wed Dec 03, 2014 8:59 am)
PostPosted: Wed Dec 03, 2014 3:57 am
What is the purpose of accelerator if you do only one coat a day?
PostPosted: Wed Dec 03, 2014 6:55 am
Ken,
Are you able to pore fill and level with the 5 initial coats on a porous wood like mahogany?
Chuck
PostPosted: Wed Dec 03, 2014 8:06 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
From hearing Dana's description of the finish during his presentation at the last ASIA symposium Where he described as " a cyanoacrylate type finish with a urethane type molecular bond" I and some others came to the conclusion that was a mystical spin put on modern conversion varnish.
Brian
PostPosted: Wed Dec 03, 2014 9:34 am
City: Tyler
If it were sprayed, how would you keep the gun from clogging up?
PostPosted: Wed Dec 03, 2014 10:42 am
Unlike the BSI CA, the Starbond took a long time to cure without the accelerator. The accelerator improves the spreading characteristics and I can apply a thicker coat. There is a learning curve with this though and things are pretty lumpy after five coats.
Ken Franklin
PostPosted: Wed Dec 03, 2014 10:48 am
ChuckB wrote:
Ken,
Chuck
That's a mahogany neck in the picture. The pores are filled after 2-3 coats. That's what I used to do for pore filling when I was spraying catalyzed urethane as a topcoat.
Ken Franklin
PostPosted: Wed Dec 03, 2014 11:21 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Ken have you had any sand-throughs with CA and if so does it leave a witness line? Im curious how CA works as far as a build finish..if it melts into the finish below like lacquer or layers on top like varnish.
Starbond also makes aerosol accelerator spray. Have you tried that?
I saw a demonstration at ASL recently - wipe on Starbond medium with a paper towel - take outside and spray accelerator, immediately sand with 320, do it again, and the pores are filed. Cant wait to try this on the next guitar.
PostPosted: Wed Dec 03, 2014 12:35 pm
The tip on the spray gun would be glued closed after a few passes. I once took an old spray gun before throwing it away and tried this and that was what happened. Some info on sanding cyanoacrylate glues. The flumes are not the thing you want to worry about so much. It just burns your eyes and such and is not so great for you. It's the dust from dry sanding the glue that is the problem! OSHA came to SCGC when I ran the finish dept. and they told us that the dust from the cyanoacrylate was one of the most harmful things to the lungs in the whole shop. The dusts finest particles are so small that they go deep into your lungs to the point of not being able to come out. Just be safe as always!
These users thanked the author AddamStark for the post (total 2): Pmaj7 (Sat Dec 06, 2014 1:25 pm) • TimAllen (Fri Dec 05, 2014 8:06 pm)
PostPosted: Wed Dec 03, 2014 1:48 pm
No witness lines. I do sand through occasionally and it's not much of a problem. Just takes more time to finish. The layers do melt into each other. As Adam says you need a dust mask for the dry sanding. I haven't used the Starbond aerosol accelerator but I bet it's good. I just have a lot of the other accelerator so I'm going to wait until it runs out until I try something else. I like the accelerator below the CA so I'm sure the CA cures well, especially in the pores.
Ken Franklin
These users thanked the author Ken Franklin for the post: Goodin (Wed Dec 03, 2014 2:12 pm)
PostPosted: Wed Dec 03, 2014 2:44 pm
Trying to think of a new name for Black Lung. "Glue Lung."
PostPosted: Wed Dec 03, 2014 5:12 pm
First name: Coe
Last Name: Franklin
City: Decatur
I have it.
Yeah, it sucks.
PostPosted: Thu Dec 04, 2014 3:36 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
This just seems like a horrible idea. CA kicks off in the presence of moisture...I can just imagine someone inhaling a lung full of atomized CA. *POOF* no more lungs.
Even if there may be one or two ways to do this responsibly, IMO this thread should be deleted before it encourages someone with less than the required materials and equipment to do it the wrong way.
Trevor
http://www.PeakeGuitars.com
These users thanked the author Parser for the post (total 2): Lonnie J Barber (Sun Dec 07, 2014 5:49 pm) • dnf777 (Sat Dec 06, 2014 9:57 am)
PostPosted: Sat Dec 06, 2014 9:33 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Have you noticed any changes to the sound of the guitar
James W Bolan
Nashville Tennessee
Users browsing this forum: Ken Lewis and 37 guests
