It is currently Fri Aug 08, 2025 1:48 am
 Post subject: 20th Fret width
PostPosted: Sun Nov 16, 2014 10:44 am
First name: herry
Last Name: trismono
City: malang
State: east java
Zip/Postal Code: 65142
Country: Indonesia
Hi, hello, I need help about my 20th fret width
I'm building 34" electric bass with Precision Bass pickup neck through body, 80%done, but, when I measured nut width 42mm and oops_sign 20th fret width just 52mm (heel) idunno duh
What you think? about 20th fret width just 52mm, is that too narrow? what should I do?
I need your suggestion, thank you so much
herry tze [uncle]
 Post subject: Re: 20th Fret width
PostPosted: Sun Nov 16, 2014 11:34 am
Well, without knowing the string spread at the saddle, the number is somewhat irrelevant .... your saddle width, and 12th fret fingerboard width need to be close, the fingerboard could be smaller by a couple mm (mine usually are on a SS) .. does the bridge you plan to use feature adjustable string spacing ?? - some bass bridges do ...
PostPosted: Mon Nov 17, 2014 1:53 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
Hi Tony, this is the picture, I mean with the narrow saddle spread spacing: 15mm and the wider pbass picktup, is that produce true sound or good sound? thakn's
PostPosted: Mon Nov 17, 2014 8:43 am
what is the string spread on the pickup poles .. cant tell from that picture .... what is the typical string spread on a fender ?? check your local guitar shop, or maybe online somewhere ...
These users thanked the author TonyKarol for the post: herry tze (Mon Nov 17, 2014 8:10 pm)
PostPosted: Mon Nov 17, 2014 10:28 am
First name: Matt
Last Name: Cushman
City: Great Falls
State: MT
Zip/Postal Code: 59401
A width of 52mm seems a little bit slim. You may be able to add some binding to the fingerboard to gain some width. If you do add binding. In order to keep the proper taper of the fingerboard you may have to shave a little from the nut end of the board. If you use it the way it is the bridge will need to be adjustable or maybe 4 individuals would work. The standard spacing for a bass bridge is about 60mm.
http://www.cushmanguitars.com/.
A man who carries a cat by the tail learns something he can learn in no other way.
Mark Twain
PostPosted: Mon Nov 17, 2014 8:12 pm
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
Thank's Cush, I will do to add the binding, thank's so much bliss pizza
