It is currently Tue Jul 29, 2025 10:00 am
PostPosted: Tue Nov 04, 2014 11:41 pm
I hope to be retired completely within 7 months. As such I am trying to make sure I have the tools I need to build guitars. have been a wood carver for 30 plus years but have never built a guitar. I have the following power tools: band saw, drum sander 16x32, belt sander, hand drills, palm sander, portable circular saw, and router. I don't know if I need more power tools or not but if you think I do please let me know. I'm thinking a drill press may be needed but don't know for sure.
As for hand tools I have a number 6 surfacing plane, a low angle block plane, scrapers, many carving gauges, an accurate 24 inch straight edge, fractional calipers, 3 and 6 inch squares accurate to .001, an LMI tool to make the cut outs for the rosette, straight chisels and skew chisels. I know I will need files for doing the nut and bits with bearing to do the purfling, but I am sure there are many other tools I need and just don't know yet what they are.
Therefore, I would appreciate folks suggesting what additional tools I need, power or hand, so I can get started with the right tools and not end up buying things I don't need and missing what I do need.
Thank you for your suggestions,
Chuck
PostPosted: Wed Nov 05, 2014 12:19 am
Congrats on your looming retirement!
You can build a guitar with the tools you have, if you're willing to buy certain parts that are pre-machined. For example, you'll either need to be your fret boards pre-slotted or buy some tools that will allow you to cut fret slots.
I would suggest that you pick up a book like the Cumpiano book. You'll get a good sense of what tools you want to invest in from that. You can build a guitar with the tools you already have. But if you're going to build more than one, you'll certainly be buying more tools.
PostPosted: Wed Nov 05, 2014 12:28 am
Last Name: G
Andy Birko made a nice list of the tasks/tools that was so nice that it should be mentioned. It's here:
viewtopic.php?p=483054#p483054
cheers
These users thanked the author SteveG for the post: CraigG (Wed Nov 05, 2014 8:48 am)
PostPosted: Wed Nov 05, 2014 1:56 am
There are a lot of ways to do everything. Andy's list is about right. Sounds like you're mostly set. I wouldn't worry about getting things you might need in the future. Instead get them as you need them. There are a ton of videos on youtube that walk you through most of the steps. You can see lots of tools and options there.
Since you're here, I assume your main interest is acoustic guitars? Steel strings?
Looking at your tools, some things to start shopping for or building include
1 Neck shaping - rasps and or spoke shave
2 Side bending - bending machine or bending iron
3 Clamping kerfed linings - binder clips usually work well
4 radius dishes for profiling the sides and clamping the braces - though there are alternatives in both process and design
5 Binding channel - there are a lot of ways to do that. Start looking into them so you know what you want when you get there.
6 Patience
7 Little planes like those made by Steven Booth or if you can't get those, the Ibex - not needed but make brace shaving so much easier.
8 If you're looking for an excuse to buy more power tools, I keep wanting a big edge sander. Maybe you need one too.
9 Dust collection - don't skimp here.
10 Certainly not required for guitars, but I can't do anything without firing up the tablesaw once or twice. They make cutting fret slots easy, but there are perfectly good hand tool jigs that work well too.
11 I find good quality nut slotting files are shockingly expensive and totally worth it.
12 Safety goggles.
13 Go bar deck and bars - very useful
Drill press - I use it some for guitars, but they're just so useful all the time, everyone should have one. Preferably with a better chuck than I have.
Welcome to the hobby. Lots of help here for the asking.
Mike Lindstrom
PostPosted: Wed Nov 05, 2014 9:07 am
6 Patience
12 Safety goggles.
Looking at what you have to say I have to add that I have the following already:
a side bender than I have already built
Jet dust collection system
Safety glasses
Spoke shave
Inner and outer molds for L-00 that I have built (I know that is probably not the correct terms but as I said I am just learning)
I also have a 6 inch planer
I also have the Cumpiano Natelson book Guitarmaking Tradition and Technology. I will look at the tools they recommend and also will add to the list the information from the other posts above.
How do you use a table saw for making the fretboard? Wouldn't the kerf be way to wide for the fret wire or is it used to cut the sides to the right dimensions ?
Any other suggestions?
I am planning on building a steel string L-00 as my first guitar.
Thanks for the responses,
Chuck
PostPosted: Wed Nov 05, 2014 9:30 am
There are special thin blades for fretboard slotting. Sounds like you're in good shape. Now just start hoarding wood.
Oh! What about humidity control? Not absolutely needed, but sure helps avoid problems.
Mike Lindstrom
PostPosted: Wed Nov 05, 2014 2:40 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
To some degree, the tools you need depend on your building technique.
What I mean is there are usually several techniques for any task, and some of those techniques are tool dependent.
Go with what you have until you need something better, you'll know when you need something better.
These users thanked the author Rodger Knox for the post (total 2): Bryan Bear (Fri Nov 07, 2014 9:56 pm) • Lonnie J Barber (Wed Nov 05, 2014 8:01 pm)
PostPosted: Wed Nov 05, 2014 9:51 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
What hand and power tools do I need?
All of em!
Sorry, couldnt resist.
The many unique and specialized jigs, try making your own.
B
PostPosted: Thu Nov 06, 2014 2:16 am
I live in the Northwest close to Seattle so my humidity is frequently around 45-50 percent in the house all winter. I can leave out a guitar or two sitting on a stand, no kids no dogs no cats, and not have to worry about cracks or problems with splitting. At least the rain is good for something.
Chuck
PostPosted: Thu Nov 06, 2014 5:28 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Got enough clamps?
Whatever answer you just gave - the fact is that you can never have enough clamps.
But you do have a lot of great stuff, so just jump in and make a guitar!
cheers
Mark
PostPosted: Thu Dec 04, 2014 1:51 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Mark Mc wrote:
Got enough clamps?
cheers
Mark
There's two ways to identify a luthier. laughing6-hehe
1. They don't have enough wood.
2. They don't have enough clamps.
PostPosted: Thu Dec 04, 2014 2:29 pm
First name: Greg
Last Name: B
City: Los Angeles
A drill press is awfully useful for the headstock tuner holes, and drilling the pin holes for the bridge.
A spokeshave for carving the neck is something I couldn't do without.
And +1, you can't have too many clamps... :D
PostPosted: Fri Dec 05, 2014 7:13 pm
First name: D
Last Name: S
A precision straight edge comes in handy for fretboard work.
I could not do without my nut slot files.
A loving wife that lets you commandeer the entire garage is essential.
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Dec 05, 2014 8:27 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Were I live, that garage is useful for guitar making for about 4 months in the summer - the rest of the year it is good for monkeys with brass cojones....
PostPosted: Fri Dec 05, 2014 9:03 pm
First name: Kerry
Last Name: Werry
City: Coquitlam
How True!!!
Chisel or two (or more) I assume you have some
My Website http://klw-strings.com
My Luthier's Blog...http://klwstrings.blogspot.com
Users browsing this forum: doncaparker, Powdrell1 and 9 guests
