It is currently Fri Aug 15, 2025 6:39 am
PostPosted: Sun Sep 07, 2014 6:09 am
First name: David
Last Name: Ferraro
City: Franklin
State: Pennsylvania
Zip/Postal Code: 16323
Looking at adding a drum sander to my shop, and have narrowed it down to Jet or Grizzly. Been happy with both brands in the past and with current tools. Question is, do the open-ended sanders *really* give consistent thicknesses across the entire surface, as opposed to the grizzly models which have adjustment rods on BOTH ends of the drum? Seems the advantage is you can get a slightly smaller (ie, MUCH less expensive) open ended machine and just run pieces through twice.....IF it gives accurate results. Any thoughts? Thanks
PostPosted: Sun Sep 07, 2014 6:42 am
I would go with the Jet. While open ended sanders can "flex" if you take your time and remember to flip the work and don't hog, take small bites it will do fine. Also use 80 grit paper or even 60 for rosewoods. Keep the paper clean and replace as soon as it gets loaded up. It will do you well. This is a thickness sander , not a finish sander so just allow a few extra thous for hand sanding.
PostPosted: Sun Sep 07, 2014 7:38 am
First name: Victor
Last Name: Seal
City: Osseo
Zip/Postal Code: 49266
I have the Jet. It can be adjusted/set up by removing the sandpaper and running the drum down until it contacts a block of some kind equally on both ends of the drum. I use a 6" ruler set on edge. The manual that comes with it explains this adjustment very well. I have found that it REALLY improves performance if you take your time and don't try to take too much off at a time.
PostPosted: Sun Sep 07, 2014 8:29 am
I have the Jet also and I tend to set the drum to take off a little more on the drive end so that I can put a little taper into the top and back.
PostPosted: Sun Sep 07, 2014 9:45 am
I've had the Jet/Performax 18/36 for about 8 years. It's been fine. Loading dramatically decreased when I upgraded to a 3hp Oneida cyclone with 6" lines and put the sander on the first drop.
PostPosted: Sun Sep 07, 2014 10:42 am
I've got an 18/36 Hausmann (rebadged Grizzly) and it is functional. As has been said, go slow.
They can be set up quite accurately.
I bought a Delta 18-36 as well and like it a lot more. Mostly for paper changes which is very quick compared to the other.
PostPosted: Sun Sep 07, 2014 11:23 am
First name: David
Last Name: Ferraro
City: Franklin
State: Pennsylvania
Thanks for all the great advice. Seems like the manufacturers know there is a significant jump around the 20" width, and make that a quantum jump in price! Given the advice above, I will feel quite comfortable trying the 18" open models. Just by looking at photos, it would appear that the delta and grizzly are the same machine with different paint/logos? I did not realize the drum was adjustable--making it thicker at one end to bevel is a great idea. Nice to know I can save around 800 by not needing the 24" models...but then again "save" is a misnomer, as it will just be put towards other tools!
PostPosted: Sun Sep 07, 2014 11:28 am
No, I do not believe the delta and grizzly are the same machine. I believe the grizzly and the Hausmann (Rona's house brand in Canada) are the same machine...Image
PostPosted: Sun Sep 07, 2014 11:40 am
First name: David
Last Name: Ferraro
City: Franklin
State: Pennsylvania
Nope, definately not the same. I think I was looking at a smaller machine--maybe 16"? More likely to be outsourced than the nicer big machines. Anyhow, Jet has a factory 10% sale going on, so there's an extra 100 off, so that helps the decision process a little. Not that price is the only factor, of course.
PostPosted: Sun Sep 07, 2014 12:06 pm
Better off with an 18" for sure.
PostPosted: Sun Sep 07, 2014 12:51 pm
First name: David
Last Name: Ferraro
City: Franklin
State: Pennsylvania
Yeah, that's what I figured. 18" better than 16", but will have smaller footprint in my small shop than a 24", and will leave around a grand in my pocket....which will promptly burn a hole I'm sure....
Thanks again for all the replies. Just wanted to make sure there were no major regrets with an 18, and I feel much better about it now.
Dave F
PostPosted: Sun Sep 07, 2014 1:34 pm
Shops are an endless money pit.
These users thanked the author meddlingfool for the post (total 3): Lonnie J Barber (Sun Sep 07, 2014 8:35 pm) • Alex Kleon (Sun Sep 07, 2014 3:28 pm) • John Sonksen (Sun Sep 07, 2014 1:58 pm)
PostPosted: Sun Sep 07, 2014 3:43 pm
Shhhhh. Don't tell my wife
PostPosted: Sun Sep 07, 2014 4:36 pm
It gets worse when it stops being a hobby....;)
PostPosted: Sun Sep 07, 2014 5:10 pm
Last Name: Colbert
City: Anacortes
Have you looked at the Supermax 19-38?
PostPosted: Sun Sep 07, 2014 8:29 pm
First name: Mark
City: Concord
What small amount of flex you see can be canceled by flipping the board and run it through a second time. I ran across this idea a while back and thought it would be a good idea (and void the warranty on a new sander) if flex was a big concern:
The photo on the infeed table shows a Ryobi WDS1600 sander from before they made disposable tools with a sliding metal brace attachment. Fortunately I was satisfied with my sander's performance and never had to use it.
PostPosted: Sun Sep 07, 2014 8:45 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
Those are fancy. I built my own. Even with a 3hp motor I've found to go smooth and slow. Works better that way.
PostPosted: Mon Sep 08, 2014 7:54 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I have the Supermax 19-38 which is open ended and it is absolutely dead flat across the entire surface. It is a very robust and well built machine.
http://www.supermaxtools.com/products-s ... um-sander/
PostPosted: Mon Sep 08, 2014 2:29 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
If you have room and can afford them, the sanders that can fit a whole top or back at once are great. However, if you either don't have room or that much money, a Jet (Performax) 10-20 works fine. I really like mine. Having to make two passes for each plate is not that big of a problem. Proper adjustment is important with the open end sanders. My 10-20 has never given me problems. Happy user here.
PostPosted: Mon Sep 08, 2014 5:09 pm
Absolutely nothing wrong with the 10-20 or 16-32. They get the job done for less. I have the 16-32 and never run a full 16". Always run half and turn it around.
PostPosted: Mon Sep 08, 2014 9:58 pm
"It gets worse when it stops being a hobby....;)"
Kinda like drugs......
I have a Ryobi 16/32 that I bought used. I don't think I'll upgrade until I really find a need. I try to keep my addiction at a manageable level.
PostPosted: Sat Sep 13, 2014 5:31 pm
First name: Les
Last Name: Sardi
City: Calgary
State: Alberta
Zip/Postal Code: t3k4m4
I have just purchased the supermax 19-38 as well, have not recieved it yet. It came highly recommened.
PostPosted: Sat Sep 13, 2014 10:05 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
My Jet (performax) 22/44 is very reliable. Never had a flex issue. Joe Woodworker has a great technique for setting up. I posted a link to it in the tutorial forum. Once set, u should never have to redo it.
PostPosted: Sun Sep 14, 2014 4:57 pm
Last Name: Killin
I have the Ryobi 16/32 and love it. I'm sure bigger would be nicer, but I don't see where I need it.
I bought mine used and the previous owner did a great job setting it up. I never had to touch it even after the trip from his place to mine and the move onto the cart I built. My understanding with the Jets is that the adjustment process is easier than on the machine I have. If I were buying new, that is the brand I'd be looking at.
If I go slow I don't have issues with the flex. The biggest thing I have seen is watching the paper. Changing it when it needs it and going slow. Actually thinking of a larger sander makes me think of the extra cost in changing paper. If you burn a 2" strip out right in the middle, then you still have to change the entire drum.
PostPosted: Sun Sep 14, 2014 10:24 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
You should never burn out a segment. Always pass stock through at an angle so entire drum is in use. This keeps local temperatures down and contributes yo even wear of paper. Yes, straight pass on final cuts to align grit lines with grain, but u only need 2-3 passes like that.
Users browsing this forum: Chris Ide and 16 guests
