It is currently Tue Jul 29, 2025 10:38 am
 Post subject: Bone for Inlay
PostPosted: Thu Jun 26, 2014 4:37 pm
Last Name: Cavanaugh
City: Saint Paul
State: MN
Does anyone know of a supplier of bone shapes for inlay? I'm mostly interested in side marker dots and fretboard dots.
Thanks.
John Cavanaugh
Saint Paul, MN
"What could possibly go wrong?"
 Post subject: Re: Bone for Inlay
PostPosted: Thu Jun 26, 2014 4:43 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
John I know this might be gross. But about 25 yrs ago I stole a big beef leg bone from my dog. I'm still using on it. eBay is the only other place I know
These users thanked the author Lonnie J Barber for the post: Mark L. (Fri Jun 27, 2014 4:29 pm)
PostPosted: Fri Jun 27, 2014 3:25 am
First name: Michiyuki
Last Name: Kubo
State:
Country: Österreich
Hi Lonnie, what method did you use to cure the bone?
久保
美智え
PostPosted: Fri Jun 27, 2014 7:21 am
First name: Tom
Last Name: Armstrong
City: Portsmouth
Zip/Postal Code: 23701
Go to your local Petsmart store....already cured.
PostPosted: Fri Jun 27, 2014 8:20 am
I don't know of anyone that sells bone dots but you can make them using a fuller type countersink with the drill bit reversed and retracted to leave a cavity in the center. In the past I have used old piano key tops as a source of material.
PostPosted: Fri Jun 27, 2014 8:39 am
If you just want dots, chuck a square length in a drill and turn it round. I do it all the time to make tortoise dots for my instrument's side dots. File and sand till you get the diameter you want, drill the hole in the F/B. superglue the whole dowel in and finally use a fine saw to cut it off.
PostPosted: Fri Jun 27, 2014 8:56 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
i/ve used plug cutters from harbor freight to make dots. Have made lamb bone by boiling in hot water /vinegar to get rid of the fat to make saddles.
PostPosted: Fri Jun 27, 2014 8:59 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I have not found any pet stores that sells cow bones. All I have found are ground up bones pressed into the shape of a bone.
Typhoon Guitars
PostPosted: Fri Jun 27, 2014 9:52 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
I'm about to cut up a deer antler for nut/saddle for my local materials challenge build. Very hard and dense. Don't see any reason for why it could not be used for inlay. Has anyone else used antlers? Whitetail for those of you who care. Three point.
Doug
PostPosted: Fri Jun 27, 2014 10:49 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
I've used all sorts of horns and antlers. Usually the tips are the best as they are solid. When you have a curved piece it's sometimes hard to cut out a wide enough flat piece. If you place the horn in the oven on LOW HEAT they go soft and you can clamp the piece flat. Watch out! If it over heats, the horn bubbles and is ruined.
If you get horn that is translucent and cut a thin piece you can put coloured paper, plastic etc. behind it or even colour the back with ink, paint etc. When inlayed the horn lets the colour through.
We are all in the gutter but some of us are looking at guitars.
These users thanked the author Joe Sallis for the post: Colin North (Fri Jun 27, 2014 11:07 am)
PostPosted: Fri Jun 27, 2014 12:54 pm
City: Saint Paul
State: MN
Thanks, everyone, for the replies. Looks like this one is a do-it-yourself project.
John Cavanaugh
Saint Paul, MN
PostPosted: Fri Jun 27, 2014 1:46 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
MichiyukI, hope I spelled that right. I sawed the bone in half long ways. Yuk!! Lots of grease. Then I boiled it for awhile. I was living in the desert so it just cured naturally. Some of those suggestions on here may be better. However,I've made a lot of things out of it. Still have a bit left too. Going to make some side dots for the Uke I'm just finishing up on. I guess I'm pretty primitive. But that's just me I guess. Good luck
PostPosted: Fri Jun 27, 2014 1:47 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Oh by the way use a hacksaw. You don't want bone marrow on your bandsaw blade.
PostPosted: Fri Jun 27, 2014 3:59 pm
First name: Kent
Last Name: Wilkinson
City: New Carlisle
State: Ohio
Zip/Postal Code: 45344
http://www.guitarpartsandmore.com/?nav= ... oductid=37
PostPosted: Fri Jun 27, 2014 10:23 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So what does bone marrow do to bandsaw blades?
Typhoon Guitars
PostPosted: Fri Jun 27, 2014 10:43 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
It is super greasy and would be a real ich to get off. Bieve me you wouldn't want it on there. Would probably get all over your tires guides etc. Not good.
PostPosted: Sat Jun 28, 2014 6:20 am
Last Name: Kubo
State:
Country: Österreich
Thanks for the tips, will have to give it a go one day.
Apologies to John for butting in the topic here :)
久保
美智え
PostPosted: Mon Jun 30, 2014 1:42 pm
First name: Tim
Last Name: Allen
City: San Francisco
I've thought of this too, and ended up going to eBay and picking up a couple of Tagua nuts, which are a very hard nut that is used as "vegetable ivory." No boiling on the stove for hours, no grease on your bandsaw, no sullen resentment on the part of your dog. One of these days I'm going to make an all-vegan guitar.
Tim Allen
"Never hurry, never rest."
PostPosted: Mon Jun 30, 2014 1:46 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Lee Valley sells Tagua nuts, as well. http://www.leevalley.com/en/wood/page.a ... ,250,43217
Alex
PostPosted: Mon Jun 30, 2014 1:52 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
They don't seem long enough to make saddles...
Typhoon Guitars
PostPosted: Mon Jun 30, 2014 2:09 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Well the boiling process was not hours maybe ten minutes tops. The grease is yucky. That's why I suggest using a hacksaw. Now the dog getting upset is a different story. However I did give him the knuckles off the ends. That seemed to pacify him. I don't regret having this piece of bone all these years and would gladly make another. Which I plan on doing fairly soon.
PostPosted: Mon Jun 30, 2014 4:31 pm
City: Saint Paul
State: MN
If you want to prepare your own bone for instrument use, the writeup at http://www.bearmeadow.com/build/materials/bone/html/bone-clean.html is useful. It describes a pretty complicated procedure, which is why I was asking about pre-shaped pieces in the first place.
John Cavanaugh
Saint Paul, MN
PostPosted: Sat Jul 05, 2014 3:11 am
I picked some old bone up at a campsite. Great stuff, bleached by the sun, thoroughly cleaned by ants. I think it was a beef bone but am not totally sure. It's not white white but that's not the look I'm like anyway.
Users browsing this forum: Chris Ensor, pullshocks and 13 guests
