It is currently Sat Apr 18, 2026 6:26 pm
 Post subject: Binding cutter bearings
PostPosted: Tue Jun 10, 2014 9:29 am
First name: Wendy
Last Name: W
State: Arizona
Does anyone know if the Stew Mac bearings will fit the LMI bit?
PostPosted: Tue Jun 10, 2014 9:43 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
They will not. I have both sets.
PostPosted: Tue Jun 10, 2014 9:46 am
First name: Wendy
Last Name: W
State: Arizona
Too bad. Thanks for the answer!
Wendy
PostPosted: Tue Jun 10, 2014 9:54 am
First name: David
Last Name: LaPlante
If you go to your local Hobby shop they should have lengths of small brass tube in varying inside and outside dimensions. With any luck you may find what you need to sleeve a larger center opening in the bearing to the smaller shaft size of the bit.
You can also cut the bit of tube to adjust to the size. Make sure you add a washer to the hold down screw to keep the sleeves in place.
If you live in a larger city, there are industrial bearing suppliers (Kaman) that pretty much have all different sizes to make up what you need.
PostPosted: Tue Jun 10, 2014 10:06 am
First name: Wendy
Last Name: W
State: Arizona
Thanks David. I don't have the Stew Mac bearing so not worth going to the trouble. I was trying to get away with not ordering the 1 bearing I need from LMI, (forgot to order last time) since that is all I need and they have minimum shipping charge. I could have ordered a couple of other things from Stew Mac. I will just bite the bullet and order from LMI.
PostPosted: Tue Jun 10, 2014 10:09 am
First name: Wendy
Last Name: W
State: Arizona
I checked and there is a Kaman on the other side of town. If it was closer I'd go, but the gas would probably be as much as the shipping from LMI. Good to know they are there though, thanks!
PostPosted: Tue Jun 10, 2014 10:10 am
Just to let you know, I have built up a smaller bearing with self adhesive copper tape to get the size I want (Todd Stock tip)
PostPosted: Tue Jun 10, 2014 10:17 am
First name: Wendy
Last Name: W
State: Arizona
I don't think I have 1 close enough in size, I seem to have a gap. Do you know how thick the copper tape is and I will check? Where do you buy that?
PostPosted: Tue Jun 10, 2014 10:31 am
I think this was the one http://www.ebay.co.uk/itm/5mm-X-30M-Guitar-Pickup-EMI-Copper-Foil-Shielding-Tape-Conductive-Self-Adhesive-/360655842459?pt=UK_Sound_Vision_Other&hash=item53f8c36c9b
In my case,
Thickness of copper foil: 30microns
Total thickness: 65microns (0.002559", call it 2.6 thou)
But obviously you would look on your local site(s).
I have used up to 9 wraps to get the size I needed (and was successful despite my initial doubts)
PostPosted: Tue Jun 10, 2014 10:38 am
First name: Wendy
Last Name: W
State: Arizona
OK, thanks Colin, I will see what I find.
PostPosted: Tue Jun 10, 2014 11:27 am
BTW, I cut the ends slightly short of meeting (well, sort of, one end inside, other outside) and cut both ends diagonally to help prevent any possible bump and get a smooth transition point
Bit sad isn't it, trying for perfection. gaah
Some call it obsessing, I call it normal....
PostPosted: Tue Jun 10, 2014 2:54 pm
First name: David
Last Name: LaPlante
I recently used one of the LMI bearings (designed to be used with their 1" wide cutter)
With an old Freud 1 3/8" cutter in order to get an extra wide .260" purfling ledge.
Way back in prehistoric-luthier times before LMI and Stew Mac offered them (late 70s and early 80s) one had to improvise these cutters and bearings.
For me this included buying the cutters that Sears offered and modifying them to accept bearings as well as turning brass sleeves of specific sizes to epoxy onto the few bearings that came with standard rabbeting bits.
Folks have no idea how lucky they are these days........
PostPosted: Tue Jun 10, 2014 3:43 pm
Or cobble together old bicycles like this.
(With more than a nod to the newer Olsen site - I was actually looking for the older version of this, which hung from the roof IIRC, and was a little more rustic [:Y:] )
PostPosted: Tue Jun 10, 2014 5:13 pm
First name: tim
Last Name: minkkinen
City: charlotte
State: nC
Zip/Postal Code: 28203
Country: united States
I've been using aluminum duct tape since the seventies to augment the the sizes of the bearings on rabbet bits. Sticky, thin and harder than masking so it doesn't compress. Available at any hardware store.
Tim
PostPosted: Tue Jun 10, 2014 6:46 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
I like that bike thingy. After you cut your channel you can go riding just how cool is that? :0)
