It is currently Sat Aug 16, 2025 6:34 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
 Post subject: Re: Radius Cutter
PostPosted: Thu Feb 27, 2014 5:09 pm
Last Name: Curtis
City: Mangrove Mountain
State: N.S.W
Zip/Postal Code: 2250
I own the LMI circle/rosette cutter and it is the only one i have used, well made and does its job. Its downfall for me is you can't see it doing its work and you can't see the work itself, you are pretty much working blind. For something as fine and noticeable as a soundhole IMHO any tool which gives me a better look at whats going on would be preferable. The pop stick, both LN and LV tools, perspex/lexan and many assorted home/shop improvements are way better suited to our needs as you can see the cutter at work.
PostPosted: Thu Feb 27, 2014 5:16 pm
Last Name: Curtis
State: N.S.W
Oops double post perhaps a mod can remove please.
Thanks Steve
PostPosted: Thu Feb 27, 2014 5:17 pm
First name: Justin
Last Name: North
City: Chattanooga
Zip/Postal Code: 37416
Steve - thanks for the reply. I'm going to pick up one of the circle cutters I mentioned from Lowe's or Home Depot tomorrow and try it out on some cheap spruce I picked up last year and I'll let you know how it goes.
It's disadvantage is that the depth of the cut cannot be adjusted on the tool itself so I'll have to devise a way around that.
It does have the benefit of being able to see very clearly what is happening as you cut.
PostPosted: Thu Feb 27, 2014 5:19 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
@guitarwhisperer: i come i never thought of that? ingenious!
PostPosted: Thu Feb 27, 2014 11:23 pm
First name: Justin
Last Name: North
City: Chattanooga
So for anyone interested, I purchased a $10 circle cutter from Home Depot this evening to try out on some student grade spruce I picked up from RC Tonewoods about a year ago.
I will not be using this tool to cut my rosette channels.
To be fair, the tool is designed to cut through sheet rock, not hardwoods. I had to use *considerable* down force to get the thing to really cut at all. Interestingly, because the thing is designed for actually cutting holes, I thought that I might have trouble with it cutting too deep. This was not the case.
The results might have been satisfactory once the rosette was in place and the area was sanded down, but I am not interesting in satisfactory. I would prefer excellence if at all possible, and I believe using a tool from StewMac or LMI that is made for the job would have yielded much better results.
PostPosted: Thu Feb 27, 2014 11:48 pm
Yeah, but that blade attachment block fixes that. Great idea!
Old growth, shmold growth!
PostPosted: Fri Feb 28, 2014 9:09 am
First name: Miguel
Last Name: Bernardo
Country: portugal
Oh, now i see that contraption with the stewmac thing wasn´t tGW´s idea but sanchopanza´s... great idea!
These users thanked the author mqbernardo for the post: sanchopanza (Wed Mar 19, 2014 5:17 pm)
PostPosted: Fri Feb 28, 2014 9:19 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
JustinNorth wrote:
Has anyone here tried using a circle cutter hand tool like the ones you can find at local hardware stores? They're inexpensive and are adjustable to different diameters. They're technically made to cut holes in dry wall, but I'm wondering if it would work. Might try on some scrap this weekend.
I've used it, but with some modifications:
-Sharpen the blade! Stock, the blade is, at best sharpish.
-use a pre-drilled hole in the base on the drill press table, so that the cutter has something to register to. Ensure that the table is horizontal so that the cutter makes an even cut all around the circle.
-set the cutter in the drill press to keep it aligned properly, and then turn it by hand. A few turns is enough. Don't turn the drill press on, its really not worth it. Set the blade, and turn the cutter so that it makes a slicing cut. It is possible for it to be set for a plowing cut by reversing the blade.
Used like this, these cutters can work very well.
http://redrivercanoe.ca/
PostPosted: Fri Feb 28, 2014 9:32 am
First name: Justin
Last Name: North
City: Chattanooga
Mr. Ingram,
It wasn't a drill attached circle cutter, but I appreciate your response very much! Sadly, I do not own a drill press. I am working with mostly hand tools at the moment, and tried using a $10 manual circle cutter. It wasn't very sharp, and I don't think I'll ever use it again. I'm on a shoestring budget, which is fine because I'm working on my first guitar, but my birthday is next month and the LMI circle cutter is on my list (along with some chisels and radius sanding stuff).
PostPosted: Fri Feb 28, 2014 9:46 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I use this tool to square my drill press table to the drill. I chuck up the circle cutter and adjust the table so that I can spin the bit just touching the table insert I have. I never considered actually using it to route the rosette rebate or cut out the sound hole.
PostPosted: Fri Feb 28, 2014 11:09 am
This is true. I didn't think of it.
However, it is still quite ingenious!
These users thanked the author theguitarwhisperer for the post: sanchopanza (Wed Mar 19, 2014 5:17 pm)
