It is currently Sun Aug 03, 2025 12:27 am
PostPosted: Mon Feb 07, 2011 8:42 am
So I have one I'm working on and when I did the rosette there was a bit of chip out. I thought I had managed to fix it, but it reappeared in final sanding.
So I'm wondering if anyone has ever tried to recut a rosette channel after the body is assembled? I'd probably be trying to do the inside and outside edges and then relay in new purfling.
Neil
PostPosted: Mon Feb 07, 2011 9:54 am
Yup, I've done it and it works well.
You cut a plug with your router rosette rig (make sure it's a tight fit), add a block under it to keep the pin perpendicular, and rout away...
PostPosted: Mon Feb 07, 2011 10:47 am
Well Haans that's cleaver as heck.
Thanks alot. I appreciate it.
Neil
PostPosted: Mon Feb 07, 2011 3:42 pm
First name: Hugh
City: Lake Oswego
State: oregon
Haans,
How thick is your plug? It looks like about twice that of the top.
PostPosted: Mon Feb 07, 2011 5:14 pm
Yea, that's about right...
PostPosted: Mon Feb 07, 2011 5:37 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
cool
PostPosted: Mon Feb 07, 2011 7:34 pm
First name: Darryl
Last Name: Young
State: AR
Here is another twist on the previously shown theme. This one might be easier to get in and out of the soundhole yet still hold well.......and it can be made where it's level with the top. I assume sponges or similar material is placed underneath to hold the block in place. These pics were taken by Bill Cory (I assume his idea idunno )
PostPosted: Mon Feb 24, 2014 4:07 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
I did it but not as neat looking as the above pics.
Screw a strip of wood under the sound hole. the screw hole will be covered by the finger board. Use a slither of wood and double-sided sticking tape or bluetack or whatever it takes to prop the strip of wood up from the other side of the sound hole.
Find the centre line and mid point of the sound hole. And you're away with your router.
Worked absolutely fine for me. But I like Haans method better.
We are all in the gutter but some of us are looking at guitars.
PostPosted: Mon Feb 24, 2014 7:04 am
First name: Trevor
Last Name: Gore
City: Sydney
Using your router/circle cutter, cut a disc the exact size of your sound hole. When it's free from it's surroundings, it should lift out on the circle cutter pivot. Lift the disc off the pivot, apply double sided tape (or similar) and put it back on the pivot so as the disc sticks to the router base. The disc now acts as a pivot in the sound hole.
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post: EddieLee (Mon Feb 24, 2014 8:18 pm)
PostPosted: Mon Feb 24, 2014 6:03 pm
First name: nick
City: Vallejo
State: ca
what's a circle cutter pivot?
PostPosted: Mon Feb 24, 2014 6:08 pm
First name: Wendy
Last Name: W
State: Arizona
The pin that your circle cutter rotates on or pivots on.
Users browsing this forum: Facebook [Bot] and 31 guests
