It is currently Wed Jul 23, 2025 7:11 am
PostPosted: Thu Feb 13, 2014 5:06 pm
Last Name: Sollod
I've seen a number of guitars that the neck heel has purfling under the heel plate. Typically, that purfling line is in line with the purfling that goes around under the side binding. I looks really nice, but I'm not sure how it's done. Do you route a channel into the heel by hand? How do you do it?
www.swiftcreekguitars.com
PostPosted: Thu Feb 13, 2014 5:33 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I believe corresponding veneers are laminated on the heel before the heel cap is glued on, or the veneers are laminated on to the heel cap, then glued to the heel.
PostPosted: Thu Feb 13, 2014 5:39 pm
Last Name: Sollod
I thought about that, but I have seen it where it matches the side purfling perfectly and is not likely veneers stacked under the heel...
PostPosted: Thu Feb 13, 2014 6:00 pm
Like this?
The way to do it (at least how I do it) is to make the heel cap the very last step before final sanding before finish. The set of the neck has been done at this point too.
Attach the neck and using a wide chisel, shave the heel just so it meets the side purfling. Glue on a laminate of the side purfling and the heel cap. Done.
PostPosted: Thu Feb 13, 2014 6:53 pm
First name: Tom
Last Name: West
State: Nova Scotia
Laminates for me.............!!
Tom
PostPosted: Thu Feb 13, 2014 7:34 pm
Lam the purfling piece to the heel cap. Trim heel to exact length. Add heel cap. Presto.
PostPosted: Thu Feb 13, 2014 8:23 pm
Lams.
PostPosted: Thu Feb 13, 2014 8:35 pm
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
As others have mentioned, almost everyone uses stacked veneers. Quite honestly, this is the kind of embellishment that just looks awful if you don't have the woodworking chops to pull it off. For new builders, it is always better to start of with simpler aesthetics and slowly increase complexity as you gain in competency. As far as methodology, you need to add the laminates as one of the last steps in the neck fitting process. I add the heel cap after I have set the neck angle and mated the heel to the body. I then add the fretboard, carve the neck and do the final fitting and neck alignment. The important point is to have the neck pretty much ready to be mounted before adding the heel cap as additional sanding can cause the laminates to no longer line up with your side purfling.
PostPosted: Thu Feb 13, 2014 10:47 pm
First name: Trevor
Last Name: Gore
City: Sydney
I usually use stacked veneers, but you can bind them. Not for the faint-of-heart.
Not the best pic (cropped from a pic of the whole of the back), but you get the idea...
http://www.goreguitars.com.au
PostPosted: Sat Feb 15, 2014 1:40 am
Last Name: Beaver
City: Lake Forest
once upon a time I used premade purflings. But when I wanted to decorate the heal cap in purfling it lead to a problem. If you are using a black and white purfling made from fiber then it is easy. Just buy a sheet of each and make heal veneers.
If you are using wood for the white line than it is best to buy some wood veneer (maple and others work fine) and make your own. I usually use black fiber for the dark line. I make a piece with the same material that can be used to veneer the heal cap and usually the head plate.
Joe Beaver
Maker of Sawdust
PostPosted: Sat Feb 15, 2014 11:54 am
Last Name: Sollod
Thanks for the info. At this point I have been using premade B/W/B purfling. I can see that if you make your own purfling it would be easier to match the laminates of the heel cap. I figured you could use purfling and bind the heel cap as Trevor points out, but that probably is tricky. This is one of the many things that come with experience...
PostPosted: Sat Feb 15, 2014 5:36 pm
I do it the same way as Rod does. Take your time and remember it's easer to take it off than put it back on!
Users browsing this forum: DennisK, jfrench and 28 guests
