It is currently Wed Aug 06, 2025 7:22 pm
PostPosted: Fri Nov 22, 2013 2:13 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Zip/Postal Code: 94608
I've been looking around and haven't found anything about what parts of a bolt-on mortise and tenon neck joint should be glued. I gather the part to glue is just the fret board extension. I am intending to use hot hide glue. I imagine it would be best to just glue under the edges, but that's just a guess to make a future neck reset a bit easier. Do I glue else where, like where the heel contacts the body (after finishing). Thank you!
PostPosted: Fri Nov 22, 2013 2:31 pm
Only glue the extension, that's the point of a bolt on neck. A bead of glue just around the edges is sufficient. You don't even need to clean out the finish under the whole tongue, just a channel where the bead will land.
These users thanked the author meddlingfool for the post: Steven Bollman (Fri Nov 22, 2013 2:40 pm)
PostPosted: Fri Nov 22, 2013 2:40 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Thanks, meddling fool! I was thinking that was the likely solution.
PostPosted: Fri Nov 22, 2013 3:04 pm
Just like Meddling does it, a little glue around the perimeter of the extension.
These users thanked the author Jim Watts for the post: Steven Bollman (Fri Nov 22, 2013 3:23 pm)
Users browsing this forum: ptourin and 15 guests
