It is currently Sat Apr 18, 2026 1:14 pm
 Post subject: Build No. 2
PostPosted: Tue Nov 12, 2013 8:58 am
So after completing my build for the Newbie challenge, I thought I had better get on with another, so over the last couple of months, I have been working on a mandolin that is going to be a Christmas present for my partners sister. I have been meaning to add some pictures for weeks, but now that she is complete, I thought I had better put a few up.
Spec
Back and sided - English Walnut
Soundboard - European Spruce
Fretboard - Laburnum
Bridge - Laburnum
Neck - Sycamore
Binding - Mahogany with black blue purfling
I was surprised with how quickly I managed to work through the build, and enjoyed it so much that I think I will be making another for myself very soon. I will put a full build up on my website, but this won't be until post Christmas so that it can be kept a secret.
Nick
Follow my musings on getting started in luthiery http://www.tredwellinstruments.co.uk
 Post subject: Re: Build No. 2
PostPosted: Tue Nov 12, 2013 9:04 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Nice work! I really like the rosette. What kind of finish did you use?
PostPosted: Tue Nov 12, 2013 9:10 am
Goodin
Thanks! I used Liberon finishing oil, wiped on then then knocked back to a more satin finish with fine wire wool. I have used the Liberon several times now, and its rather like tru oil but a lot cheaper here.
Nick
PostPosted: Tue Nov 12, 2013 9:30 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Hey that's really cool. I have already started a bouzouki myself. How did you brace the top? Any pics of that?
Doug
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I used Liberon on my first five instruments. It worked well on everything but the rosewoods. How many coats did you use? Seems like I put down 8-10 coats.
PostPosted: Tue Nov 12, 2013 11:17 am
Doug, a Bouzouki is something else that I would like to have a go at in the future another one to add to the list.
Here is a shot of the bracing, its just a simple H brace,
Goodin, I put down a similar number, around 12-15, lost count. I had already pore filled using an egg white slurry and then a couple of coats of blond shellac before the Liberon.
Nick
PostPosted: Tue Nov 12, 2013 11:44 am
First name: Big
Last Name: Jim
Beautiful ! Bracing looks a Little Beefy , but that could just be the camera . Camera does add weight lol . How does she sound ? Post a clip ? Post this in Mando Forum as well [:Y:]
PostPosted: Tue Nov 12, 2013 3:03 pm
The bracing is fairly thin, I followed the plans in the mandolin project book. She sounds pretty good, i cant play the mandolin at all, but am trying to pick up a few notes for a demo.
Sent from my KFTT using Tapatalk 4
Nick
PostPosted: Tue Nov 12, 2013 5:49 pm
First name: Jay
Last Name: Swann
City: Austin
Zip/Postal Code: 78739
Nick, that is a beautiful instrument!!
PostPosted: Tue Nov 12, 2013 9:16 pm
Great job, Nick!
eek I was thinking of using liberon on my current build... rosewood back and sides! In what way did it not work well?
PostPosted: Thu Nov 14, 2013 1:53 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Very nice mando!
PostPosted: Fri Nov 15, 2013 7:50 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
Another fine instrument, Nick. I hope you stay on the forum, it's going to be intersting how your style changes over the years. I should be posting pics of my first guitars soon.
Where did you get the laburnam from? Thats exactly what I need for my next build.
We are all in the gutter but some of us are looking at guitars.
PostPosted: Fri Nov 15, 2013 9:38 am
Thanks for the comments. Im going to try and record a demo over the weekend, though it will only be a few chords etc. as I have never played the mando before. I'm expecting one very happy recipient come Christmas day.
Joe, I bought the laburnum on Ebay, Ill pm you the sellers id.
Nick
PostPosted: Fri Nov 15, 2013 10:45 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Nick Royle wrote:
Great job, Nick!
The oils in rosewoods seem to conflict with wiping varnishes and won't allow it to dry or adhere properly. I think much of my issues was my technique though and lack of extra prep work for the rosewoods (will explain below). I sanded the wood to 1200 grit which I think was too much. I think I would stop at 600 to allow more of an adhesion surface. I got lots of streaking on Indian rosewood as if the finish never wanted to stick. I think this was due to sanding too high of a grit, and maybe scorching from the hot pipe during bending (it only streaked on the sides, not the back), and I didn't wipe with Naptha before applying. Cocobolo didn't streak but it took many coats to build up a shine and many weeks or months before it dried...actually I'm not sure it ever completely cured.
If I ever do it again here would be my process: sand to 600 grit, wipe the rosewood down with Naptha thoroughly to remove natural oils, us a white rag and do as many wipe sessions as it takes until no more oils appear on a clean rag, or until your arm falls off, as soon as the Naptha dries apply the first coat of Liberon, let it sit until it almost starts to feel tacky then wipe off. If it gets tacky rub it down with a little bit of Naptha. Repeat application of Liberon until you get the sheen you desire. The finish will tack up faster the more coats you apply, so you have to work progressively quicker.
If the rosewood continues to give you problems wipe on a light coat of dewaxed shellac then lightly sand it back. That might help seal in the oils. Ive never tried this so I'm not sure how Liberon would build over top of it...should work ok though. If not, sand back to wood and think about it some more.
PostPosted: Fri Nov 15, 2013 10:50 am
I laid down my coats of liberon over the top of a couple of coats of shellac and was fine, so cant see it being a problem over rosewood, though would recommend testing on an of cut if possible.
Nick
PostPosted: Fri Nov 15, 2013 11:03 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Good to hear Nick. Probably not necessary to do that on the woods for your build though...walnut finishes beautifully with Liberon alone. EDIT: actually might still be a good idea to wipe a thin coat of shellac on spruce. Spruce seems to soak up more of the wiping varnishes than hard woods.
PostPosted: Fri Nov 15, 2013 2:14 pm
Thanks Nick, and thanks, Gil, for such a comprehensive answer! I'll be sure to do some tests and follow your advice! I'd french polish it but it is for a child so that may be a bit delicate(?).
I didn't shellac the spruce before the liberon on my last guitar but I'll be sure to test both before I finish my current build!
Cheers,
Nick
PostPosted: Tue Nov 19, 2013 3:31 am
Here is a quick sound clip of the mando, just a couple of chords but gives an idea of the sound
http://www.tredwellinstruments.co.uk/wp-content/uploads/2013/11/mando-demo-2.wav
Nick
PostPosted: Tue Nov 19, 2013 4:24 am
First name: joseph
Last Name: sallis
Country: UK
It's got a clear crisp sound.
Looking again at the photos, do you think the kerfed linnings could have been thinner? Give more room for the top plate to vibrate. Only a question as I'm not sure.
PostPosted: Tue Nov 19, 2013 6:48 am
Yes I think they could have been smaller, definitely, they are the same size that I have used for my guitar build, and they did look a bit oversized compared to the size of the mando.
I think they are something that I will probably reduce in size slightly for the next mando I make. Though I am very new to all this so I can't really comment on whether it would make the top move more or not. Maybe others can shed further light on the subject
Nick
PostPosted: Tue Nov 19, 2013 9:16 am
Thanks Todd, already started No. 3 I really like the side purflings as well on No. 3 I'm definitely going to keep doing them
I will start a build thread soon, Its a small bodied guitar, English Walnut back and sides with red cedar soundboard there are a few pics on my website, but need to update that as well.
Nick
PostPosted: Tue Nov 19, 2013 10:15 am
Well done, I'm looking at building one of those for myself at some point even though I have no clue how to play it.
A note on the Liberon over shellac. I've never used Leberon but if it is similar to to TruOil then it shouldn't be a problem as I've used TruOil over shellac several times.
