It is currently Sat May 02, 2026 2:56 am
 Post subject: bridge curve
PostPosted: Wed Nov 13, 2013 4:22 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
Should the top of the bridge, where the saddle slot is, curve to match the finger board radius?
We are all in the gutter but some of us are looking at guitars.
 Post subject: Re: bridge curve
PostPosted: Wed Nov 13, 2013 5:23 am
First name: Trevor
Last Name: Gore
City: Sydney
There's not many "shoulds" at all in guitar building! However, one approach is to curve the top of the bridge so that the saddle protrusion is constant across. (i.e. approx [but often tighter than] fretbopard radius, on a tilt to match the higher action of the bass side). So the bridge is thinner on the treble side. This also give you an excuse to talk about impedance matched bridges, should you so desire, :mrgreen: .
http://www.goreguitars.com.au
PostPosted: Wed Nov 13, 2013 5:55 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Martin and several other makers do. I see no reason not to do it.
PostPosted: Wed Nov 13, 2013 10:10 am
I do it, as mentioned, to keep a more constant saddle height from bass to treble.
PostPosted: Wed Nov 13, 2013 10:40 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Yes. Cumpiano/Natelson has a great outline on how to make a Martin style bridge (which is radiused). I use 16" radius for the fretboard but that seems like too much radius for the bridge which is wider, so I use a 20" radius block. I hold the 20" block with some sandpaper in a vise and rub the top of the bridge on it until the radius is achieved. You want to take down the treble side a little bit more than the bass side. Takes about 2 minutes.
PostPosted: Wed Nov 13, 2013 12:16 pm
At some point in the future when a repairman gets the guitar in to lower the action he's gonna plane a curve into it anyway, so ya may as well do it now. Unless of course you don't want too :)
PostPosted: Thu Nov 14, 2013 4:34 am
First name: joseph
Last Name: sallis
Country: UK
That's great, thanks for replies. Issue cleared in my mind.
