It is currently Sat May 02, 2026 6:41 am
PostPosted: Fri Nov 08, 2013 10:51 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Good vid. I learnt 1 new idea burnish at 90 deg BEFORE putting on hook.Thanks Todd. Other than that I use a LV carbide burnisher for the 5 -7 deg hook.
PostPosted: Fri Nov 08, 2013 11:22 am
I was never good at sharpening scrapers.... must try Link's techniques soon.
As for the hollow ground chisel... old toolmakers trick. I get that one.
PostPosted: Fri Nov 08, 2013 11:24 am
First name: Danny
Last Name: Vincent
It is a good one but I'm sure someone will come forth with a superior method. beehive :lol: On sharpening scrapers, how many burnishings do you think one can do before going through the whole process?
PostPosted: Fri Nov 08, 2013 11:58 am
Great stuff. I like the simplicity.
PostPosted: Fri Nov 08, 2013 12:18 pm
Addendum: I usually go right to the burnisher from the file. Of course I knock off the burr from the filing but if one chalks the file and gets a nice clean stroke the surface a good sharp file leaves is very good. This simplifies the whole process. It is easy to round the edge when trying to refine it on a stone even with a block of wood to guide you. You can feel when you get a good clean cut off of the file and you can feel when you roll up some metal and spoil the edge.
If I was going to scrape a finish or try to get a final surface with a scraper I would refine the edge on a stone and make a small burr but for most work this isn't necessary.
There are other things like using the burnisher to take the hook off and then put it back on to work harden the edge but this video was very extemporaneous and only basics were covered. Hopefully enough to give the idea.
L.
These users thanked the author Link Van Cleave for the post: Darryl Young (Thu Nov 14, 2013 10:36 pm)
PostPosted: Fri Nov 08, 2013 12:24 pm
City: chicagoland
State: illinois
good point about not trying to get too much of a hook; i lay my burnisher over too steeply i think
PostPosted: Fri Nov 08, 2013 12:36 pm
An attribute that most great ideas share.
PostPosted: Fri Nov 08, 2013 1:08 pm
First name: duh
Last Name: Padma
Slap an old 80 grit belt for metal on the 6 incher, flatten the faces, square up the edges and burnish. An arch top build...usually about 3 sharpenings.
Do them all at once. Less than 1/2 min per scraper.
Ya, me know, me slowing down in me old age. bliss
@ Danny V~ Once.
PostPosted: Fri Nov 08, 2013 1:31 pm
First name: Tony
Last Name: C
City: Brooklyn
Great video Link. I'm going to try this method at some point soon.
http://www.CostaGuitars.com
PMoMC
PostPosted: Sun Nov 10, 2013 9:43 pm
First name: Randolph
Last Name: Morris
Great video! Thanks for your wisdom, Link! Will be trying tomorrow!
PostPosted: Sun Nov 10, 2013 10:29 pm
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
I am usually a bit quicker with sharpening my scraper, and I get a pretty decent hook, though I'm not always happy with the consistency and how long it lasts. I have sharpened it by hand for years with the fine side of a regular file, with the scraper in a bench vise. Then to put a hook on it I usually just grab a screwdriver and use the shaft at an angle similar to the one in the video. I've found this gives me a very nice edge about 80% of the time, but only takes around a minute to do both long edges. I think I'll try a few of the tweaks in here and see if it helps. Nice video, very clear instructions.
PostPosted: Sun Nov 10, 2013 10:55 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Thanks for the video & the addendum.
I'm glad to hear that it's easy to round the edge on the stone - something I've always had issues with and thought I was the only one.
Kevin Looker
I'm not a luthier.
PostPosted: Sun Nov 10, 2013 11:49 pm
Thanks Link, great stuff!
PostPosted: Thu Nov 14, 2013 12:50 am
More great woodworking advice from Link. I remember when we first got together and I knew I could make a decent instrument. But he has taken my skills to another level.
Ken Franklin
clumsy yet persistent
Users browsing this forum: No registered users and 47 guests
