It is currently Mon Aug 11, 2025 7:35 am
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
 Post subject: UTB: flat or radiused?
PostPosted: Sat Oct 05, 2013 6:53 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
So my first couple of guitars I radiused the UTB to match that of the soundboard. Having just purchased and watched Robbie O'Brien's online videos on this subject (well worth the $$ BTW), I learned that he keeps his flat. Are there others who radius the UTB? Pros and cons for both approaches? Thanks in advance!
Doug
PostPosted: Sat Oct 05, 2013 7:00 pm
First name: Linus
City: Brooklyn
Zip/Postal Code: 11215
What is UTB?
PostPosted: Sat Oct 05, 2013 7:15 pm
I was using the top radius on the UTB and then sanding the fretboard area flat. But after reading Trevor's book I did one with a 60' radius and, as Todd stated, the geometry came out just right.
PostPosted: Sat Oct 05, 2013 7:19 pm
PostPosted: Sat Oct 05, 2013 7:58 pm
Doug, I've used flat UTB (.625" tall x 1/2" wide) up to this point without issue. John Mayes mentioned it in his Advanced Voicing DVD, and I thought, cool, less work. The reasoning was no more involved or thought-through than that.
Todd Stock wrote:
I radius the UTB (only) at 60' and glue it on flat, which helps limit any distortion to no greater than dead flat.
I've wondered about something related, and hopefully I can bring it up without stealing the thread. Folks in the Somogyi school tend not to feather the ends of their UTB's. I've seen it in a number of their pics, but the image I'm attaching is one Tim McKnight published on the AGF. Hopefully he won't mind me sharing it here.
On p.51 of The Responsive Guitar, Somogyi writes:
Quote:
Typically, the upper transverse brace is the most massive brace in the steel string guitar's top. It also, typically, is severely tapered/scalloped/feathered at its ends where it connects to the linings.
. . . The significance of this is that while these transverse members are fairly massive, they aren't all that well connected to the structure if they're severely scalloped (and weakened) at the very place that they need to be at full stiffness. Such braces can approach being almost free-floating and are hence useless as functioning supports. Think of a massive ceiling beam that's poorly connected to the walls on either side, and you get the idea: it's there largely for show and won't support the weight.
. . . it will make much more sense to make the upper transverse brace an effective support/anchor/limit by attaching it to firm structure on either side; otherwise we weaken the anchoring ends . . . .
In general, I wonder what you all think of this argument for UTB's without feathered ends. Specifically, I wonder if not feathering the ends down to 1/8" or whatever would prevent this distortion?
PostPosted: Sat Oct 05, 2013 8:39 pm
I radius mine to 28' just like the rest of the top bracing. But I glue it all onto flat rims, and the geometry all seems to come together fine....just requires a little extra pressure to get the neck block glued...
PostPosted: Sat Oct 05, 2013 8:52 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
I just realized that I'm doing an experiment on this as we speak. Like the picture above I stuck my UTB on in a similar way, only with feathered ends. I used a similar head block extension (without CF rods) and glued the UTB right to it at the proper angle to divert some pressure from the top to the sides without adding a bunch of weight. I also extended the head block for the back and radiused it at the same time as the sides the same way as the top.
Being my second-first build (the real first was a complete failure) I've got nothing to lose.
PostPosted: Sat Oct 05, 2013 9:38 pm
Sorry if the picture was misleading. The UTB was glued to the top. I think the pic simply shows it being fitted to the linings, but there was a pic of it being glued to the actual top after. I thought it was a pretty good example of the UTB's that aren't feathered.
PostPosted: Sun Oct 06, 2013 2:33 am
Online
Last Name: Kincheloe
I agree with Ervin on that. Feathering the ends is unlikely to make any difference to the sound, but most likely does make it less stable against long-term neck angle deformation. I do agree with Todd as well that full height isn't necessary, but scalloping to 1/8" or less like a lot of people do is way too much, especially with how far inward the scallops go by that point. I'd say 1/4" minimum, 3/8" better, 1/2"+ excessive but no harm in it.
As a side note, with the CF buttress style, personally I'd put some A-frame style braces on the back, going from the CF attachment points to the headblock... essentially making a tetrahedron of bracing, with the back waist brace being one edge, and the headblock being another. Probably the most rigid 3 dimensional shape you can make out of sticks.
As for the actual topic, I arch the UTB, but flatten the part that will be under the fingerboard. Provides a flat glue surface for the headblock (which I also glue to the UTB at the same time) and for the fingerboard, with some arching outside to remain convex in low humidity, and for neck angle purposes... although I still don't 100% understand the ideal fret plane-string plane geometry.
PostPosted: Sun Oct 06, 2013 3:04 am
First name: Trevor
Last Name: Gore
City: Sydney
Todd Stock wrote:
I reduce the depth of the UTB at the ends for the simple reason that it is not necessary to have a full depth beam there to carry the shear and bending loads, and adding anchoring for for that full depth beam is adding more weight.
All very sensible.
Todd Stock wrote:
I have no idea why Somogyi suggests that the beam must be full depth...
He majored in English.
http://www.goreguitars.com.au
PostPosted: Sun Oct 06, 2013 8:58 am
I've been going flat on the UTB for the last few years but am doing 60' on two current builds. The rest of the top remains 30'. I'll report back but am hoping to see a little less movement on string up.
PostPosted: Sun Oct 06, 2013 9:57 am
I have been using a 60' radius on the UTB for the last 10 guitars or so with a 28' radius on everything else. Got this idea from Todd, and it works great for the geometry. You still maintain the arch for it's added strength and the fret board extension is in near perfect position, just requiring a little touch up block sanding.
As far as feathering the UTB, I feather to 1/8" on the ends, as Todd said, there is no need from an engineering standpoint for it to be any thicker.
Chuck
PostPosted: Sun Oct 06, 2013 4:21 pm
Last Name: Beaver
City: Lake Forest
That's not a brace, it's a truss, and a darn well make one at that.
Joe Beaver
Maker of Sawdust
PostPosted: Sun Oct 06, 2013 4:53 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Have to agree with you there Joe - that UTB is pretty high on the cool factor...
Saw another one a few months back that had smaller to larger circles drilled out...
Not being a bridge engineer - are these stronger than a solid brace?
PostPosted: Sun Oct 06, 2013 8:42 pm
First name: Trevor
Last Name: Gore
City: Sydney
Less strong, less stiff than the equivalent dimensions (height, thickness) in solid, but higher stiffness to mass ratio.
PostPosted: Mon Oct 07, 2013 10:57 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
If you do a 60' radius on the utb and 30' on the rest, how do you fit the top to the sides? You can't just do it in a radius dish anymore can you?
Sent from my GT-S5830 using Tapatalk 2
Pablo Picasso
PostPosted: Mon Oct 07, 2013 11:10 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Actually, you can, and that's the way it's usually done.
A larger radius on the UTB results in a localized flattening of the top dome when it's removed from the dish.
PostPosted: Mon Oct 07, 2013 11:55 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Ok, so you just do that by eye with a block plane do you? Or is there some other jig or dish you need to do it?
Pablo Picasso
PostPosted: Mon Oct 07, 2013 12:57 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Hey Todd - With your radius system how much space do you get at the saddle area when you put a straight edge above the sound hole and run it down the center line (does that make sense!?)? Do you sand down the sides any at the heel block area, to achieve correct neck angle?
PostPosted: Tue Oct 08, 2013 2:56 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I have had success (though I haven't made many instruments) with using a flat UTB and getting the neck angle the way I want. The thought of using a slight arc (closer to flat than the normal top radius) to build in a little insurance from humidity changes appeals to me. I may as well use the 60 ft (or close enough) that you all are having success with. How much offset over say 24" would it take to approximate a 60 ft. radius. I'd like to just make a template of that arc and draw it on my stock, plane to the line and call it close enough.
Bryan Bear PMoMC
PostPosted: Tue Oct 08, 2013 3:01 pm
Online
Very handy tool for calculating arch offsets http://liutaiomottola.com/formulae/sag.htm
PostPosted: Tue Oct 08, 2013 3:21 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Handy indeed, thanks Dennis! I come up with 0.1 inches over a 24 inch span.
Oops looks like Todd sent me a fish while I was shopping for bait and tackle. . .
Bryan Bear PMoMC
PostPosted: Tue Oct 08, 2013 3:58 pm
Bryan, I just take a couple of swipes on each end of the UTB with a block plane. Works for me.
PostPosted: Tue Oct 08, 2013 4:11 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Yeah Steve, I knew the offset wouldn't be much but once I did the numbers It became obvious just how small the offset would be over the length of the typical UTB. I'll probably not bother with a template and just take of a few wisps as you described.
And I didn't properly thank Todd. Sagitta was the term I couldn't come up with when I tried to find a calculator on the internet.
Bryan Bear PMoMC
PostPosted: Tue Oct 08, 2013 6:45 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I do it like Steve does. 1/16" off the ends with a block plane from a 2 1/2" flat center. Then I just slightly sand the heel block on a sanding board with a thin wedge propping up the tail block. Get's me .090" at the saddle.
Users browsing this forum: DennisK and 41 guests
