It is currently Sun Jul 27, 2025 10:24 pm
PostPosted: Mon Sep 16, 2013 5:23 pm
Gentlemen and fair ladies:
I glued some fretboard side dots into a tapered and glued fretboard last night that weren't quite at the perfect depth. Some sit proud .020-.030". I want to level them, obviously, but I'm not sure what the best means might be. Going at it with a palm sander gives me concerns about making unwanted dips along the edge of the fretboard. Could approach them with a model maker's plane, but I don't know if MOP planes.
Thoughts?
PostPosted: Mon Sep 16, 2013 5:29 pm
City: chicagoland
State: illinois
use a file; the MOP will probably chip and nick a blade, and the MOP will chip and nick as well
PostPosted: Mon Sep 16, 2013 6:10 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I'd do it differently. You can use a file (or a flat stick) but wrap it tightly with fine sandpaper--220 or finer. Then patiently stroke along the dots until you bring them into a flush fit. Don't be aggressive. You don't want to sand in a hard-edged flat on the neck. Go slowly, gently, patiently. And feel the surface often with your hand in the playing position.
Patrick
PostPosted: Mon Sep 16, 2013 6:38 pm
I don't suppose you have an edge sander?
PostPosted: Mon Sep 16, 2013 7:06 pm
Last Name: Kincheloe
Side dots are probably small enough that sanding as Patrick describes should be quick and safe enough. But for larger inlays, a scraper and chisel are my tools of choice if I need to take down a high spot. Mainly because you can see what you're doing, unlike with a sanding block. Also doesn't fluff shell dust into the air. But you still need to finish with a sanding block to get things perfectly flat.
PostPosted: Mon Sep 16, 2013 7:45 pm
Last Name: calkin
City: greenville
State: va
Zip/Postal Code: 24440
I suppose that if you have to ask this question you really are a rookie. 80 grit on a flat block will take them down in seconds without hurting anything else. Always finish with blocks as you work down through the grits as you sand your neck, the shell is harder than wood and will leave high spots if you just sand with your fingers. I can't imagine attacking shell with metal tools. Use the largest sanding block that doesn't get in the way, otherwise you might sand away more wood than shell and leave a scalloped effect. Be brave in the rough stages and use more finesse as you close in on the finished work. If your fingerboard is still free of the neck I'd just touch it to the belt sander to take down the dots and be done. Don't attack your work like a crazy man, but don't use your beginner status as an excuse to be timid, either.
PostPosted: Mon Sep 16, 2013 8:29 pm
Thanks, John! Yes, this is my first kit!
PostPosted: Mon Sep 16, 2013 8:44 pm
First name: Tom
Last Name: West
State: Nova Scotia
Flat sanding stick.............!!!
Tom
PostPosted: Mon Sep 16, 2013 8:46 pm
First name: Danny
Last Name: Vincent
File, 220 grit followed by 320 grit with a hard block.
PostPosted: Mon Sep 16, 2013 8:49 pm
Last Name: calkin
City: greenville
State: va
Congratulations! You probably can't imagine the agony and joy that lie ahead of you. Best of luck to you.
PostPosted: Mon Sep 16, 2013 11:19 pm
I was teasing ;) It's my sixth, but the first time doing position markers OR working with shell, so it is a rookie thing in every sense [:Y:]
Thanks for all the tips, guys!
PostPosted: Tue Sep 17, 2013 6:37 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I like a file because it's fairly fast & the feel & sound of filing the shell is very different from wood so there's feedback to help you know when to stop.
Kevin Looker
I'm not a luthier.
PostPosted: Tue Sep 17, 2013 9:34 am
That's what I found.
PostPosted: Tue Sep 17, 2013 10:55 am
First name: Tom
Last Name: West
State: Nova Scotia
The only time I've ever touched a file to shell is when I'm using a small needle file to clean up after cutting a shape from a shell blank. It was my thought that it was too easy to pull a hunk out of the inlay but I guess I was wrong again.
Tom
PostPosted: Tue Sep 17, 2013 11:48 am
That was kind of rude for a guy who's only been here a couple weeks......Even if you are a professional.
These users thanked the author Rod True for the post: James Orr (Tue Sep 17, 2013 10:58 pm)
PostPosted: Tue Sep 17, 2013 8:06 pm
Last Name: calkin
City: greenville
State: va
I used to be the most sensitive guy on the planet. I got over it. No rudeness was intended, but I was surprised by the basic nature of the question. And with some of the other answers. Its very likely that I can no longer remember the anxieties I went through as a beginner, but some things just seem obvious to me, and did forty years ago. Problem solving is key to our pursuit, and it shouldn't take a handful of online allies to tackle such a minor irritant. Having multiple answers handy at the click of a mouse is a sad substitute for thinking something out and just giving it a try. Building guitars is nothing compared to building your own character.
PostPosted: Tue Sep 17, 2013 10:58 pm
On the development of character:
Quote:
[When it was announced that France had surrendered] We had stood up, too. Bonhoeffer raised his arm in the regulation Hitler salute, while I stood there dazed. "Raise your arm! Are you crazy?" he whispered to me, and later: "We shall have to run risks for very different things now, but not for that salute!" -- Bonhoeffer, Bethge, p. 585
Picking the fights that are worth it. [:Y:]
PostPosted: Tue Sep 17, 2013 11:36 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Todd Stock wrote:
I think the derivations of energy, momentum, and continuity equations from first principles as applied to fluid dynamics are so obvious as to be trivial for even the poorly educated, but I keep it to myself because it would be such a douche move not to.
Dam(n)...did I say that aloud?
Wouldn't the derivations of energy, momentum, and continuity equations from first principles as applied to fluid dynamics actually describe how a douche moves?
Bryan Bear PMoMC
PostPosted: Tue Sep 17, 2013 11:42 pm
First name: Ringo
Forget edge tools and files... there is no better tool for leveling MOP than sandpaper. Just wear a respirator to keep the dust out of your lungs.
PostPosted: Wed Sep 18, 2013 9:46 am
First name: Patrick
Last Name: Hanna
State: Missouri
I previously commented, but I just wanted to add that Kevin made an interesting point about the sound and feel of shell as it's being filed (or sanded). James made a VERY important point about wearing a respirator mask. I'm still in the camp that recommends a fairly long sanding block and a sequence of fine abrasives. I would work parallel to the edge of the fingerboard, rather than going at the dots in a perpendicular way. Block doesn't necessarily need to be full length, but the longer it is, the less chance you have of accidentally sanding a curve where you don't want one. It'll go pretty quickly for you.
Patrick
PostPosted: Wed Sep 18, 2013 10:56 am
Long sanding block with 220 or 320 glued to it. Nothing else needed for this. I do use a file when leveling inlay on a headplate though if it is sticking out a good bit.
PostPosted: Sun Sep 22, 2013 8:11 am
"Building guitars is nothing compared to building your own character."
Yes, you are right, be it good or bad! :lol:
It's nice to see how different people approach the same problem. I have found better ways to do things by reading how others do them. I might be able to think of a way, but not necessarily the best way to do things.
I generally grab a fine file to level shell side marker dots before doing the final sanding on the neck, but an emory board or a hard backed sanding block will work too. I don't like setting the dots below the level of the wood and filling over them, but some have good success with that method.
PostPosted: Sun Sep 22, 2013 12:17 pm
When I wasn't sure how to adhere the 220 to the stick of maple I used, I almost started a thread. But then I though, "Nah. I'll just use my Super 77," and it worked like a charm.
<That was meant in fun>
The sanding block worked perfectly. And yes, a little embarrassed that I didn't think of it immediately, but not that I started a thread on a luthiers forum to get a quick and effective solution to a problem.
PostPosted: Sun Sep 22, 2013 1:39 pm
Indeed. Even just to answer the question for someone else as well....
Users browsing this forum: Bing [Bot] and 20 guests
