It is currently Sat May 16, 2026 11:04 am
 Post subject: Warped EIR sides?
PostPosted: Mon Aug 05, 2013 3:36 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I'm not sure if this is a problem but as I was thicknessing the EIR side the wood seem to develop a warp that gets worse as I thin it... It's not really resisting and I can easily press it flat with a little bit of pressure, and I figure that I can correct it at the bending iron. Are wraped sides an issue? The wood really wants to bend... could almost bend it cold.
I normally wait a bit before I start on it but the wood is dry and I don't want to sit idle for 2 months while the wood gets used to Taiwan...
Typhoon Guitars
 Post subject: Re: Warped EIR sides?
PostPosted: Mon Aug 05, 2013 3:47 am
Go ahead and bend it. Sometimes wood like that will really want to twist and you end up with 2 different bouts for 2 different Guitars. Don't know what it's like with a bending machine (might be easier) but on an iron you have a certain amount of scope for correcting any twist. Sometimes it's a battle. Only one way to find out.
PostPosted: Mon Aug 05, 2013 5:12 am
I don't worry about RH for the sides. It's going to get wetted and heated up anyway.
PostPosted: Mon Aug 05, 2013 12:29 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I think it will be OK after bending. Maybe keep a straight edge handy to see if you get any cupping.
PostPosted: Mon Aug 05, 2013 12:34 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
If timber has differential residual stress (they all do, some more than others), it can move as material is removed.
It should not be a problem once the sides are bent and clamped in a form, but getting to that point may not be easy!
Users browsing this forum: DennisK and 20 guests
