It is currently Sat May 16, 2026 1:30 am
PostPosted: Thu Aug 01, 2013 1:45 pm
Last Name: Livermore
State: Minnesota
Has anyone used one of these?
Why should or shouldn't I consider this for my shop?
http://www.wagnerspraytech.com/portal/control_spray_plus_en_spray,,358970,,,markierung+Hvlp.html
PostPosted: Thu Aug 01, 2013 2:35 pm
I used one to paint my aunt's house. It's noisy as hell, and hard to clean up after usage. In my experience, it would be hard to get a small spray pattern for guitars, but then - I never tried all of the heads available to fit these guns.
PostPosted: Thu Aug 01, 2013 3:01 pm
First name: Mark
Last Name: Chinworth
City: Kirkwood
Zip/Postal Code: 63122
I own the Wagner Control Spray Double Duty, and although the product website states (similarly to the control spray plus), "...spray thin materials such as stains, sealers, urethanes, varnishes, and lacquers." I contacted Wagner Tech support to inquire if it would be suitable to spray nitro. This is the response I received:
Quote:
Good morning. The seals in a Control Spray Double Duty are not resistant to lacquer thinner, so you may experience irreversible damage to the spray head itself. The best way to minimize this is to clean the sprayer quickly and not let the lacquer thinner set in the sprayer too long. If damage does occur to your sprayer, you would need to order 0417700A front end as a replacement ($24.30 plus freight). Also, make sure you are using this in an area with plentiful ventilation and no exposed flames (i.e. furnaces, gas stoves, etc) as the fumes from this type of lacquer is very flammable.
Wagner Service
I haven't tried it yet, but I intend to experiment with 2 lb. shellac first. Good luck
PostPosted: Thu Aug 01, 2013 3:03 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I agree with Chris. I have a similar sprayer, used it twice, and is currently collecting dust on an upper shelf. If you have a compressor, you can try this http://www.gleempaint.com/hvcongunnew.html. I used one for cabinetry stain and finishing before I bought my Fuji, and it does a good job.
Alex
PostPosted: Fri Aug 02, 2013 10:36 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Zip/Postal Code: 30308
I started with one. It worked OK. About 6 months later I decided to buy a compressor and spray guns because I was starting to get into doing bursts and more intricate finished in general. I can't even tell you how much better it is in comparison. I think I have less than $400 invested in my rig. Worth every penny. The control spray is just ok. You will find yourself wishing you had gotten something better after using it a couple times though.
"I'm not going to say that perfection has never been achieved. However, if it has, it probably went unnoticed due to it's lack of character."
PostPosted: Sat Aug 03, 2013 11:08 am
State: Minnesota
Good feedback.
I will stick with my regular gun and compressor
Users browsing this forum: DennisK, meddlingfool and 332 guests
