It is currently Sat Aug 02, 2025 1:04 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jul 27, 2013 2:36 pm
First name: Tony
Last Name: C
City: Brooklyn
pthes wrote:
Tony_in_NYC wrote:
One of the biggest obstacles to overcome will be people always saying you copied Kevin's design.
My question was a technical one and nothing more. I do not want to switch the conversation to one of ethics since the luthier world is full of copying. Only one person created x-bracing but the percentage of steel strings built with one is likely in the high 90s. Innovations such as armrests, side ports and wedge guitars are part of many guitars built by people on this forum but do the builders reference Grit Laskin or Linda Manzer? Some do, some don't.
Just looking for pros and cons of a tighter radius on the back. If people have constructive input I welcome it.
My comment was meant to be a joke, but I guess it could be taken seriously.
I have innovated exactly zero point zero things with my guitars. Everything I do has been done before. Including my mistakes.
Sent from my iPhone using Tapatalk 2
http://www.CostaGuitars.com
PMoMC
PostPosted: Sat Jul 27, 2013 6:46 pm
First name: Trevor
Last Name: Gore
City: Sydney
Mike Collins wrote:
theguitarwhisperer wrote:
Mike Collins wrote:
The stiffer(less flex & a high resonance) the back-the less it takes from the top.
Make a supple top & stiff back & sides.
That's one view. Another is that the back contributes complexity and by reducing the back's influence, the overall tone becomes less complex. Rather than taking from the top, the back contributes. Lessen it's influence and the top stands more alone.
I just find a stiffer B & S help with the tone,volume & projection
My clients need.
A loose(flexible) back is hard to control.
And can really mess up a clear,clean sound.
Well, as ever, it's not a case of just one type or the other. Both live and non-live backs have their very valid places. As I've said before, (and very simplistically) stiff backs give "volume" and live backs give "tone". Floppy backs (as Mike has suggested) kill both. It's a case of knowing what the alternatives offer and when to use them.
For guitars played acoustically I generally use a live back with a 3m radius dome (that's about 10 feet). Not seven, but I wouldn't want to bind a back with a Venetian cutaway with a seven foot radius. 3m radius makes it difficult enough. The majority of my SS guitars have Venetian cuts.
http://www.goreguitars.com.au
PostPosted: Sat Jul 27, 2013 7:34 pm
I'm not sure I said "loose floppy back".
I just said the back's influence makes the tone more complex, and lessening it's influence makes the top's influence dominant.
The back doesn't have to be loose and floppy to contribute.
Old growth, shmold growth!
PostPosted: Sat Jul 27, 2013 11:30 pm
First name: Trevor
Last Name: Gore
City: Sydney
Having checked back, I'm sure you didn't!
I was just making the point. Both live and non-live backs work fine, which means giving them the right degree of stiffness for the job. I've seen/heard a few floppy backed guitars and acoustically they don't seem to do anything well.
PostPosted: Sun Jul 28, 2013 4:24 am
First name: Trevor
Last Name: Gore
City: Sydney
OK, here's some more technical terminology:
Live backs produce a T(1,1)3 resonance.
Non-live backs don't produce a T(1,1)3 resonance.
Floppy/loose backs have a T(1,1)3 < T(1,1)2 (which is not strictly correct use of the nomenclature, but those who know will understand ;) )
Is that better?
:lol:
PostPosted: Sun Jul 28, 2013 8:21 am
" D T's" - delirium tremens - a.k.a. "shaking frenzy" ? :)
PostPosted: Sun Jul 28, 2013 11:36 am
Filippo Morelli wrote:
Trevor Gore wrote:
Is that better?:lol:
Not really. Filippo
I'll say!! :shock: idunno
jw ( o)===:::
PostPosted: Sun Jul 28, 2013 12:12 pm
What he's saying is that a live (not floppy) back contributes frequencies making the tone character more complex. A floppy back will contribute wolf tones and tuning dissonances.
PostPosted: Sun Jul 28, 2013 1:33 pm
First name: Danny
Last Name: Vincent
LanceK wrote:
dberkowitz wrote:
forged a new era in American luthierie.
Not to mention what her and her cast of characters did for Canadian luthierie ;)
PostPosted: Sun Jul 28, 2013 6:59 pm
First name: Trevor
Last Name: Gore
City: Sydney
Trevor Gore wrote:
Is that better?
:lol:
Not really.
Filippo
OK, here's a longer version.
Typically, if you do Chladni patterns on a guitar top you'll see either two or three occurrences of a main monopole resonance. A non-live back guitar will show just two, the two parts of the air/top couple. A live back guitar will show three, the three parts of the air/top/back couple. Typically the frequencies of these resonances are ~100Hz, ~200Hz and ~250Hz if you have those resonances placed according to my processes. These resonances, if present, will also appear as peaks in the guitar's frequency response curve (elicited, for example, by recording taps into a spectrum analyser). Whilst there are other naming conventions, the one I use names these resonances the T(1,1)1, T(1,1)2 and T(1,1)3; T stands for Top, the first two digits count antinodes across then down the vibrating surface and the third digit denotes the frequency order in which they occur (lowest first). So a T(1,1)1 resonance is the first (in frequency order) occurrence of a top monopole resonance, sometimes called the fully coupled main air resonance or (incorrectly) called the Helmholtz resonance. A T(2,1) resonance is a cross dipole.
So, if you can find an active T(1,1)3 resonance you have a live back guitar. If you can't, you have a non-live back guitar. Normally the T(1,1)3 peak, which shows the back coupling into the system, has a frequency greater than the T(1,1)2, as the nomenclature would suggest. If it is lower, the nomenclature falls apart a bit as the T(1,1)3 normally refers to the back's contribution. However, if it is lower, all sorts of things happen which I don't like the sound of (hence "kills volume and tone").
The T(1,1)3 in its "normal" region can have a bunch of beneficial effects which I won't go into in detail, but can add to the complexity of the sound (tone) at the expense of a bit of volume. Not having a T(1,1)3 saves you that volume loss, so, simplistically gives you "volume". However, if you make a very sensitive, loud, guitar, using a live back can stop it from becoming too raucous, with associated wolf tones, so you get a nicer sounding guitar if you give it a "proper" live back in those circumstances.
There are certain mobility criteria that have to be observed to ensure a live back, and a bunch of frequency relationships to take care of between the main T(1,1)x resonances so that things work as intended. It's easier to make a non-live back guitar, because you just make the back stiff/heavy and don't have to think about it any more. Getting a live back guitar right is more difficult and harder on classical guitars. Getting it wrong can give you the floppy back scenario, which in my experience is never good.
More, as ever, in the usual place.
PostPosted: Sun Jul 28, 2013 7:39 pm
First name: Trevor
Last Name: Gore
City: Sydney
So floppy to you would be back thickness / brace / brace style which is too unsupporting, that meaning that it sucks tone and volume from the guitar?
"Floppy" to me just means a T(1,1)3 that is too low, typically below the T(1,1)2. You can get that by going with a back that is too thin, too dense, not enough bracing, etc. etc. all the normal things that reduce resonant frequencies. What it does is absorb too much energy as it vibrates, so killing volume, and can produce a "phasing" muddy sort of sound if the T(1,1)2 and T(1,1)3 are too close together, irrespective of which has the higher frequency.
...in other words, can some back woods have only two contribution possibilities: "non-live" and "floppy"? Can some back woods be incapable of a "live" contribution?
I don't know that I'd be so "black and white" about it. However, it reminds me of this quote (Domingo Prat) about Torres' "cardboard" guitar:
"...this guitar has an extraordinary sound, if perhaps a little muted, bland and low, as the author of this dictionary was able to confirm when he played it in the house of Tarrega."
:lol:
If I was going for a live back I'd be avoiding heavily damped timbers just because they're harder to get them moving and keep them moving, so stealing more energy from the top to get them to work.
Users browsing this forum: meddlingfool and 33 guests
cron
