It is currently Mon Jul 28, 2025 12:15 am
PostPosted: Tue Jun 25, 2013 10:15 am
Last Name: Baley
City: Goleta
Zip/Postal Code: 93117
As part of my repair learning process, I bought a mid 70's made in Japan classical guitar that had a lot of issues (top separating from the sides, all the braces loose, etc, etc). I have pulled the neck and removed the top in preparation for all the brace work.
The top is laminated and ladder braced.
I am thinking I would like to replace the lower bout ladder brace with fan braces.
Does anyone have a suggestion on how to determine the correct size of the braces for such a top?
I could follow the standard size in Cumpliano but that seems too heavy for a laminated top.
PostPosted: Tue Jun 25, 2013 10:25 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Glue them on oversize and carve them down until it makes a nice sound when you tap it. As far as I can put it into words, it should go 'boom' rather than 'bong' - ie, it should sustain for a while. It should sound fairly similar all around the lower bout and 'tighter' above the soundhole where it needs to be braced stiffer.
Pablo Picasso
PostPosted: Tue Jun 25, 2013 12:21 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Being a learning process I'd replace the
top with a solid wood one with whatever bracing you want to
use.
Mike Collins
PostPosted: Tue Jun 25, 2013 6:29 pm
Last Name: Baley
City: Goleta
I considered it but it is just too much of a leap at this point.
I am not set up yet for making tops. I don't have a shooting board, my planes aren't sharpened and setup yet, I don't have a thickness gauge set up and I don't have any binding capability. I fully hope to be ready for this some day but just not yet. With all the things I am working on for repair stuff, builidng tops is further down the list. I am going to use HHG to put this top back on though so as a future practice for top building it will still be available.
Thanks for the suggestion
PostPosted: Tue Jun 25, 2013 7:16 pm
To be honest Dave, if any of us has any pertinent experience in bracing cheap plywood japanese classical guitar, they probably won't say it out loud... :D
Alain Moisan
(Now building just for fun!)
PostPosted: Wed Jun 26, 2013 10:41 am
Last Name: Baley
City: Goleta
oops. Sorry if I offended anyone.
I think I will just glue the loose brace back down and move on and leave the bracing until I have something worth the time to do it and I am ready for it.
"Newb" Dave
PostPosted: Wed Jun 26, 2013 10:51 am
"Newb" Dave
Don't get me wrong Dave. I'm sure no one has been offended at all. I was just trying to make a joke. I guess I'm better at making guitars than making jokes (I hope...).
Alain Moisan
PostPosted: Wed Jun 26, 2013 11:13 am
I bet you could find a local luthier to join and thickness a student grade top for cheap (OLFers?). With any lam trimmer, you could make your own circle cutter for a rosette and use a flush cut bit with a smaller bearing to give you a 1/16 inch binding channel.
