It is currently Thu Aug 21, 2025 6:20 pm
 Post subject: Building Cases
PostPosted: Mon May 20, 2013 9:29 am
Last Name: Ensor
City: Springfield
State: Missouri
Anyone ever build their own acoustic case? Any know where to get parts/hardware for a case build?
http://elevatelutherie.com
http://ensorguitars.com
 Post subject: Re: Building Cases
PostPosted: Mon May 20, 2013 9:52 am
It's been pondered. If you search you'll find some threads eg
viewtopic.php?f=10112&t=37267&hilit=case
As far as hardware LV or Stewmac ( http://www.stewmac.com/shop/Accessories/Case_parts.html) or
viewtopic.php?f=10101&t=21614&hilit=case
viewtopic.php?f=10101&t=29754&hilit=case
Saw a Greg Smallman doc years ago... looked like he made his own... very nice. Bendy-ply avail these days can make it easier.
Milton, ON
PostPosted: Mon May 20, 2013 9:54 am
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
seems like the only "hardware" would be hinges and latches. I don't see any reason why the ones at the hardware store wouldn't work. I've never made a case though. Seems like a rectangle box would Be simple To make. But the guitar shaped carbon fiber ones seem like a little more effort. What style are you going for?
PostPosted: Mon May 20, 2013 11:50 am
City: winnipeg
State: manitoba
Country: canada
I have built cases for ukuleles. I have found that fiber-board with wood veneer surface is used for furniture building (mine is free). eighth inch bends easily if it is wet and hot (spritz water, foil wrap, bend on mold). Hardware from Lee-Valley. The case is a tad heavy but works.
I am thinking glass cloth, epoxy resin and aluminum foil might be worth a try. Guitars would need extra structural design because of their length.
Bob :ugeek:
PostPosted: Mon May 20, 2013 12:03 pm
Last Name: Ensor
City: Springfield
State: Missouri
I am wanting to build a "standard" type of guitar case. Think TKL/Cedar Creek. And by me, I mean I want to convince my wife to do all the upholstry and non wood working type stuff. I don't think they would be hard to pull off.
Bob,
Do you have any "build" pics of how you make cases? I would love to see the process.
PostPosted: Mon May 20, 2013 1:50 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I have built a few coffin cases for guitars from plywood. It's pretty simple and the product looks good. But, the effort far exceeds the cost of a TKL case, even at retail. The cost of the materials is non-trivial. I do a Cedar Creek order once a year (they sell the TKL Prestige Elite cases). They cut a deal for builders. They are good people and the cases are well worth the cost.
PostPosted: Mon May 20, 2013 5:58 pm
I have built a few "coffin" cases using 1/2 inch pine sides and 1/8th inch plywood skins on the top and bottom. Glued and nailed and painted black, much the same as the originals, the box can be knocked together in a few hours. For linings and blockings I used corrugated cardboard panels wrapped in velvet remnants. Using 1/2 pine and 1/8th inch plywood helps keep the weight down, a common fault of homemade cases.
If you are good at scrounging and don't count your time you can build a box pretty cheaply. The coffin cases are not as sturdy as a commercially made hard case but for general transport in a passenger vehicle they are much better than the typical soft case.
Unless you need a special shape, you will be hard pressed to build a commercial type case for less than you can buy one (even counting your time for next to nothing).
PostPosted: Wed May 22, 2013 1:31 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I don't see the need to build a case unless the guitar is so oddly shaped that no pre-made case will fit it...
Typhoon Guitars
PostPosted: Wed May 22, 2013 2:03 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I'm not sure it would be worth the effort if you are looking to achieve the quality (without weighing a ton) you would expect from a pre-made case. That said, if you do it, I can't wait to see the results.
Bryan Bear PMoMC
PostPosted: Wed May 22, 2013 2:53 pm
FWIW here's a pic of a Smallman case ... nice
http://www.schrammguitars.com/ebay_small_case.jpg
http://www.romantic-guitars.com/wp-cont ... n-case.jpg
I agree it would be more a "labour of love" than commercially viable, but it would sure send a message re the quality guitar inside (& would be a cool project).
Milton, ON
PostPosted: Thu May 23, 2013 4:03 pm
I thought about veneering a case in Brazilian rosewood, but then I would need a case for the case. My English horn has a soft case to protect the hard case. Maybe I should carry it in a brown paper bag to protect the soft case. [headinwall]
Some people prefer to use cheap beatup cases to- NOT- advertise the quality of the guitar inside.
PostPosted: Sun May 26, 2013 3:58 am
First name: Brad
City: St. Louis
Chris, you may want to check out Scott Walker's website www.scottwalkerguitars.com and definitely his Facebook page. He builds primarily electrics, but does offer a few small batches of acoustics and hollowbodies every year. All of his guitars now include a custom built case by him with every order, and he has some very cool ideas. I'm sure he'd be able to point you in the right direction with design and vendors with all the necessary parts to put one together. Tell him I suggested you contact him, and i'm sure he'd be more than willing to help you out in anyway he can.
Brad
Brad
