It is currently Mon Aug 11, 2025 12:56 am
PostPosted: Wed May 15, 2013 3:12 pm
I've outsourced all of my necks to date. I'm not setup to make the joint or truss-rod slot, and when you add up the cost of the blank, truss-rod, and time, Hanaeli-Moon seems pretty reasonable.
The itch is there, though, and it's something I'd like to learn. Especially after following last week's dovetail v. bolt-on thread.
I have Porter Cable 690 and 310 routers, but no table. If I had a table the truss rod slot would be simple. Is there a way to cut it by hand (rabbet or pattern maker's plane?), or with the router without a table?
I feel comfortable enough with a saw to cut the tenon on the neck blank, but not sure how to cut the mortis on the body by hand. Any ideas?
A neck angle jig would be great, but our single car garage is pulling double duty as a garage gym. Space is pretty limited, so the more compact the better right now.
PostPosted: Wed May 15, 2013 3:24 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Truss rod slot is easy peasy! Just put an edge guide in the router and rout it in there. Do it in several passes of course not the entire depth at once but there is absolutely nothing to it. As far as the mortise and tenon use a hand saw or table saw. On my irate I did it with a hand saw. Just carefully mark the neck blank up and saw the two blocks out and kaboom baby you got a tenon. For the mortise you can cut it into the neck block before installation. Just mark to up and cut both sides with the saw and chisel out between the lines. Then carefully trim to fit the tenon nicely. The only thing you have to worry about doing it that way it to be sure you glue the neck block on it's in nice and square and straight. A center line around the block really helps with this.
Hope that helped. Let me know if ya got more questions. I may even be able to find a picture or two
PostPosted: Wed May 15, 2013 3:34 pm
Thanks, Zeke. I'm comfortable cutting the tenon. Didn't even know about edge guides.
Chiseling the mortis to tight tolerances seems iffy, but makes sense. Knock out the majority with a mortis chisel, then bring it home with some bench or paring chisels?
PostPosted: Wed May 15, 2013 3:43 pm
As Zeke said, a router with an edge guide will do it. You might use a 3/16 bit a hair off center and passes down each side (so you're left with 1/4" slot that you know is on centerline). As far as the mortise, many have cut them by hand (Jimmy D'Aquisto for one).
Milton, ON
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
A good functioning router table is simple, easy and cheap to make. Grab a piece of 3/4" mdf, counter sink mounting holes using your existing router base as a template. Use a straight edge of plywood clamped to the mdf as your fence...voila! I have made several of these to accommodate various sizes of router bits for minimal bit / table clearance.
Doug
PostPosted: Wed May 15, 2013 4:01 pm
First name: Zeke
Last Name: McKee
Here is the edge guide that came with my Bosch colt
Just set it and take your passes works great.
For the mortise you take most out with the chisel and then either chisel the sides slowly for a fit or I used a flat file on the sides.
PostPosted: Wed May 15, 2013 4:26 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
I have to agree with Doug about the table. If you've got a router, a piece of plywood or mdf should work just fine. Just need a couple of clamps and nice striaght board as a fence. I've used the edge guide, which works, put I find it easier to run the wood over the router than the other way around.
PostPosted: Wed May 15, 2013 4:54 pm
I have plans for a table, just prefer not to build one at this point. I agree that one would be nice. I built a few drumsets one summer in college. I just screwed a router to some plywood and flipped it over to cut the bearing edges :)
Dave, do you know how D'Aquisto cut the mortis?
PostPosted: Wed May 15, 2013 4:58 pm
First name: Zeke
Last Name: McKee
James of you have the cumpiano book he shows how to do it in there. It what I used as a guide for my first.
PostPosted: Wed May 15, 2013 5:41 pm
First name: Larry
Last Name: Hawes
Better than an edge guide (they only guide along one side and can move along the other) is a couple pieces of straight scrap clamped in place and run the router between the two pieces over the neck blank. I did my first that way - before I built a router table.
Thank You and Best To All
First name: Zeke
Last Name: McKee
Here is Zekes quick and crappy mortise tutorial.
Step one mark centerline
Step two measure and mark both sides of mortise and mortise depth. Mark on both sides and across the top. Shade in area for idiot proofing ;)
Use saw (I like the miter saw) to cut just inside of the lines to the depth of the mortise. Be sure to check both sides if the block do your cuts are nice and square
Use chisel to remove material inside of the two cuts. (I was in a rush and had tear out on the backside. Go from both directions to the middle to prevent this)
Voila a mortise. Now just file the sides a little at a time regularly checking the fit to the tenon.
PostPosted: Thu May 16, 2013 1:59 am
Router with an edge guide is all you need for a truss rod. I have a table, prefer to use the edge guide. Just remember the simple rule: routers go left. Relative to the direction you push them. So keep your fence to the left or the guide to the right.
PostPosted: Thu May 16, 2013 3:12 am
I have done similar from the start.
2 strips of Baltic ply, 18mm apart in a "frame" type jig and run the router with an 18 mm guide bush up this "slot"
Very simple to make, just give it a wax now and again.
Basically nowhere else for the router to go but straight.
PostPosted: Thu May 16, 2013 5:50 am
State: Tennessee
Zeke thats incredible laughing6-hehe but why not use your table saw? Take a 2' piece of whatever and run a few passes through the old saw and voila! You have a years supply.
PostPosted: Thu May 16, 2013 6:12 am
First name: Zeke
Last Name: McKee
I don't use the table saw because I'm too lazy to walk across the street and all the way to the back of the foundry to the pattern shop where the only table saw us located. Plus now I use a Simpson jig and router. :)
PostPosted: Thu May 16, 2013 6:39 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zeke, love your tutorial. Cumpiano would be proud.
PostPosted: Thu May 16, 2013 6:55 am
But keep your fence to the right in a table situation. Your router is upside down and will want to push the wood to the right.
Users browsing this forum: meddlingfool and 41 guests
